    big box madness
    4.3k
      I suggest you test the motors using G1 S2 moves at low speeds (send G91 first to put axis motion in relative mode).
      If you plug the X motor into the Y or Z output, can you get it to move? Power down before connecting or disconnecting motors.
      • magdiundefined
        magdi
        Right im with you guys. Am now in the process of testing all the wires and getting the stepper sorted will then re-wire and hopefully be sorted.
        Cheers for the help will confirm once complete
          Phaedrux Moderator @magdi
          @magdi said in big box madness:
          M574 X1 Y1 Z1.2 S1 ; set endstop configuration (X and Y endstops only, at low end, active high)
          Z1.2? I don't think that's valid.
          • Ryan Lockundefined
            Ryan Lock
            Hi @magdi,
            Thanks for posting your config.g file and the model of your motor. You want to see it to no more than 1.45A.
            That error normally relates to a wire being disconnected or not properly connected. As DC42 suggested try the known working X-Axis wire with either the Y or Z-Axis motor.
            If that fails try plugging the known working X-Axis wire AND motor into the Y-Axis or Z-Axis port.
            Best Regards
            Ryan Lock
            magdiundefined 1 Reply Last reply Reply Quote 0
            • magdiundefined
              magdi
              So I've unplugged every wire on the motherboard, tested everything on another motherboard including all the wires for steppers and the steppers that I've been using. They all work there. Now I plug one motor into the duet (currently working with z motors) and nothing happens. Have tried every combination of pin connection and everything ugh.
              I'm just pulling my hair out at this point im so confused.
              What have I done wrong?!
                I already made a suggestion to try to pin down the problem, but you appear to have ignored it.
                • magdiundefined
                  magdi @dc42
                  @dc42 have tried that i get the same error for connection sorry I didn't reply to it so that's with putting the x axis motor on another axis.
                  I was just doing what you then later said but I tested all the hardware to see if it worked first
                  • magdiundefined
                    magdi @Ryan Lock
                    @ryan-lock thanks for the advice. I have tried moving around the x axis motor to other ports, with and without the same wire. And using that working X wire on other motors. Still the same errors unfortunately. Even got some new wires and the same issue 😞
                      Let's start with getting the X motor working when it is connected to the Y motor output. Please add the following command to the start of config.g:
                      M584 X1 Y0
                      That will swap the X and Y motor outputs over. Also connect the X motor to the Y motor output, and vice versa. Then try moving X and Y again. If the X motor (connected to the Y motor output) moves correctly when you command X movement, but the Y motor (connected to the X motor output) doesn't, then it is a configuration problem. If the X motor stops working but the Y motor starts working, then it is a problem with the Y driver.
                      • magdiundefined
                        magdi
                        @dc42 said in big box madness:
                        M584 X1 Y0
                        right i have tried what you have advised. problem still persists with the Y driver, driving the x axis.
                          Thanks. Please ask your supplier to replace your Duet.
                          • magdiundefined
                            magdi @dc42
                            @dc42 so new board, new problems.
                            I cant seem to get the end stops to now work.
                            motors are moving fine but the end stops aren't doing their bit.
                            have a 2 wire endstop so ive wired them on both ends of the endstop. (light starts off as red and then when the stops are engaged turns off) . have tried both X1 Y1 and X0 Y0 and the current code also on my endstop in config.g
                            M574 X2 Y2 S1 ; Set active high endstops
                            also i have an E3d hot end and am a bit confused about using the pt1000 amps? ive connected them currently straight to the duet but temps are like 2000c.
                            magdiundefined Vetiundefined 2 Replies Last reply Reply Quote 0
                            • magdiundefined
                              magdi @magdi
                              @magdi right i have made stuff do things.
                              problem now is when i press to 'home y' it homes y a little and also homes x.
                              so both axis move not just one. But then they also dont move all of the way to homing. hopefully that makes sense.
                              • Vetiundefined
                                Veti @magdi
                                do you mean pt100?
                                did you configure the m305 correctly?
                                • magdiundefined
                                  magdi @Veti
                                  @veti yes pt100 i think.
                                  heres what i have atm but in all honesty im not sure what to configure here.
                                  M305 P0 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 0
                                  M305 P1 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1
                                  M305 P2 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 2
                                  M143 H2 S280 ; Set temperature limit for heater 2 to 280C
                                  • Vetiundefined
                                    Veti
                                    none of those are for pt100 or pt1000 thermistors
                                    check the configurator for the sensor channel to set it correctly
                                    https://configurator.reprapfirmware.org/Heaters
                                    • magdiundefined
                                      magdi @Veti
                                      @veti cheers for the help, i have changed to the pt100, but still have the same issue. where should i then pin the two wires into the board,
                                      • Vetiundefined
                                        Veti
                                        to the external RTD interface board
                                        https://duet3d.dozuki.com/Wiki/Connecting_PT100_temperature_sensors
                                        • magdiundefined
                                          magdi @Veti
                                          @veti i have tried it and still cant connect the bloody thing. so ive found the daugherboard connection point on the duet. that has 10 pins. i only have 4 wires (dual extruders' with two sets of black and red wires connected together) I just dont know where to put the bloody things. the images on the page you supplied are not very helpful and i cant crack the schematic. i think im just being stupid.
                                            @magdi Do you have a PT100 daughterboard?
                                            https://www.duet3d.com/PT100_DaughterBoard
