    PEI coated flex-plate system
    3D Printing General Chat
    13
    50
    6.2k
    • klcjr89undefined
      klcjr89 @keyz182
      @keyz182 Do you mean diameter? I'm not sure what you mean by diagonal, but yes, it excludes the tab sizes. So, the sheet would be about 310x310mm printing area and the tabs are about 20mm in length.
      Thank you!
      • gregspruceundefined
        gregspruce
        I backed it - I'm using the IR sensor with my current PEI stuck to a buildtak flex plate and the transparency is a pain to deal with. I like the texture and opacity of this plate.
        klcjr89undefined 1 Reply Last reply Reply Quote 0
        • klcjr89undefined
          klcjr89 @gregspruce
          @gregspruce Greg, I sincerely appreciate it. I messaged you in my Kickstarter dashboard.
          I am not sure how to deal with the problem of people wanting to order just the sheet if they already have a magnet system, so I made a FAQ on the Kickstarter.
          The problem is, if I sold 500 coated sheets without the magnet and 100 with the magnet, I wouldn't meet the minimum order quantity from my supplier to order the magnet material.
          gregspruceundefined 1 Reply Last reply Reply Quote 0
            gregspruce @klcjr89
            @klcjr89 I'm sure I can find a creative use for an extra magnet.
            Or just use it as an excuse to pull together all of my other spare parts and build yet another printer. 😄
            • klcjr89undefined
              klcjr89 @gregspruce
              @gregspruce
              That’s very true. It could be used for lots of things due to the high temp rating and adhesive backing! ☺
              • gavatron3000undefined
                gavatron3000
                Ill back it also, I've got a custom size one from thekiinnng in Canada as I've set magnets in my cast aluminium bed. Works great but the issue I've faced already with the textured sheet was the pores went through to the steel sheet in some places and began to rust underneath the pei resulting in it lifting off within 2 months .
                I hope you can achieve a reliable quality
                • klcjr89undefined
                  klcjr89 @gavatron3000
                  @gavatron3000
                  Thank you for being a backer. I noticed with the amazon sheets and Prusas is that the texture is pretty coarse; maybe that is part of the issue. I've had people using them since July without issue.
                    gavatron3000
                    Is it possible to specify no magnets?
                    • klcjr89undefined
                      @gavatron3000 said in PEI coated flex-plate system:
                      Technically, yes, but if you don't need the magnet couldn't you use it for something else? Otherwise you would be paying for something you're not receiving.
                        gavatron3000
                        Yep fair enough, I'm sure I could find something to use it on
                        • timcurtis67undefined
                          timcurtis67
                          Is 310mm the limit in size?
                          I'm looking for one around 460mm square, 450mm minimum.
                          • klcjr89undefined
                            klcjr89 @timcurtis67
                            @timcurtis67 said in PEI coated flex-plate system:
                            The size limit is stated on the Kickstarter. We also have a FAQ section over there as to the current limitations. The future is bright however for making any size if the Kickstarter is successfully funded.
                            Thank you!
                            • klcjr89undefined
                              klcjr89
                              We have just published an update to the Kickstarter. We are now offering flex-plates without the magnet based off of feedback.
                                gavatron3000
                                I shared your Kickstarter with 3d printing Australia group also. A few people interested there
                                • klcjr89undefined
                                  You have no idea how much that means to me. I am very humbled ☺
                                  Thank you!
                                  • Dougal1957undefined
                                    Dougal1957 @klcjr89
                                    @klcjr89 I have also shared it on the 3D-Printers Discord server
                                    3Dprinting
                                    • klcjr89undefined
                                      klcjr89 @Dougal1957
                                      @dougal1957 Doug, thank you for that!
                                      Are you still enjoying your Nimble?
                                        Dougal1957 @klcjr89
                                        @klcjr89 Oh yes best upgrade I ever made in fact I have a sidewinder waiting for me to finish my CoreXY Build.
                                        Any chance you could do your bed plates any larger my delta is 370 diamater and my CoreXY will be 450x450
                                        • klcjr89undefined
                                          klcjr89 @Dougal1957
                                          @dougal1957 said in PEI coated flex-plate system:
                                          Doug, we can make any size in the future if the campaign is funded. To make sizes greater than 310mm requires the purchase of 10 tons of steel in larger widths, as that is the minimum order quantity unfortunately.
                                            Dougal1957 @klcjr89
                                            @klcjr89 Yeah I can see why that would be prohibitive. Have seen your comments on the discord as well (I'm lil doug on there)
