Artefacts on walls
3.4k
    Veti
    Anybody got a suggestion where these could come from? you can not realy feel them but can see it in light reflections.
    the top one is printed at 80mm/s the bottom one at 40mm/s
    my printer is a corexy (hevo fusion) with linear rails.
      There's been a few good threads about troubleshooting issues like this. Search for vertical ribbing, or banding, or waves.
      Usually it's a mechanical issue. Something loose. Belts not meshing with pulleys smoothly. Toothed side of belt running on a smooth idler. Oblong pulley, or not running on center. Bad bearing. those are the things I would check first.
        DocTrucker
        Here's my recent thread:
        https://forum.duet3d.com/topic/9222/part-wobble-formerly-need-gates-gt2-belt/23
        Mostly mechanical, but in my case motor choice/swap helped. I've not finished yet. Dampers, pulleys, and tl smoothers (note: I'm running v0.6/0.8.5, v2) are due over the next few days.
          DocTrucker
          Looks like the wobble on your parts are about stepper major step size?
          Presume a Duet Ethernet/WIFI?
            Veti
            Its a duet maestro.
            it could be the stepper major size.
            i will try swapping my x and y stepper motors with the z ones.
              DocTrucker
              Alongside the already popular polymer dampers there is also mass inertial dampers to consider. That said I've not heard of these being used on printers yet and would limit the max accelerations the steppers could achieve without stalling. Whether that effects the accelerations and instant speeds used in printing is another question.
                DocTrucker
                Are you already running on the current limit of the Maestro or 80% of stepper max current whichever is smaller?
                  Veti
                  I am currently running my steppers at 67%
                  I can give 80% a try.
                    Veti
                    after a long time of testing and adjusting
                    chaining to different motors -> Still there.
                    switching to 16 tooth pulley -> Still there but small ripple distance decrease
                    using Spreadcycle instead of Stealthchop -> Still there , just more motor noise
                    chaning all toothed idler to smooth ones and twisting the belt -> Still there.
                    modifying some parts for better belt alignment -> Still there.
                    upping the current -> Still there
                    relubricating all the rails -> Still there.
                    i then rotated the part by 45 degrees. this causes the part to be printed by only one motor at a time.
                    -> The ripples decreased in distance.
                    So i guess i will some 0.9 degrees steppers and combine them with a 16 tooth pulley and see if that helps
                      What are the motors?
                        Veti
                        Model 17HS8401
                        Step Angle 1.8 (deg)
                        Motor Length (mm) 48
                        Rated Current (A) 1.8
                        Phase Resistance (Ohm) 1.8
                        Phase Inductance (mH) 3.2
                        Holding Torque (N.cm) 52
                        Detent Torque (N.cm) 2.6
                        Rotor Inertia (g.cm2) 68
                        Lead Wire (No) 4
                        Motor Weight (g) 400
                          What type of printer is it, which firmware version are you running, and what is your extruder steps/mm ?
                            Veti
                            its a Hypercube Fusion CoreXY with linear rails.
                            Duet Maestro with Firmware Version: 2.02(RTOS) (2018-12-24b1)
                            Extruder Steps are 415 for Bondtech BMG
                              I'm not and expert on CoreXY machines. I've seen a number of threads about similar artefacts on CoreXY machines. AFAIR the pitch of the artefacts generally matches the belt pitch, and the cause is generally friction. Using non-toothed idlers may also contribute.
                              Until you resolve this issue, I suggest you use spreadCycle mode for the X and Y drivers, also run them at higher rather than lower current.
                                Veti
                                the steppers havent arrived yet.
                                but this seems to be a common problem
                                see these benchys from a prusa.
                                https://youtu.be/FAXUjZZER5E?t=563
                                undefined 1 Reply Last reply 17 Mar 2019, 17:08 Reply Quote 0
                                  Phaedrux Moderator @Veti
                                  @veti said in Artefacts on walls:
                                  That looks like plain old ringing to me though.
                                    Veti
                                    ok my 0.9 stepper motors arrived.
                                    Looks ok from this angle
                                    Same Cube, different angle, but still a lot better than before
                                    However now i am getting layer shifts (as seen at the bottom layer), so i have to do some more tuning.
                                      Veti
                                      the layer shifts were due to the lowered stealthchop -> spreadcycle switchover.
                                      its not that important but i think it would be more consistent to specify the V Parameter in M569 as mm/s rather than clock cycles
                                      undefined 1 Reply Last reply 22 Mar 2019, 09:06 Reply Quote 0
                                        dc42 administrators @Veti
                                        Then we would need to reprogram the stepper drivers when you set the steps/mm. So I compromised with setting the TPWMTHRS value but reporting the corresponding speed too. Also bear in mind that these are belt speeds, which for CoreXY, delta. SCARA| etc. printers are not the same as head speeds.
                                          Veti
                                          so i bought an ender 3 on sale and was surprised to find the same artefacts on the wall. I have not done much tuning on the machine yet.
                                          This is using a board with marlin 2.0
                                          so am i beeing to picky and there are inherent artefacts for 3d printing?
