    What exactly does PID tuning do?
    3.4k
      A Former User
      For the home gamer water to a propper boil, and water filled with ice cubes are the two easiest to recreate temperature references which will be close to 100C and 0C. Just make sure you don't touch the container or ice with the actual probe. But not super usefull for hot end use as its only half to a third of the range, but still, it'll give you some idea.
      Kapton tape to hold the thermocouple to the hotend and giving it some time to stabilize ought give a good reading, provided the temperature the read by the thermistor isn't oscillating.
        Is it really a thermocouple you are using, connected to a thermocouple daughter board that is plugged into the Duet, or is it the more common thermistor? It it's a thermistor, then you may just be using the wrong settings in config.g.
        crchisholmundefined 1 Reply Last reply Reply Quote 0
        • crchisholmundefined
          crchisholm @dc42
          @dc42 said in What exactly does PID tuning do?:
          I am using a k-type thermocouple on a multi-meter with a temporature function and a thermocouple plug.
          The problem is worse than I thought. I tested the thermocouple/multimeter with boiling water and it was within a couple degrees of 100c. I taped the thermocouple to the heat block and when DWC showed 235c , the thermocouple showed 160c My neighbor has another thermocouple device and we tried with that and got essentially the same reading (157-165)
          I am not using the thermocouple daughter board as I have zero confidence that it will be significantly different that the three devices I have tried. Is their reason to believe otherwise? Also the fact that I have to print PLA at such a high temp seems to confirm that the temp reported in DWC is not accurate.
          Could it be that there is a setting somewhere that does not correctly identify the Titan Aero thermister?
          @Phaedrux - Also the Titan Areo is the real deal....not a knock-off
            A Former User
            I think dc42 meant to ask if you had a thermcouple on the hotend, or basically establish which thermistor you have, and if the settings are correct?
              crchisholm @A Former User
              @bearer I am not using a thermocouple/daughter board on the hotend. I am using the thernmistor that came with the Titan Aero. If there is a setting that should be tweaked to accomodate that arrangment, I have not done so. That certainly could be the issue.
              @dc42 I may have miss understood your question
              Do I really need to go to the Duet daughter board to get anything more accurate than a 65+ inaccuracy? If I have to I will, but I guess I thought the Titan Aero would work as supplied.
              How do I set the firmware to work with the Titan Aero thermistor? Or that just not a realistic option.
              mudcruzrundefined 1 Reply Last reply Reply Quote 0
              • mudcruzrundefined
                mudcruzr @crchisholm
                @crchisholm Check your M305 values in your config.g, I have a Titan Aero and I've never had the slightest reason to suspect the accuracy of the E3D thermistor (It is the cartridge type you have, yes?) My settings are:
                M305 P1 T100000 B4388 C7.06e-8 R2200 ; Set thermistor + ADC parameters for heater 1
                But I have a Maestro, for your WiFi I believe the R parameter should be changed to R4700. It should then look like this:
                M305 P1 T100000 B4388 C7.06e-8 R4700
                Otherwise, please post your config.g to let us have a look at it.
                Alan
                  @mudcruzr I think your B values are out of date. That was correct for firmware 1.16 and earlier. According to the E3D documentation the values for the Duet Wifi and firmware 1.17 and later should be:
                  M305 P1 T100000 B4725 C7.06e-8 R4700
                  There was a mistake in the configurator that was still using the old values.
                  @crchisholm So check your config.g for the heater section and compare your M305 P1 commands with the one above. A wrong value there would definitely explain the difference in temperature readings.
                    crchisholm @mudcruzr
                    I made the change but not much difference config.g attached.
                    ; generated by RepRapFirmware Configuration Tool v2 on Fri Feb 01 2019 16:04:24 GMT-0500 (Eastern Standard Time)
                    M667 S1 ; Select CoreXY mode
                    M550 P"Core XY" ; Set machine name
                    M552 S1 ; Enable network
                    ; M587 S"BHNDVW3201B4B28" P"3c5d116a" ; Configure access point. You can delete this line once connected
                    M586 P0 S1 ; Enable HTTP
                    M586 P1 S0 ; Disable FTP
                    M586 P2 S0 ; Disable Telnet
                    M569 P0 S0 ; Drive 0 goes backwards
                    M569 P1 S0 ; Drive 1 goes backwards
                    M569 P3 S0 ; Drive 3 goes forwards
                    M92 X80.5369 Y100.7067 Z399.9219 E416.666 ; Set steps per mm
                    M566 X900.00 Y900.00 Z150.00 E857.1428 ; Set maximum instantaneous speed changes (mm/min)
                    M203 X18000.00 Y6000.00 Z380.00 E1500.00 ; Set maximum speeds (mm/min)
                    M201 X3000.00 Y500.00 Z100.00 E10000.00 ; Set accelerations (mm/s^2)
                    M906 X950.00 Y950.00 Z950.00 E950.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
                    M84 S30 ; Set idle timeout
                    M208 X300 Y270 Z300 S0 ; Set axis maxima
                    M574 X1 Y1 Z1 S0 ; Set active low and disabled endstops
                    ;M574 Z1 S2 ; Set endstops controlled by probe
                    ;M558 P5 H5 F0 T6000 ; Set Z probe type to switch and the dive height + speeds
                    ;G31 P500 X0 Y0 Z0 ; Set Z probe trigger value, offset and trigger height
                    ;M557 X15:13 Y15:195 S20 ; Define mesh grid
                    M305 P0 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 0
                    M305 P1 T100000 B4388 C7.06e-8 R4700 ; As suggested by mudcurxzr
                    ;M305 P1 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1
                    M305 P2 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1
                    M143 H2 S280
                    M106 P0 S0.3 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                    M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                    M563 P0 D0 H1 ; Define tool 0
                    ; Automatic power saving
                    M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
                    ; Attempt to control heater2
                    M307 H2 A-1 C-1 D-1 ; Disable Heater E1 for use with the Berd-Air cooling
                    M106 P0 A2 S0 F30000 ; Fan 0 (Part Cooler) using Heater E1 Mosfet; Custom settings are not configured
                    ; BLTouch code
                    G29 S1
                    M307 H3 A-1 C-1 D-1
                    M558 P9 H5 F100 T2000
                    G31 X30 Y15 Z3 P25
                    G31 P500 Z0.1
                    M375 ; load "heightMape.csv"
                    • mudcruzrundefined
                      mudcruzr @Phaedrux
                      @phaedrux Remember I have a Maestro
                        A Former User
                        Use your multimeter and measure the resistance of the thermistor at room temperature? Cant see any other possibility than
                        • sensor is bad
                        • input channel is not configured correctly
                        • input channel is bad (try another one?)
                          Phaedrux Moderator @mudcruzr
                          @mudcruzr said in What exactly does PID tuning do?:
                          In that case the only thing that changes in the command I posted is the R4700. For the maestro it's R2200, but you can actually leave the R value off completely for boards newer than the 0.6 Duet.
                          • mudcruzrundefined
                            mudcruzr @Phaedrux
                            @phaedrux Sorry m8, missed you were talking about the B parameter. I've changed it and will keep a close eye on temps for a day or two.
                            Alan
                              crchisholm
                              Ok, for good or for bad, I have ordered the thermocouple daughter board and K type probe for it. I think the reason I didn't want to do that was that I spent a lot of time designing and printing (on another priinter) the case....just the way I wanted it. So now, after installing this, I will be redesigning it again. Oh well.
                                So this didn't give a good result?
                                  crchisholm @Phaedrux
                                  @phaedrux said in What exactly does PID tuning do?:
                                  @Phaedrux Pretty much the same results. Now I've tried B4138, B4388 and B4725 and the results have not varied any appreciable amount. All registered around 160 to 170
                                  when DWC reported a temp of 235,
                                  (I also added the R4700 on the end because I figured that was just an oversite that it wasn't added, correct?)
                                  @bearer I checked the resistance across the thermiter and it is about 91k which I would think was close enough.
                                  Phaedruxundefined A Former User? 2 Replies Last reply Reply Quote 0
                                    Phaedrux Moderator @crchisholm
                                    @crchisholm said in What exactly does PID tuning do?:
                                    It doesn't matter if it was included or not, but won't hurt to include it.
                                    I would suggest contacting E3D support, perhaps they can replace your thermistor cartridge for you.
                                    Another way to check where the fault lies is to swap the bed thermistor and hotend thermistor connection on the board. If the fault follows the thermistor, the board is fine at least.
                                      A Former User @crchisholm
                                      If your ambient temp is about 27C then that should be correct.
                                      (if https://e3d-online.com/100k-ohm-ntc-thermistor-semitec is correct and it is a 104GT-2 (which is replaced by 104NT-4-R025H42G) both should have b=4267 from what I could tell )
                                      Try another input on the Duet?
                                        dc42 administrators @crchisholm
                                        It's hard to get a good reading that way, because the thermocouple leads carry heat away from the top and it's difficult to get good thermal contact with the heater block. Even so, that difference in reading is greater than I expect. So I think the thermistor may be faulty.
                                          crchisholm
                                          I am going to put this on hold for the time being. Appreciate all the input and assistance. I have ordered the thermocouple and daughter board and will see what that brings to the game. As it stands now, I can get some pretty good prints (I've only used PLA thus far) just by jacking up the temp.
                                          I actually think one or the more fun aspects of this pursuit is trying to be as smart as the machine. Not there yet, but who knows....
                                            I couldn't agree more.
