    Artefacts on walls
    3.4k
    • DocTruckerundefined
      DocTrucker
      Looks like the wobble on your parts are about stepper major step size?
      Presume a Duet Ethernet/WIFI?
      • Vetiundefined
        Veti
        Its a duet maestro.
        it could be the stepper major size.
        i will try swapping my x and y stepper motors with the z ones.
          DocTrucker
          Alongside the already popular polymer dampers there is also mass inertial dampers to consider. That said I've not heard of these being used on printers yet and would limit the max accelerations the steppers could achieve without stalling. Whether that effects the accelerations and instant speeds used in printing is another question.
            DocTrucker
            Are you already running on the current limit of the Maestro or 80% of stepper max current whichever is smaller?
            • Vetiundefined
              Veti
              I am currently running my steppers at 67%
              I can give 80% a try.
              • Vetiundefined
                Veti
                after a long time of testing and adjusting
                chaining to different motors -> Still there.
                switching to 16 tooth pulley -> Still there but small ripple distance decrease
                using Spreadcycle instead of Stealthchop -> Still there , just more motor noise
                chaning all toothed idler to smooth ones and twisting the belt -> Still there.
                modifying some parts for better belt alignment -> Still there.
                upping the current -> Still there
                relubricating all the rails -> Still there.
                i then rotated the part by 45 degrees. this causes the part to be printed by only one motor at a time.
                -> The ripples decreased in distance.
                So i guess i will some 0.9 degrees steppers and combine them with a 16 tooth pulley and see if that helps
                  What are the motors?
                  • Vetiundefined
                    Veti
                    Model 17HS8401
                    Step Angle 1.8 (deg)
                    Motor Length (mm) 48
                    Rated Current (A) 1.8
                    Phase Resistance (Ohm) 1.8
                    Phase Inductance (mH) 3.2
                    Holding Torque (N.cm) 52
                    Detent Torque (N.cm) 2.6
                    Rotor Inertia (g.cm2) 68
                    Lead Wire (No) 4
                    Motor Weight (g) 400
                      What type of printer is it, which firmware version are you running, and what is your extruder steps/mm ?
                      • Vetiundefined
                        Veti
                        its a Hypercube Fusion CoreXY with linear rails.
                        Duet Maestro with Firmware Version: 2.02(RTOS) (2018-12-24b1)
                        Extruder Steps are 415 for Bondtech BMG
                          I'm not and expert on CoreXY machines. I've seen a number of threads about similar artefacts on CoreXY machines. AFAIR the pitch of the artefacts generally matches the belt pitch, and the cause is generally friction. Using non-toothed idlers may also contribute.
                          Until you resolve this issue, I suggest you use spreadCycle mode for the X and Y drivers, also run them at higher rather than lower current.
                          • Vetiundefined
                            Veti
                            the steppers havent arrived yet.
                            but this seems to be a common problem
                            see these benchys from a prusa.
                            https://youtu.be/FAXUjZZER5E?t=563
                              Phaedrux Moderator @Veti
                              @veti said in Artefacts on walls:
                              That looks like plain old ringing to me though.
                              • Vetiundefined
                                Veti
                                ok my 0.9 stepper motors arrived.
                                Looks ok from this angle
                                Same Cube, different angle, but still a lot better than before
                                However now i am getting layer shifts (as seen at the bottom layer), so i have to do some more tuning.
                                • Vetiundefined
                                  Veti
                                  the layer shifts were due to the lowered stealthchop -> spreadcycle switchover.
                                  its not that important but i think it would be more consistent to specify the V Parameter in M569 as mm/s rather than clock cycles
                                    dc42 administrators @Veti
                                    Then we would need to reprogram the stepper drivers when you set the steps/mm. So I compromised with setting the TPWMTHRS value but reporting the corresponding speed too. Also bear in mind that these are belt speeds, which for CoreXY, delta. SCARA| etc. printers are not the same as head speeds.
                                    • Vetiundefined
                                      Veti
                                      so i bought an ender 3 on sale and was surprised to find the same artefacts on the wall. I have not done much tuning on the machine yet.
                                      This is using a board with marlin 2.0
                                      so am i beeing to picky and there are inherent artefacts for 3d printing?
                                        I can think of three likely causes of artefacts like that, that go all the way across the face (not just at the leading edge, which is symptomatic of ringing):
                                        1. Belt issues. If that's the case then the pitch will be related to the belt tooth pitch and will not vary with layer height or extrusion width. A possible cause is the use of smooth idlers instead of toothed ones.
                                        2. Motor issues (least likely). In this case the pitch of the artefacts will be a multiple of full motor steps, most likely it will be 1, 2 or 4 full steps.
                                        3. Extruder issues. In this case then the pitch will decrease if you increase layer height or extrusion width. A possible cause is the use of an ungeared extruder with low steps/mm. Remedies include increasing extruder microstepping, changing from a 1.8deg to a 0.9deg motor, or changing to a geared extruder.
