    DueUI: An Alternate Web Interface
    DueUI
    12
    65
    11.4k
    • thweundefined
      thwe @gtj0
      @gtj0 said in [Preview] DueUI: An Alternate Web Interface:
      @davea Check settings. You probably have "Don't Send GCode. Log Only" checked (green). For normal operation it should be off (red).
      … that it will be - with me all orders are executed first.
      Also, I've created ATX ON / OFF buttons -> runs!
      Unfortunately, the themes do not seem to be so uniform: after switching between themes, the fields are slightly shifted
      Values at the heaters are only displayed as soon as I have switched on my 24V supply (ie ATX ON).
      After an ATX-OFF, the status is not updated.
      Depending on the theme, the key cross for XY is also shifted, the midpoints are not exactly on top of each other.
      But it can also be on my 10.1 inch tablet ... no matter, you can adapt - but you should stay with a theme!
      Otherwise, the beginning is really good
      Thomas
      • gtj0undefined
        gtj0 @thwe
        @thwe said in [Preview] DueUI: An Alternate Web Interface:
        The next alpha will expose the "checkbox" widget that the buttons in settings use. This way you can have a single button that toggles the ATX power state.
        I'll check on that today.
        Unfortunately, I have no control over the themes but I thought all of the themes except for "Base" were consistent. "Base" is basically "no theme" so the contents may shift when you switch between "Base" and any other theme. Does refreshing the browser between theme switches help at all?
        For the XY Axis issue, try this for the Y axis position...
        "position": {"my": "center center", "at": "center center", "of": "#jog_x" }
        and see if it works. That should align the 2 center blank buttons. For me, it works on some devices but not others.
        Thanks!
        thweundefined 1 Reply Last reply Reply Quote 0
        • DaveAundefined
          DaveA @gtj0
          @gtj0 Yep, that was it. Thanks.
          • gtj0undefined
            gtj0 @DaveA
            @davea The ATX issue is that I forgot to add a status for "O" (off) to the
            status map at the bottom of the config file.
            Add...
            "O": {"label": "Off","style": {"background": "red","color": "black"}},
            to the status_map object after the entry for "H".
            • thweundefined
              thwe @gtj0
              No, there are little differents from hight of Buttons and so on.
              Never mind, now I use only theme BASE as my Basic.
              Other feedback:
              After pressing STOP, the printer stops as expected immediately - but then the DWC asks "The firmware still reports to be stopped after an emergency stop." and must be answered there - unfortunately not on DueUI. Even pressing the "RESTART" button on the DueUI does not help.
              Is there a solution here?
              Thomas
              • gtj0undefined
                gtj0 @thwe
                Other feedback:
                Hmmm. On my Duet, when I send M112, the Duet restarts by itself and is ready again in about 15 seconds. Try it with the DWC disconnected and see what happens on DueUI.
                • thweundefined
                  thwe @gtj0
                  Without a connect from DWC to the Duet every is OK.
                  Other question:
                  with
                  "actions": [{"type": "gcode", "gcode": "M98 Px_macro_test01.g"}]
                  i can call a file, but how can i call a macro from the macro-subfolder?
                  ... for example "\macros\Tools\Tool bed messuring 5 points"
                  Thomas
                  • thweundefined
                    thwe
                    Below I want to show you what I have created in the last few days with the DueUI.
                    DueUI is certainly not a replacement for DWC, but for me the ideal basis as a control panel directly on the printer.
                    Small netbook (without touch) was ok so far, but the operation with mouse pad was not so comfortable. Also the picture quality was not so sharp.
                    Desire was as much control panels by touch on little surfaceas as possible and not to lose the overview - so actually a contradiction.
                    Since my 10 inch tablet only serves once a year as a navigation tool on the boat, it has now got a great job again πŸ‘
                    Surely everyone has it's own idea of ​​what an ergonomic and clear surface is, but with the DueUI you can quite well realize your own taste.
                    With a little bit of logical thinking, even a non-programmer like me can do something with it.
                    Below are a few pictures of my current state in the Chrom-browser:
                    Display in normal mode, axes homed, ATX ON
                    ATX OFF
                    And now in full-screen - and now the status indicator is visible
                    After a reboot - axes not homed and ATX OFF
                    Open selection menu
                    The operation of the axes with the jogging as a cross is closer to reality, but so the place is much better exploited - we are all professionals and come so synonymous with itπŸ˜†
                    If you are interested, I will gladly provide the configuration file, but without any guarantee and with the note that certain details are adapted to MY printer and probably only usable on a 10 inch tablet.
                    Thomas
                    gtj0undefined 1 Reply Last reply Reply Quote 4
                    • gtj0undefined
                      gtj0 @thwe
                      Other question:
                      with
                      When a macro is in a subdirectory, you have to use the full path...
                      M98 P"/macros/Tools/Tool bed messuring 5 points.g"
                      • gtj0undefined
                        gtj0 @thwe
                        <snip>
                        That's fantastic! It's demonstrates perfectly the whole point of DueUI: Creating something that works for YOU. Thanks for sharing it!
                        I was thinking of enabling the Wiki on GitHub where others could share their designs. Maybe this will be the first.
                        • thweundefined
                          thwe
                          I tried
                          "actions": [{"type": "gcode", "gcode": "P"/macros/Tools/Only_a_test.g""}]
                          but this would not work (Syntax error of CSS) because of the double quotes
                          … this
                          "actions": [{"type": "gcode", "gcode": "P/macros/Tools/Only_a_test.g"}]
                          is for the CSS correctly, but the Duet can not interpret that because:
                          --> Error: Bad command: P/macros/Tools/Only_a_test.g
                          Somehow, the 2 "quotes" must be passed in the Statement within the outer quotation marks
                          Thomas
                          • thweundefined
                            thwe
                            Another Question:
                            Is it possible to show the value of the slider?
                            In my pictures you can see that I have inserted 3x? as a placeholder
                            Thomas
                            • gtj0undefined
                              gtj0 @thwe
                              I tried
                              You can either escape the double quotes with backslashes:
                              "actions": [{"type": "gcode", "gcode": "P\"/macros/Tools/Only_a_test.g\""}]
                              or in javascript, single and double quotes do the same thing:
                              "actions": [{"type": "gcode", "gcode": "P'/macros/Tools/Only_a_test.g'"}]
                              or:
                              "actions": [{"type": "gcode", "gcode": 'P"/macros/Tools/Only_a_test.g"'}]
                              or if your macro path doesn't have spaces, you can leave the inner quotes off:
                              BUT see below.
                              … this
                              That's because your real issue is that you forgot the M98 GCode command at the beginning. πŸ™‚
                              "actions": [{"type": "gcode", "gcode": "M98 P/macros/Tools/Only_a_test.g"}]
                              • gtj0undefined
                                gtj0 @thwe
                                Another Question:
                                The best way to do that right now is to have those "???" placeholders be buttons and track the state of the fanPercent values in the status message just as the slider does.
                                "read_only: true,
                                "status_level": 1,
                                "value": "${status.params.fanPercent[0]}",
                                Change "0" to correspond to each slider's value.
                                In the next release, I'll add the capability to have labels also track status variables.
                                • thweundefined
                                  thwe @gtj0
                                  There are many problems with programming, the biggest ALWAYS sits in front of the screen 😎 πŸ˜‰
                                  Now it worksπŸ‘
                                  Thomas
                                  • thweundefined
                                    thwe @gtj0
                                    @gtj0 πŸ‘
                                    First i tried it with "label" ... without success
                                    code adapted:
                                      "id": "fan_0_label2",
                                      "type": "button",
                                      "enabled": true,
                                      "read_only": true,
                                      "status_level": 1,
                                      "value": "${status.params.fanPercent[0]}%",
                                      "style": {"width": "9ch","height": "30px", "font-size": "10px", "text-align": "center"},
                                      "initial_value": "---%",
                                      "position": {"my": "left top", "at": "right+3 top+1", "of": "#fan_0"}
                                    and this is the result:
                                    I'm very satisfied πŸ˜€
                                    Thomas
                                    • pro3dundefined
                                      pro3d
                                      I appreciate this project as I use a tablet for controlling the printer with DWC. DWC in a browser is very touch sensitive and I tend to activate stuff I dont mean to and often accidentally refreshes the browser by dragging witch creates a lot of irritation for me. This is a android tablet with chrome browser
                                      Is this UI more user friendly in the touch department?
                                      Is it possible to make an application for mobile devices that is not just a browser based solution? I was very happy with the printoid app when using octoprint. It was an awesome controller with a tablet
                                      https://printoid.net/
                                      Valkyrie DIY High Temp 3D Printer
                                      R&D - Engineering Designer - Viking 3D Printers
                                      https://vkingprinter.com/
                                      gtj0undefined 2 Replies Last reply Reply Quote 1
                                      • thweundefined
                                        thwe
                                        Update made on alpha3 and also tested and implemented the new ATX button ... really nice option
                                        Unfortunately, I do not understand the other possibilities or how exactly the syntax must be.
                                        I wanted different actions in a widget and a pop-up dialog with selection and subsequent execution of the selected selection.
                                        So the "choose" variant of my test without success:
                                        /* START of TEST choose-button */
                                        					"id": "xtestx",
                                        					"type": "button",
                                        					"enabled": true,
                                        					"position": {"my": "left top", "at": "right+5% top", "of": "#elapsed"},
                                        					"style": {"width": "30%", "height": "2.5em"},
                                        					"status_level": 1,
                                        					"state_field": 1,
                                        					"state_styles": [
                                        						{"background": "red", "content": "A-A-A-A"},
                                        						{"background": "green", "content": "B-B-B-B"}
                                        					"value": "TEST",
                                        					"actions_type": "choose",
                                        					"actions": [
                                        						{"type": "gcode", "gcode": "G4 P100"},
                                        /* END of TEST choose-button */
                                        Please can you give me a little support πŸ€”
                                        Thomas
                                        • gtj0undefined
                                          gtj0 @pro3d
                                          @pro3d said in [Preview] DueUI: An Alternate Web Interface:
                                          DueUI can be customized right down to the button sizes so if you have large fingers like me, you can make the controls a bit bigger and increase the spacing between them.
                                          Hmmm. It may be possible, at least for Android. I haven't done any Android app development in a few years but it was fairly easy to take a web app and wrap it in a Webview component so it looked like a native app. This might also solve a nagging issue with having to keep making the browser full-screen to see all the content. Let me think about it. For the Apple platforms, well, sorry but I have no experience there nor can I realistically get any.
                                          • gtj0undefined
                                            gtj0 @thwe
                                            Your syntax is correct. I tested this I swear but I must have broken it afterwards. I'll fix it tonight. And I'll re-test it πŸ™‚
