Solved Heating fault on heater 1, temperature excursion exceeded 15.0°C
Hello again,
the problem is that the hot end increase the temperature really fast and don't stop if it matches the set print temperature.
I took a look at the wiki but I didn't understand it that much.
I set up 180°C it passes the 180°C and goes higher and higher until I pushed the emergency button. it increases in maybe 15 seconds to 285°C.Some information about the printer:
Tronxy X5S
Duet 2 Wifi v1.04
PanelDue 7i
PSU 24V
Firmware 1.22.1If someone could help with that would be very kind.
Kind regards
AimRabbit -
Is the heater cartridge for 12v or 24v?
@phaedrux said in Heating fault on heater 1, temperature excursion exceeded 15.0°C:
I think its for 12V. Is there something that I can do?
@aimrabbit said in Heating fault on heater 1, temperature excursion exceeded 15.0°C:
If you are running a 12V heater cartridge with 24V power: don't! Some may tell you that you can set a PWM limit, but it's still a serious fire risk. Buy a 24V heater cartridge.
You can tell if it's 12V or 24V by measuring the resistance. For a typical 35W to 40W heater, a resistance of about 4 ohms means 12V, and about 16 ohms means 24V.
@dc42 oh ok I think than I have also to send back the chimera that i bought
Thanks a lot I order it right now -
Thanks a lot I order it right nowAsk E3D or their distributor if you can just swap the heater cartridge they supplied with the Chimera for a 24V one.
@dc42 did that also infect the heating bed? only to be sure that I don't must order a new one too.
@dc42 said in Heating fault on heater 1, temperature excursion exceeded 15.0°C:
I will do that thank you a lot.
There are no words to describe how thankful I'm for your hint. I make some research and found that "2x30W Heater cartridges (12V/24V)" I think that means it supports both so i can change the hot end and kick that tronxy shit away.
Hopefully I get my first print after that.
