"Z probe already triggered at the start of the homing move."????
4.9k
    @crchisholm said in "Z probe already triggered at the start of the homing move."????:
    M574 X1 Y1 S0 ; Set active low and disabled endstops
    M574 Z1 S2 ; Set endstops controlled by probe
    M558 P5 H5 F0 T6000 ; Set Z probe type to switch and the dive height + speeds
    G31 P500 X0 Y0 Z0 ; Set Z probe trigger value, offset and trigger height
    M557 X15:13 Y15:195 S20 ; Define mesh grid
    ; homez.g
    ; called to home the Z axis
    ; generated by RepRapFirmware Configuration Tool v2 on Fri Feb 01 2019 16:04:24 GMT-0500 (Eastern Standard Time)
    G91 ; relative positioning
    G90 ; absolute positioning
    G1 X15 Y15 F6000 ; go to first probe point
    You can change your configuration to use a simple endstop for the Z axis for the time being, and setup the BLTouch later once you have the parts printed.
    First you'll need to change the quoted config section above to match the following:
    M574 X1 Y1 Z1 S0 ; Set active low and disabled endstops
    ; M574 Z1 S2 ; Set endstops controlled by probe
    ; M558 P5 H5 F0 T6000 ; Set Z probe type to switch and the dive height + speeds
    ; G31 P500 X0 Y0 Z0 ; Set Z probe trigger value, offset and trigger height
    ; M557 X15:13 Y15:195 S20 ; Define mesh grid
    Basically just added the Z min endstop to the first M574 command, and commented out the whole z probe section.
    For the homing files you'll have to change homez and homeall to not use a G30 command and instead use G1 S1 Z move to seek the endstop.
    ; homez.g
    G1 S1 Z-300 ; seek end stop
    G1 Z5 ; back up
    G1 S1 Z-300 F300 ; home Z again slowly
    G1 Z5 ; part nozzle 5mm above the bed
    undefined 1 Reply Last reply 23 Feb 2019, 15:22 Reply Quote 0
      SupraGuy
      For that matter, you can set upt he printer to use a manual adjustment for the Z probe
      M558 P0
      This will allow you to use the Z jog buttons in the DWC as the Z probe, adjusting the Z height to 0 manually until you're ready to print the BLTouch parts.
      My earlier response was assuming that you had an already complete kit though.
      Lead screw driven printer, powered by Duet 2 Wifi
      MPCNC powered by Duet 2 Wifi
      CoreXY printer driven by Duet 3 6HC
      LowRider CNC powered by Duet 2 Wifi
        crchisholm
        this worked great. Thanks.
        One more question, though. Am I right to assume that the Duet supports either am min or max end-stop, but not both?
        undefined 1 Reply Last reply 5 Feb 2019, 18:37 Reply Quote 0
          Phaedrux Moderator @crchisholm
          @crchisholm you really only need one or the other to home to, afterwards the firmware will enforce travel limits.
          You can use one of the other endstops like e0 or e1 and use it as a general trigger endstop to do whatever you want if triggered. They can all be wired together if you use a switch on each axis for max.
            crchisholm @Phaedrux
            @phaedrux question: the code you show above... can it be entered and exicuted directly in the DWC? I have my printer built and all functionality tested except the BlTouch, so I don’t want to do something now that creates a problem (like a crash into the bed). I think I understand the M557 and M558 commands, and a lessor understanding of the G29, G30 and G31 commands but not real confident yet. Ruining this sfuff like console commands would allow me to dip my toes in the process ( I think)
              Yes every command can be run from the console. The config.g is just a list of commands that gets run in order at startup. There's nothing special about it other than that. Any time a new command is run it takes effect.
              So you could enter each line one at a time in the console. Or to make for less typing you could enter the commands into a new macro file called BLTouch test and then run that macro. That way if you want to revert just reboot the duet. If it all tests ok you can put the commands into config.g.
              The gcode wiki is a good reference to keep on hand for figuring out how the gcodes work.
              G29 is for mesh bed leveling.
              G30 runs the macro bed.g. and can be used for a number of things like lead screw leveling. It's not required.
              G31 defines the XYZ position of the probe in relation to the nozzle tip. So when the probe triggers the system know where the nozzle is.
                crchisholm
                This post is deleted!
                undefined 1 Reply Last reply 23 Feb 2019, 21:28 Reply Quote 0
                  crchisholm @crchisholm
                    crchisholm
                    undefined 1 Reply Last reply 23 Feb 2019, 21:40 Reply Quote 0
                      Scachi @crchisholm
                      @crchisholm You have your bltouch connected now ?
                      Check your sensor signal wiring and the value of your probe-z shown in the web frontend.
                      If it reads 1000 all the time you may have a wiring problem like bad crimp or using the wrong polarity of your probe signal cable or something like that.
                      Check the documentation and all the test and probe release reset command mentioned there:
                      https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_BLTouch
                      undefined 1 Reply Last reply 23 Feb 2019, 22:25 Reply Quote 0
                        crchisholm
                        I don't know why I am having trouble typing here, but what I actually entered in DWC was...
                        M557 X0:200 Y0:200 S50
                        M558 P9 H5 F100 T6000
                        G32
                        and I get the Z Probe already triggered before probing move started.
                        undefined 1 Reply Last reply 23 Feb 2019, 21:58 Reply Quote 0
                          @crchisholm what do you have in bed.g? That's what gets run when you send g32
                          undefined 1 Reply Last reply 23 Feb 2019, 22:30 Reply Quote 0
                            crchisholm @Scachi
                            @scachi Well, you called that one correctly! I have continuity on four or the five wires all the way from the termination point back to the jack on the BLTouch connector. The white wire does not. I am not sure what I can do about this as my eyes are just not up to working on a connector that small. I may have to return the device back to Amazon and order another. This is frustrating, but then, no body forced me to build this printer. Crap
                              @phaedrux As you will see from my last, I now have another issue I have to get resolved before I move ahead with this.
                              To answer your question.....
                              ; bed.g
                              ; generated by RepRapFirmware Configuration Tool v2 on Fri Feb 01 2019 16:04:23 GMT-0500 (Eastern Standard Time)
                              G29 ; probe the bed and enable compensation
                              BTW, how do you mark code as you did in your message. I tried <code></code> and that didn't seem to work.
                                All the forum markup can be found here: http://commonmark.org/help/
                                For the Bltouch wire that's unfortunate. Dupont connectors and crimps are quite fiddly. If you aren't able to recrimp the wire yourself perhaps a local electronics shop could give you a hand?
                                  crchisholm
                                  Crap! the return window is closed, so I will have to try and fix this tomorrow, or order another. Sheesh
                                    crchisholm
                                    Ok, so I ordered another BLTouch. It will be here Monday.
                                    @Phaedrux: In the meantime, I know there no since trying to figure out what was going on now that I know there was a problem with the wires, but does the bed.g look ok?
                                      The bed.g looks like it wouldn't have any problems, but there's only two commands in it. And G29 will automatically cancel any active bed compensation before running, so it's really only calling G32 to run G29. Might as well just call G29.
                                        Maybe I should elaborate on how G29 can be used.
                                        G32 used to be used to do a 5 point compensation routine that would generate a plane through 5 points you specified in bed.g. G29 has now taken over that roll, but it can do more than just 5 points. It's far more flexible. With G29 you specify a grid (with M557) and then a detailed network of points gets probed to allow for more fine grained adjustments.
                                        You can still use G29 with a sparse grid of points to get the same effect as the old way if you know your bed is really flat already and want to probe it quickly before every print this is not a bad way to go.
                                        However, if your bed isn't very flat but the platform itself is pretty stable, you can do a high detail G29 with lots of points and save that resulting heightmap and reload it before a print without needing to reprobe. Usually it would be loaded at startup in config.g or after homing, or right before printing.
                                        Does that kind of make sense on your options for using G29?
                                        Now that G29 is the recommended way of doing compensation, G32 and bed.g are usually used for printers with 2 or more independently Z axis lead screws so you can do automatic leveling.
                                          crchisholm
                                          Ok, I think I’ve got it. I am pretty confident that my bed is level: 0.25” tool and jig grade extruded aluminum. There will be a bed leveling need though. The rails that the x gantry ride on are out of parallel by a about 0.4 mm in 305mm and have not been able to get that fixed.
                                          I will give this all a fresh start on Monday when the replacement probe arrives.
                                          Thank again for all your help. Everyone!
