DueUI: An Alternate Web Interface
DueUI
12
65
11.1k
    gtj0 @nilrog
    @nilrog said in [Preview] DueUI: An Alternate Web Interface:
    @gtj0 Yes,that is what I meant...perhaps I should have made my case clearer...
    But on the other hand, if you have the printer on a closed network, it would be rare if you would access DueUI from a browser that has internet access. I can understand why it is implemented this way, at least in this initial state, but removing that limitation in the future would be nice. Especially since Duet3D itself doesn't have this limitation.
    I can fix that but I wanted to make sure it was actually an issue before I did as it does require some work and coordination with the DWC.
    undefined 1 Reply Last reply 7 Mar 2019, 08:51 Reply Quote 0
      nilrog @gtj0
      @gtj0 said in [Preview] DueUI: An Alternate Web Interface:
      There is no rush, at least from my side, it will be some time before I can start playing with DueUI for real. But i'm looking forward to being able to customize the UI once I have the Duet3d and all the rest fully working.
        appjaws
        downloaded the file to my kindle fire and installed it but when I click on the app icon I get the start page to input the printers address, then press go and all I get is a blank screen.
        Any thoughts?
        appjaws - Core XYUV Duet Ethernet Duex5
        firmware 3.5.0-rc.4 Web Interface 3.5.0-rc.4
        Ormerod 1-converted to laser engraver, Duet wifi
        OpenSCAD version 2024.03.18
        Simplify3D 5.1.2
        undefined 1 Reply Last reply 7 Mar 2019, 14:12 Reply Quote 0
          gtj0 @appjaws
          @appjaws said in [Preview] DueUI: An Alternate Web Interface:
          Any thoughts?
          Did you install DueUI on the printer?
          Did you specify the full URL? http://<your_printer>/dueui.html
          The next release won't require you to do this.
          If you unchecked the "Show this screen at startup" button, you'll have to uninstall and re-install to get back to the welcome screen, or go to Settings, Applications, select the app and clear it's data. The next release will have a way to do that from the DueUI settings and will also have better feedback of what went wrong.
            boldnuts
            Try to install your app on my Asus tablet, getting a parsing error?
            undefined 1 Reply Last reply 9 Mar 2019, 21:13 Reply Quote 0
              gtj0 @boldnuts
              @boldnuts said in [Preview] DueUI: An Alternate Web Interface:
              More detail?
              Screenshot?
              When does the issue happen?
              Can you run the web version OK?
                thwe
                1. How can I change the design of the "choose" buttons (eg distance between the buttons)?
                2. Can you put a "refresh" button in the menubar bottom (next to the two buttons "fullscreen" and "set up")?
                3. Can the web application be started immediately in full screen mode as soon as I call the page (like if you click on the small button "fullscreen" on the bottom right)?
                Thomas
                undefined 1 Reply Last reply 10 Mar 2019, 13:58 Reply Quote 0
                  gtj0 @thwe
                  @thwe said in [Preview] DueUI: An Alternate Web Interface:
                  In the current version, you can't but I'm almost finished with moving from jQuery-UI to Bootstrap and the spacing will be easier to control.
                  1. Can you put a "refresh" button in the menubar bottom (next to the two buttons "fullscreen" and "set up")?
                  Will do.
                  1. Can the web application be started immediately in full screen mode as soon as I call the page (like if you click on the small button "fullscreen" on the bottom right)?
                  Early on I tried to add an option to the settings that automatically requested fullscreen when the app started but it appears that fullscreen can only be requested by a user action. I guess this is to prevent malicious websites from automatically putting the browser in fullscreen mode without user consent.,
                  undefined 1 Reply Last reply 10 Mar 2019, 14:33 Reply Quote 0
                    devleon @gtj0
                    Woop woop! That's awesome to hear. Looking forward to it!
                      thwe
                      Unfortunately, I have now discovered a problem that could possibly be critical:
                      To measure my bed, I run a macro in which at 5 points a "G30 S-"1 is started - the results then readable on the DWC in the "G-Code Console".
                      Without a connection of my tablet, ie without a connection from the DueUI to the Duet, the result looks like this:
                      When I start the DueUI without any operation of my printer on the DueUI, the measurement results suddenly look like this:
                      Obviously there are any overloads of the Duet caused by the DueUI?
                      Thomas
                      undefined 1 Reply Last reply 10 Mar 2019, 18:45 Reply Quote 0
                        gtj0 @thwe
                        @thwe Hmmm. I'll look into it.
                          gtj0
                          I'm starting to look at this issue now.
                          As I've been using DueUI myself, I'm also thinking about a height map viewer and the ability to create macros that can use values from the status messages.
                            thwe
                            My new designed surface of the DueUI:
                            video of my new DueUI surface
                            Thomas
                            Phaedruxundefined undefined 2 Replies Last reply 14 Apr 2019, 18:04 Reply Quote 2
                              Phaedrux Moderator @thwe
                              @thwe That looks great.
                                gtj0 @thwe
                                @thwe That's fantastic. If you'd like to share your config I'd love to add it to the DueUI wiki and if you're OK with it, I'd like to link to your video from the README (giving you full credit of course).
                                Is there anything that you'd wished was easier?
                                undefined 1 Reply Last reply 15 Apr 2019, 15:47 Reply Quote 0
                                  thwe @gtj0
                                  @gtj0 I like to share the config file, here it is:
                                  dueui_config.txt
                                  Attention:
                                  • Rename the file after download -> make a *.json file from the *.txt file
                                  • The positions are optimized on my 10 " tablet and may not fit on other screens.
                                  • Furthermore: all the buttons deposited commands and values and arrows are necessary to my taste -> own adjustments.
                                  ... and you are welcome to link the video 👍
                                  The only thing I miss at the moment is the display/value of the extruder. Otherwise I have to work intensively with it first.
                                  Thomas
                                  undefined 1 Reply Last reply 15 Apr 2019, 17:35 Reply Quote 1
                                    gtj0 @thwe
                                    @thwe said in DueUI: An Alternate Web Interface:
                                    dueui_config.txt
                                    Attention:
                                    Cool, thanks!
                                    "display/value of the extruder" could you explain a little more?
                                    undefined 1 Reply Last reply 16 Apr 2019, 04:51 Reply Quote 0
                                      thwe @gtj0
                                      @gtj0 yes, following what i mean:
                                      another thing: is it possible to add a space between the menu tabs (at the bottom)?
                                      Thomas
                                      undefined 1 Reply Last reply 17 Apr 2019, 02:11 Reply Quote 0
                                        gtj0 @thwe
                                        @thwe For the E position I think you need to use ${status.coords.extr[0]} in the "value" field for that widget.
                                        There isn't a way to add the spaces now but I can add that capability in a few days. I've also got some other fixes that need to be released as well.
                                        undefined 1 Reply Last reply 20 Apr 2019, 15:25 Reply Quote 0
                                          thwe @gtj0
                                          @gtj0 said in DueUI: An Alternate Web Interface:
                                          @thwe For the E position I think you need to use ${status.coords.extr[0]} in the "value" field …
                                          That was it 👍
                                          Thomas
