    Tutorial - running Duet Wifi 2 in Access Point Mode ?
    4.6k
    • fcwiltundefined
      fcwilt
      I'm confused.
      To connect the Duet to a "hotspot" you need to use "client" mode (M552 S1).
      In this mode you use M587 and M588 to maintain the list of access point SSIDs you wish to connect to.
      To allow a client device to connect directly to your Duet you need to use "access point" mode (M552 S2).
      In this mode you use M589 to configure the Duet as an access point".
      Which are you trying to do?
      Phaedruxundefined SputnikOC3dundefined 2 Replies Last reply Reply Quote 0
        Phaedrux Moderator @fcwilt
        @fcwilt he's been trying both.
        • SputnikOC3dundefined
          SputnikOC3d @fcwilt
          @fcwilt
          thank you for your reply. Neither mode - client not access point is working for me. Its stuck in client mode and connecting ONLY to a network that is non functioning [ other than it broadcasting an SSID and taking connections its dns is not functioning ] ... Im trying to get this duet board to operate in either Access Point Mode or ... connect to my phones Hotspot - it refuses to do either
            Can you confirm which firmware and wifi server you're running?
              SputnikOC3d
              cant get it loaded to tell you - but 1.21 main firmware - wifi module - nto sure let me look at my latest download files
                SputnikOC3d
                Correction - Im on duet FW 2.0 iirc as it has the RTOS functionality and wifi server 1.21 - specifically what rev of wifi Im not exactly sure - the android app tells me 1.21
                • fcwiltundefined
                  fcwilt @SputnikOC3d
                  @sputnikoc3d said in Tutorial - running Duet Wifi 2 in Access Point Mode ?:
                  @fcwilt
                  In your last example you used M552 S1 before configuring the list of SSIDs. I think you would need to have M552 S1 after the list is correct.
                  Try this:
                  M552 S0
                  M558 S"*"
                  M557 S"desired_ssid" P"ssid_password"
                  M552 S1
                  That has always worked for me when setting a Duet as a WiFi client.
                  SputnikOC3dundefined 2 Replies Last reply Reply Quote 1
                    SputnikOC3d @fcwilt
                    @fcwilt
                    ok gret - TY - gunna give this a whirl ... more to follow
                      SputnikOC3d @fcwilt
                      @fcwilt said in Tutorial - running Duet Wifi 2 in Access Point Mode ?:
                      @fcwilt
                      Try this:
                      M552 S0
                      M558 S"*"
                      M552 S1
                      tried this variant - still connecting to the old network [ im leaving it on only because it lets me know the wifi module on the board is doing "something" - otherwise the led just flashes and never blinks and then goes dark and stays that way ]
                      M550 PZaribo220 ; Set machine name
                      M551 Pmehs ; Set password
                      M552 S0 ; Disable network
                      G4 1000 ; Pause Machine for 1000 milliseconds
                      M588 S"EC24EA" ; Flush all known networks
                      M588 S"EC24F0" ; Flush all known networks
                      ;M589 S"DuetWiFi" P"whatevr" I192.168.1.101 ; AccessPointMode
                      ;M587 S"EC24EA" P"nope" ; Configure access point. Connect to Cox Wifi at 2.4Ghz
                      M587 S"SM-N920PC3B" P"nope2" ; Configure access point. Connect to Android Phone Hotspot
                      ;M587 S"SMA iPad" P"nope" ; Configure access point. Connect to Apple iPad Phone Hotspot
                      M552 S1 ; Enable network
                      M586 P0 S1 ; Enable HTTP
                      M586 P1 S0 ; Disable FTP
                      M586 P2 S0 ; Disable Telnet
                        You may want to try upgrading your firmware and wifi server to the 2.02 release. I think there was a fix for something for the access point mode. Check the release notes.
                        You should be able to put the bin files on the SD card and add the update command to the config.g. but it really would be easier if you could get a console up.
                        SputnikOC3dundefined 1 Reply Last reply Reply Quote 0
                          SputnikOC3d @Phaedrux
                          @phaedrux said in Tutorial - running Duet Wifi 2 in Access Point Mode ?:
                          That sounds promising. There is no "Panel" option for the foreseeable future. How could I get it to update the firmware if I had the files on the SD Card ?
                            https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Fallback_procedure_Num_1
                            The procedure described assumes you have console access, but you might be able to include the M997 S0 in config.g to be run at startup. Then there is another command to install the wifi server. You'll also have to update the DWC files in /www.
                              SputnikOC3d
                              Can you actually call macros from the config.g via the standard M98 syntax ?
                                SputnikOC3d
                                well i gave the macro thing a shot sorta - a little different aspect than we were discussing exactly but ....
                                I created a -- macro -- file in the sys dir/ as follows - ANDROID_HOTSPOT.g
                                ; Android Hotspot - macro to set up access to Android Phone Hotspot test Wifi network
                                M552 S0
                                G4 P1000
                                M587 S"SM-N920PC3B" P"buzzzanga" ; Configure access point. Connect to Android Phone Hotspot
                                M587
                                M552 S1
                                M552
                                then in config.g I have ....
                                M551 P9662 ; Set password
                                M587 S"SM-N920PC3B" P"buzzinga" ; Configure access point. Connect to Android Phone Hotspot
                                M98 PANDROID_HOTSPOT.g
                                knowing that it will just execute the standard config.g and ignore my M588 and M587 gcode - i thought maybe calling some gcode from a macro file might change its stubborn mind ...
                                This is at the point of being infuriating and dumb - this should NOT be this hard to make these types of changes to a configuration ...
                                Additionally I KNOW it will end up being somethign rather stupid and easy to fix
                                  Phaedrux Moderator @SputnikOC3d
                                  Should work, yup.
                                  May need to specify the full path for it. Are you putting the macros in the macros folder or into the sys folder?
                                  0:/sys/macro.g or what have you
                                    Is the light on the wifi module coming on?
                                    • fcwiltundefined
                                      fcwilt @SputnikOC3d
                                      @sputnikoc3d
                                      Now that I think about it I've believe I have always executed the gcode I posted using the USB connection just to get the WiFi connection going so I could then create the various configuration files.
                                      I've don't think I have ever actually tried it from within config.g OR as a macro executed via the DWC.
                                        Should work, yup.
                                        i put this one in the SYS folder ...
                                        when i go to open and edit the macros in Notepad++ in the /macros folder - they dont appear to have a file extension on them, and I am not savvy about using notepad++ and creating a file with NO .extension on it. and since the default path seems to be /sys for the M98 command - i created a .g macro file on /sys ... i didnt specify the full path in the config.g M98 command either
                                        it didnt work - nothing does
                                          SputnikOC3d @fcwilt
                                          @sputnikoc3d
                                          got a friend who executes a stored macro almost verbatim of the one i Just posted [ because I essentially stole his ] - that he runs off the panelDue when needing to connect at a different locale than HOME.
                                            SputnikOC3d
                                            I feel as if the 1st order of business to tackle this issue is - stopping the Duet from connecting to the OLD network. aka - flushing out the stored settings on this indestructible eprom memory ....
                                            M588 from config.g doesnt work - what other options for this are avail ?
                                            remove sd card and do a full reset - reinsert sd card and reboot ? how does that perhaps work - and ... I will say again - this is in-f'ing-sane to have to do THIS ...
                                            If I wanted to hook the printer up to a USB cable... muhhh NVM ....
