    DueUI: An Alternate Web Interface
    DueUI
    12
    65
    11.1k
    • thweundefined
      thwe
      1. How can I change the design of the "choose" buttons (eg distance between the buttons)?
      2. Can you put a "refresh" button in the menubar bottom (next to the two buttons "fullscreen" and "set up")?
      3. Can the web application be started immediately in full screen mode as soon as I call the page (like if you click on the small button "fullscreen" on the bottom right)?
      Thomas
      • gtj0undefined
        gtj0 @thwe
        @thwe said in [Preview] DueUI: An Alternate Web Interface:
        In the current version, you can't but I'm almost finished with moving from jQuery-UI to Bootstrap and the spacing will be easier to control.
        1. Can you put a "refresh" button in the menubar bottom (next to the two buttons "fullscreen" and "set up")?
        Will do.
        1. Can the web application be started immediately in full screen mode as soon as I call the page (like if you click on the small button "fullscreen" on the bottom right)?
        Early on I tried to add an option to the settings that automatically requested fullscreen when the app started but it appears that fullscreen can only be requested by a user action. I guess this is to prevent malicious websites from automatically putting the browser in fullscreen mode without user consent.,
        devleonundefined 1 Reply Last reply Reply Quote 0
        • devleonundefined
          devleon @gtj0
          @gtj0 said in [Preview] DueUI: An Alternate Web Interface:
          Woop woop! That's awesome to hear. Looking forward to it!
          • thweundefined
            thwe
            Unfortunately, I have now discovered a problem that could possibly be critical:
            To measure my bed, I run a macro in which at 5 points a "G30 S-"1 is started - the results then readable on the DWC in the "G-Code Console".
            Without a connection of my tablet, ie without a connection from the DueUI to the Duet, the result looks like this:
            When I start the DueUI without any operation of my printer on the DueUI, the measurement results suddenly look like this:
            Obviously there are any overloads of the Duet caused by the DueUI?
            Thomas
            • gtj0undefined
              gtj0 @thwe
              @thwe Hmmm. I'll look into it.
              • gtj0undefined
                gtj0
                I'm starting to look at this issue now.
                As I've been using DueUI myself, I'm also thinking about a height map viewer and the ability to create macros that can use values from the status messages.
                • thweundefined
                  thwe
                  My new designed surface of the DueUI:
                  video of my new DueUI surface
                  Thomas
                  Phaedruxundefined gtj0undefined 2 Replies Last reply Reply Quote 2
                    Phaedrux Moderator @thwe
                    @thwe That looks great.
                    • gtj0undefined
                      gtj0 @thwe
                      @thwe That's fantastic. If you'd like to share your config I'd love to add it to the DueUI wiki and if you're OK with it, I'd like to link to your video from the README (giving you full credit of course).
                      Is there anything that you'd wished was easier?
                      thweundefined 1 Reply Last reply Reply Quote 0
                      • thweundefined
                        thwe @gtj0
                        @gtj0 I like to share the config file, here it is:
                        dueui_config.txt
                        Attention:
                        • Rename the file after download -> make a *.json file from the *.txt file
                        • The positions are optimized on my 10 " tablet and may not fit on other screens.
                        • Furthermore: all the buttons deposited commands and values and arrows are necessary to my taste -> own adjustments.
                        ... and you are welcome to link the video 👍
                        The only thing I miss at the moment is the display/value of the extruder. Otherwise I have to work intensively with it first.
                        Thomas
                        gtj0undefined 1 Reply Last reply Reply Quote 1
                        • gtj0undefined
                          gtj0 @thwe
                          @thwe said in DueUI: An Alternate Web Interface:
                          dueui_config.txt
                          Attention:
                          Cool, thanks!
                          "display/value of the extruder" could you explain a little more?
                          • thweundefined
                            thwe @gtj0
                            @gtj0 yes, following what i mean:
                            another thing: is it possible to add a space between the menu tabs (at the bottom)?
                            Thomas
                            • gtj0undefined
                              gtj0 @thwe
                              @thwe For the E position I think you need to use ${status.coords.extr[0]} in the "value" field for that widget.
                              There isn't a way to add the spaces now but I can add that capability in a few days. I've also got some other fixes that need to be released as well.
                              • thweundefined
                                thwe @gtj0
                                @gtj0 said in DueUI: An Alternate Web Interface:
                                @thwe For the E position I think you need to use ${status.coords.extr[0]} in the "value" field …
                                That was it 👍
                                Thomas
