Slicer based Dynamic Acceleration Control
Think I'm running a Marlin flavour. Didn't think there was a reprap. Will look for that. Thought marlin was the preferred option but it's been a long time since I looked at that side of it for a while.
I like the ability to set acceleration and jerk values based on print move type. Cura has good control and uses the right gcodes for it. Slic3r PE is less detailed in the control. And they aren't receptive to change based on threads from their GitHub on the subject. They'd rather any firmware configuration happen in their Marlin flavor machine specific gcode parser. But I'm surprised that vanilla slicer uses M201 at all.
There are definitely behavior changes in the slicers based on gcode flavor choice. It's actually a little maddening trying to find details on what those specifics are without going into source code.
@phaedrux Yes, I want the see variable jerk on Slic3r too. Interior infill could be sped up and/or external perimeters and top surfaces tidied up.
My only grumble is there should be a gcode that is used and respected for limits, and another for geometry level changes in acceleration and jerk. Having seen how slopy it is done atm I am tempted to put a reload config file in my end of print gcode. Think that's already been mentioned.
@doctrucker said in Slicer based Dynamic Acceleration Control:
The options I have on my dev version of Slic3R for gcode flavour are listed as:
RepRap (Marlin/Sprinter)
Repetier
Teacup
MakerWare
Sailfish
Mach3 (Linux CNC)
Machinekit
Smoothieware
No Extrusion.So Reprap/Marlin/Sprinter seem to be one and the same.
But on the PE version it's RepRap/Sprinter with Marlin being listed as a separate "flavour" option.
Just to muddy the waters even more...........
Just checking in Slic3r PE and when you have Marlin flavor selected in the printer settings tab you get an entire machine limits page that lets you set all the speed settings. Which I think is what they pass into the path planner for their accurate time estimates.
Then in the resulting gcode file you get this:
M201 X4000 Y4000 Z60 E8000 ; sets maximum accelerations, mm/sec^2 M203 X500 Y500 Z7 E10 ; sets maximum feedrates, mm/sec M204 P1500 R8000 T1500 ; sets acceleration (P, T) and retract acceleration (R), mm/sec^2 M205 X10.00 Y10.00 Z0.50 E10.00 ; sets the jerk limits, mm/sec M205 S100 T233 ; sets the minimum extruding and travel feed rate, mm/sec
I think one of the recent firmware versions had a bunch of the marlin specific gcodes added for compatibility. M205 for example, though only for jerk. https://duet3d.dozuki.com/Wiki/GCode#Section_M205_Set_max_instantaneous_speed_change_in_mm_sec
@deckingman said in Slicer based Dynamic Acceleration Control:
Yes, the PE version split off the Marlin flavour a little while ago when they added the machine parameters page I posted above and switched to using the marlin path planner for their time estimates.
I just tried to test the latest dev version of vanilla slicer to see how it behaves, but I couldn't get it to do anything without crashing on OSX.
@phaedrux Jeees. So PE Slic3R does mess with M201 - also M203, M204, M205.
Only when you're using Marlin flavor. Which is intended for use with their own printer and firmwares which enabled their full speed and quite mode operation. It doesn't do that if you're using RepRap flavour.
@phaedrux ahh OK.
