    Unable to Connect Duet Ethernet via Web Interface
    1.6k
    • mfisher103undefined
      mfisher103 @aidar
      @aidar Ok I removed the M40 command and changed the IP to 0.0.0.0....and I still can't connect..anything else I am missing?
        What response do you get when you send command M552 via the USB port?
        mfisher103undefined 1 Reply Last reply Reply Quote 0
          mfisher103 @dc42
            mfisher103
            ; Configuration file for factory testing Duet Ethernet and Wifi with V2.01 firmware
            FOR TESTING ONLY! USE https://configurator.reprapfirmware.org/ to generate configuration files for your printer!
            ; Communication and general
            M111 S0 ; Debug off
            M550 PDuetTest ; Machine name and Netbios name (can be anything you like)
            M551 Preprap ; Machine password (used for FTP)
            *** Ethernet networking: The following lines are used for factory testing - PLEASE REMOVE THEM
            M552 P0.0.0.0 ; IP address
            M554 P192.168.1.255 ; Gateway
            M553 P255.255.255.0 ; Netmask
            ;*** End of factory test lines to be removed
            ;*** Networking
            M552 S1 ; Turn network on
            M555 P2 ; Set output to look like Marlin
            G21 ; Work in millimetres
            ; Disable Fan 1 thermostatic mode
            M106 P1 H-1
            ; Axis and motor configuration
            M574 X2 Y2 Z2 S1 ; set endstop configuration (all endstops at high end, active high)
            ;*** The homed height is deliberately set too high in the following - you will adjust it during calibration
            M665 R105.6 L215.0 B85 H250 ; set delta radius, diagonal rod length, printable radius and homed height
            M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
            M350 X16 Y16 Z16 E16:16 I1 ; Set 16x microstepping with interpolation
            M92 X80 Y80 Z80 ; Set axis steps/mm
            M906 X1000 Y1000 Z1000 E800 I60 ; Set motor currents (mA) and increase idle current to 60%
            M201 X1000 Y1000 Z1000 E1000 ; Accelerations (mm/s^2)
            M203 X20000 Y20000 Z20000 E3600 ; Maximum speeds (mm/min)
            M566 X1200 Y1200 Z1200 E1200 ; Maximum instant speed changes mm/minute
            ; Thermistors
            M305 P0 T100000 B3950 R4700 H30 L0 ; Put your own H and/or L values here to set the bed thermistor ADC correction
            M305 P1 T100000 B3974 R4700 H30 L0 ; Put your own H and/or L values here to set first nozzle thermistor ADC correction
            M305 P2 T100000 B3974 R4700 H30 L0 ; Put your own H and/or L values here to set 2nd nozzle thermistor ADC correction
            M570 S180 ; Hot end may be a little slow to heat up so allow it 180 seconds
            ; Adjustments for dummy heaters on test rig
            M307 H0 A250 C140 D5.5 B1
            M307 H1 A250 C140 D5.5 B0
            M307 H2 A250 C140 D5.5 B0
            M106 P1 S-1 ; disable thermostatic mode for fan 1
            ; Tool definitions
            M563 P0 D0 H1 ; Define tool 0
            G10 P0 S0 R0 ; Set tool 0 operating and standby temperatures
            ;*** If you have a single-nozzle build, comment the next 2 lines
            M563 P1 D1 H2 ; Define tool 1
            G10 P1 S0 R0 ; Set tool 1 operating and standby temperatures
            M92 E80:80 ; Set extruder steps per mm
            ; Z probe and compensation definition
            ;*** If you have a switch instead of an IR probe, change P1 to P4 in the following M558 command.
            M558 P5 F100 T6000 X0 Y0 Z0 H3 ; Z probe is a Smart Effector and is not used for homing any axes R0.4 not used. Reduced F300 to 100
            G31 P100 X0 Y0 Z-0.25 ; Set the zprobe height and threshold for Smart Effector
            ;*** If you are using axis compensation, put the figures in the following command
            M556 S78 X0 Y0 Z0 ; Axis compensation here
            M208 S1 Z-0.2 ; set minimum Z
            T0 ; select first hot end
            ; M117 Use https://configurator.reprapfirmware.org/ to set up your printer config
              The M552 response shows that the Duet failed to get an IP address. Do you have the Duet connected to your router, or directly to a PC or laptop?
              mfisher103undefined duetnoviceundefined 3 Replies Last reply Reply Quote 0
                mfisher103 @dc42
                @dc42 It is connected to a powered land line.
                  mfisher103 @dc42
                  @dc42 Question....can the computer I am using be in Wifi? or does it have to be in a land line?
                    Phaedrux Moderator @mfisher103
                    @mfisher103 said in Unable to Connect Duet Ethernet via Web Interface:
                    It shouldn't matter as long as you're both connected to the same router.
                      dc42 administrators @mfisher103
                      I'm sorry, I don't understand what you mean by "powered land line".
                        mfisher103 @dc42
                        @dc42 I think the problem was that the computer I was using was on WiFi....I ran land lines to the computer and the Duet and it's working now...
                        • duetnoviceundefined
                          duetnovice @dc42
                          @dc42 i also did the steps but its not working either
