    G-code Syntax Highlighting in Text Edit Windows
    Duet Web Control wishlist
    2.0k
      For example:
      This is a screen shot of Atom on MacOS. It's not the greatest color scheme, but you get the idea.
      Line numbering would be nice as well.
      • Snimaxundefined
        Snimax
        Im using Visual Studio Code, there is an extension nc-gcode which brings syntax highlighting in a similar fashion.
        Example
        • snoozerundefined
          snoozer
          There is also Notepad++ which has a few definitions for syntax highlighting here.
          http://docs.notepad-plus-plus.org/index.php/User_Defined_Language_Files
          Jan
          Regards Jan
          My Printers:
          #1 Prusa i3 MK3 kit all stock (Retired)
          #2 Rat Rig V-Core Core-XY (Almost finished but fully usable)
          My Experiments:
          https://www.thingiverse.com/snoozer17/designs
            Atom is using nc-gcode as well.
            NotePad++ doesn't have a Mac version sadly. Hence using Atom.
            But it would be nice to get the highlighting in the browser without having to download it.
            I had tried using FTP to interface with the Duet since it will launch your local editor to edit the files, but I was having problems with FTP uploads not actually completing even though they claimed they had. It would just result in a correctly named empty file.
            • snoozerundefined
              snoozer
              On a Mac you should be able to use vim/vi in a terminal, there is syntax definitions for that as well.
              Jan
              Regards Jan
              My Printers:
              My Experiments:
                Right. I have Atom for that on the Mac side. It's fine. But I'd like highlighting when I'm editing a macro live on the Duet in the DWC.
                • snoozerundefined
                  snoozer
                  Oh I see, I guess that is a server side application which would require the highlighting to be implemented on the DWC end. I have not used ftp on the Duet before, just tried but have not been able to DL or UL files. Not done any troubleshooting yet.
                  Jan
                  Regards Jan
                  My Printers:
                  My Experiments:
                    Phaedrux Moderator @snoozer
                    @snoozer You'll need to ensure the FTP client is set to only use a single concurrent connection.
                    • Snimaxundefined
                      Snimax
                      Ah, I interperated your question as you were looking for a replacement for Atom in ms windows. Some highlighting in the web editor would be a nice feature.
                        dc42 administrators @Snimax
                        @snimax said in G-code Syntax Highlighting in Text Edit Windows:
                        This is for chrishamm to answer; however, implementing syntax highlighting is I think much harder in HTML/CSS/javascript than it is in a normal program or an app.
                        • snoozerundefined
                          snoozer
                          I am unable to put or get files with FTP. I can log in but put and get fails with the "PORT failed" error. Usually a sign that the client needs to use passive mode or NAT is an issue yet I am in the same subnet without firewall. I am sure its off topic just here now, I have a look through the forum what I find.
                          Jan
                          Regards Jan
                          My Printers:
                          My Experiments:
                            Phaedrux Moderator @dc42
                            @dc42 a quick google for in browser syntax highlighting brought up a few promising options.
                            https://prismjs.com
                            wilrikerundefined 1 Reply Last reply Reply Quote 1
                              dc42 administrators @snoozer
                              @snoozer said in G-code Syntax Highlighting in Text Edit Windows:
                              Jan
                              The FTP server in RRF only supports one connection. If your FTP client defaults to opening 2 connections, reconfigure it to use just one.
                              • wilrikerundefined
                                wilriker @Phaedrux
                                @phaedrux said in G-code Syntax Highlighting in Text Edit Windows:
                                https://prismjs.com
                                Just found the same thing. It does have GCode listed as supported language and there also exists Vue Prism Editor to integrate it into the new UI based on Vue.
                                Manuel
                                My Tool Collection
                                • bbergerundefined
                                  bberger
                                  I just created a pull request..
                                  https://github.com/chrishamm/DuetWebControl/pull/226
                                  Based on PrismJS. The only one I could find that reliably highlights gcode. Also is pretty lightweight.
                                  Needs some testing though and I also propose a UI setting to turn it on/off, but I don't have the means to translate it to all the supported languages.
                                  Doesn't do much besides syntax highlighting based on file extensions, but at least to me it's already a great help to have comments greyed out and commands/params highlighted..
                                  If there's a full tree of (maintained) RRF gcodes acailable then maybe CodeMirror could be an option for a more polished WebIDE.
                                  I also think a slight rework of the FileEditor would be helpful (custom Route instead of the Dialog so a page refresh or the back button doesn't break the Dialog), but that's a topic for another day..
                                  If there's interest I'm open to do some slight refactoring of that feature to make it work.
                                  bernhardberger opened this pull request in chrishamm/DuetWebControl
                                  closed Feature/prism #226
                                    Phaedrux Moderator @bberger
                                    @bberger Awesome!!
