    Replaced hot end and now get vssa fault
    2.4k
    • chriskimbrundefined
      chriskimbr @Veti
        chriskimbr
          chriskimbr @Veti
          @veti see pics
          bed is 24 degrees but hot end is 2000.C which is fault.
          • Vetiundefined
            Veti
            do replace the connector with a proper molex plug.
            check that there is no connection between the thermistor and the heater block/heater element.
              chriskimbr
              @veti Are you saying replace the connector to the thermister e-temp 0 ?
              What is a correct Molex connector for it?
                chriskimbr
                I replaced the stock Tronxy X5SA hot end with the v6 clone above.
                Ohm reading for new thermistor is 106.
                Would these settings above need to change for the next thermistor / hot end?
                Would this be causing the VSSA fault reading 2000.0C ?
                config.g file section for
                M305 P0 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 0
                M305 P1 T100000 B4388 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
                ;M305 P1 R4700 T100000 B4388 ; set E0 thermistor parameters
                • Vetiundefined
                  Veti
                  @chriskimbr said in Replaced hot end and now get vssa fault:
                  the correct connector came with the duet. its the 2 pin one.
                  where did you get those values from?
                  no the cause for that is faulty wiring or a blown vssa fuse.
                    chriskimbr
                    @veti
                    Is this the correct connector?
                    Regarding my setting...
                    Got the settings from someone else with same printer.
                    What needs to be changed?
                    • Vetiundefined
                      Veti
                      but you switched the thermistor. you need the settings that fit your thermistor.
                      you can calculate the values from the thermistor table that you hopefully got with the hotend.
                      chriskimbrundefined 1 Reply Last reply Reply Quote 0
                        chriskimbr @Veti
                        @veti The hot end with thermistor came with no documentation.
                        • Vetiundefined
                          Veti
                          then you prob need to either
                          • measure the resistance at 50 and 240 degrees using a calibrated temperature sensor.
                          • buy a thermistor with documentation
                          • live with inaccuracies that could range around 40 degrees
                            chriskimbr @Veti
                            @veti Im going to get a cheap hot end and thermistor from local store to test and see if im having same problem.
                            from what your telling me , i need to look at thermisor table and set the 'C' value ?
                            • Vetiundefined
                              Veti
                              you can use the configurator tool to calculate the values
                              https://configurator.reprapfirmware.org/Heaters
                                chriskimbr @Veti
                                @veti so the setting for thermistor isnt causing the vssa fault?
                                • Vetiundefined
                                  Veti
                                  wrong B and C values will just give you wrong temperature reading. 2000 means there is no reading
                                    The Vssa fault message means that the Vssa line, which should be very close to ground potential, is actually closer to +3.3V.
                                    The usual cause of this is a short between the side of the thermistor that is connected to Vssa, and the hot end heater or bed heater. So if you get a Vssa fault report, disconnect the thermistors one at a time. Then you will be able to tell which thermistor has the short to a heater.
                                    If you disconnect all the thermistors and you still get the Vssa fault, then either the Vssa polyfuse is open circuit, or the Vssa sense series resistor is open circuit.
                                      chriskimbr @dc42
                                      @dc42 if i dissconnect the hot end thermo the bed thermo works fine
                                        chriskimbr
                                        Good lessons learned here.
                                        Thanks for all your input and help.
                                        I went to local shop and bought another hot end assembly.
                                        Narrowed it down to the Thermistor wire is bad. The new thermistor works with no fault!!!
                                        Is it common to get bad Thermistor wires? Is there something i may have to to damage it?
                                        See temps!!! No faults!
                                        The culprit! Day waisted thanks to this guy and gearbest🤬
                                        • Vetiundefined
                                          Veti
                                          you need to be aware of the quality of the product you purchase from china.
                                          there is no quality control. so its a good idea to purchase a bit more than you need.
                                          stores i found that supply good quality products from aliexpress: triangelab, Biqu and fysetc.
                                            To get a short from the heater voltage to Vssa there are usually two faults. The first is a short between the thermistor wire and the hot end metalwork, which you have found. The second is a short between a heater wire and the hot end metalwork. So check the heater wires where they come out of the cartridge. If you can't find a short, then there may be a short in the heater cartridge between the element and the case.
