    Duet wifi died last night and can't get it running again
    1.1k
    • totalitarianundefined
      totalitarian
      Photo of LEDs
        https://duet3d.dozuki.com/Wiki/What_to_do_if_your_Duet_won't_respond
        totalitarianundefined 1 Reply Last reply Reply Quote 0
          totalitarian @Phaedrux
          @phaedrux THanks, but I have already tried those steps.
          • Atelier3Dundefined
            Atelier3D
            Have you checked your fuses to see if any of them are blown?
              dc42 administrators @totalitarian
              @totalitarian said in Duet wifi died last night and can't get it running again:
              All of them, including this one https://duet3d.dozuki.com/Wiki/What_to_do_if_your_Duet_won't_respond#Section_If_the_port_still_doesn_t_appear_on_the_PC ?
                totalitarian
                Port appears but I get this reply from pronterface sending M115
                [ERROR] Can't read from printer (disconnected?) (SerialException): call to ClearCommError failed
                [ERROR] Can't write to printer (disconnected?) (SerialException): WriteFile failed (WindowsError(22, 'The device does not recognize the command.'))
                  Does it still do that if you remove the SD card and restart? You may have to wait a few tens of seconds for it to give up reading the SD card at startup.
                    totalitarian
                    Thanks, had to reflash using SAM-BA. Now I can see the error
                    Error: short-to-ground reported by driver(s) 3
                    [ERROR] Error: short-to-ground reported by driver(s) 3
                    Error: over temperature shutdown reported by driver(s) 3
                    [ERROR] Error: over temperature shutdown reported by driver(s) 3
                      If you have a motor connected to driver 3 (the E1 E0 output), power down and disconnect the motor to avoid overheating it. Then check whether you still get the same error report, and whether the E1 E0 driver chip is getting hot.
                        totalitarian
                        Isn't driver 3 E0 rather than E1?
                        Either way, I unplugged all drivers and still get that same error 😞
                          Correct, E0 not E1. If your Duet is under warranty, please ask your supplier to repair or replace it.
