    Too much layer shifting
    32
    7.5k
    • Huguesundefined
      Hugues
      Those shifting in first post was not due to mechanical, otherwise it will not append strictly at the same height…
      I've made few test without stepper interpolation and it seem to work better, i didn't have shifting since removing it. But this result have to be validate with real comparaison test...
      • DjDemonDundefined
        DjDemonD
        It can be mechanical i.e. a print bed not properly secured so that it moves laterally my mini kossel does this as the bed mounts I made for FSR's are not clamps so the bed can shift it its not properly inserted, or electrical i.e. a motor skipping steps due to insufficient current, or being asked to move faster than it is able (i.e. insufficient current).
        www.precisionpiezo.co.uk
        • dvmourikundefined
          dvmourik
          I am using the onboard drivers in this model. Nothing hardware related because changing the board will make it print flawless.
          Sadly i was using pressure advance and this last print i removed it.
          But i don't want to hijack this thread. So we keep it to the shifting of the topic owner.
          Bigger and bigger… sky is the limit.
          • Huguesundefined
            Hugues
            @Djdemon i monitored the print and there was not mechanical, nothing move like bed shifting. It's more like the board forget few step
              deckingman
              @cubexupgrade:
              But it only affects one motor, hence the 45 degree angle of shift (corexy). Loose wire? Bad motor? Can you swap the XY motors and see if the shift then happens in the other direction? Looking at all the stringing at the bottom of the model, are you sure the nozzle didn't catch on a lump of plastic which either shifted something mechanically, caused the pulley to slip, or caused the motor to skip a few steps?
              @DC42, does interpolation affect motor torque? Just wondering if there is a mechanical resistance to movement, might a motor be more likely to skip steps with interpolation enabled.
                Interpolation will have only a tiny effect on motor torque. Maximum torque is produced when the motor is nearly 2 full steps behind the commanded position. A few 1/256 steps either way isn't going to make much difference.
                @cubexupgrade, are the two motors of the same type and definitely running at the same current? If you are using M584 to remap drivers, you should specify the mappings for all axes and extruders, and set the motor currents afterwards.
                • Huguesundefined
                  Hugues
                  @dc42 motors and current are the same. I haven't use motor mapping for this printer.
                  Since i deactivate interpolation i use pressure advance function without problem even with high accl/jerk. Maybe it's just hasard.
                  I do not push test because i've to print lot of stuff for works.
                  • Phil Maddoxundefined
                    Phil Maddox
                    Hi all
                    Was this issue ever resolved ?? Im having similar problems ( 1,5 & 1.16)
                    Prusa i3 steel Cartesian . Works fine with a ramps 1.4 with TMC 2100's
                    Doesn't always happen.
                    Doesn't happen at the same height
                    When it occurs its X and Y at the same time but not by the same amount.
                    Checked all the usual suspects but as yet no real culprit to be found
                    All help / input appreciatted
                    • Sniffleundefined
                      Sniffle
                      scientifically(one test print at a time), try reducing or eliminating your pressure advance first, then lowering your accel and jerk settings to what would be a more "normal(i3)" level.
                      I eliminated my layer shifting by greatly reducing my accel and jerk settings and there has been mention of potential issues with to many steps being generated on circular moves from pressure advance that can cause steps to be lost, though i think this was also squashed or its impact reduced.
                        Phil Maddox
                        Thanks ill certainly try that
                        Whats wierd is in the 2 months or so that ive been using the Duet Wifi its worked fantastically well on large and small prints alike . Just this past week or so ive had problems.
                        I'm not 100% convinced it the Duet Wifi but with all the usual suspects checked and double checked, i'm at a bit of a loss as to whats going on.
                        The only thing that has actually changed that i know of is ive upgraded to Simplfy 3D 3.1.1 but i cant really see how that would create this issue.
                        Maybe i should try another slicer to be sure.
                          T3P3Tony administrators
                          Sometimes layer shifting is caused by slipping pulleys at high speed acceleration.
                          • capundefined
                            cap
                            one thing i noticed sorry no tech guy here but are any of the motor wires crossing are touching as this coursed me problems
                            warning brain may explode
                              Phil Maddox
                              @T3P3Tony:
                              Would seem odd that both X & Y slipped at the same point in time/ the print and only once per print
                              Already checked them and am 100% sure they are super tight.
                                Phil Maddox
                                @cap:
                                Im confident the wiring is not the issue
                                  deckingman
                                  Here are some more possible reasons for shifted layers http://reprap.org/wiki/Shifted_layers
