    Firmware 2.03beta2 available
    Firmware installation
    25
    86
    12.2k
    • Martin1454undefined
      Martin1454 @chas2706
      @chas2706 said in Firmware 2.03beta2 available:
      @martin1454
      In your config.g remove M667 S1 and replace it with M669 K1. That will sort it!
      Still mirrored 😕
      • whosrdaddyundefined
        whosrdaddy
        @chas2706 : from which firmware did you upgrade may I ask?
        If coming from an older firmware (pre 1.19), the Y motors will need reverse direction. (you can do that in firmware)
        Martin1454undefined 1 Reply Last reply Reply Quote 0
          Martin1454 @whosrdaddy
          @whosrdaddy said in Firmware 2.03beta2 available:
          If it is me you are reffering to - 2.0 or what it was called late december
          EDIT: found out how the new 669 worked - had 2 put X-1.0:-1.0
          whosrdaddyundefined 1 Reply Last reply Reply Quote 0
            whosrdaddy @Martin1454
            @martin1454 : Yeah wrong person 🙂
            Glad you worked it out.
            Weird, I also have a CoreXY but I did not have to change anything...
              From the upgrade notes for 2.03beta1:
              If you have a CoreXY or other Core architecture printer, and you were using any axis factor parameters in your M667 command in config.g, those parameters are no longer supported. You will need to use M669 matrix parameters instead.
              @Martin1454 was using a X-1 parameter in his M667 command. Swapping the X and Y motors over and adjusting the directions in M569 would have worked too.
              • adri84djundefined
                adri84dj
                Hi. So far, I've been with firmware 2.02 RC3 in my Kossel.
                When I calibrated the bed with G32 with calibration factor 8, after two passes, I had some 0.05mm measurements, the difference between each measured point, and the first layer was very good
                I have updated to the latest version, 2.03 beta 2, and when doing the G32 calibration several times, I get disparate measurements between the measured points of up to 0.2mm. Now the first layers are uneven in different parts of the bed.
                Have I missed something? Has anything changed in this latest firmware?
                Thanks and best regards
                  There has been no intentional change in this area. There might have been an unintentional change because the code that handles endstop corrections has changed. Can you revert to 2.02 and check whether the new firmware really is to blame?
                  adri84djundefined 2 Replies Last reply Reply Quote 0
                  • adri84djundefined
                    adri84dj @dc42
                    Okay. I go back to 2.02 and try it later.
                    Thank you
                    • adri84djundefined
                      adri84dj @dc42
                      @dc42 said in Firmware 2.03beta2 available:
                      With the 2.02 final it works correctly again, as in 2.02 RC3.
                      At least in my case there is something weird about 2.03 Beta 2.
                        I've found a bug which might explain the problem, if you don't home the printer between auto calibration and printing. So please try 2.03beta3 when i release it. Meanwhile, homing between auto calibration and printing should work around the bug, assuming that your homing switches have reproducible trigger heights.
                        AlexLinundefined adri84djundefined 2 Replies Last reply Reply Quote 0
                        • AlexLinundefined
                          AlexLin @dc42
                          @dc42 does only apply to G32 or also to G29 mesh calibration?
                            dc42 administrators @AlexLin
                            @alexlin said in Firmware 2.03beta2 available:
                            Only to delta auto calibration.
                            • adri84djundefined
                              adri84dj @dc42
                              In agreement. When beta 3 is available, I try it. Thank you.
                                Beta 3 is available now.
                                • adri84djundefined
                                  adri84dj @dc42
                                  In agreement. I'll try it this weekend.
                                  Thank you
                                  • adri84djundefined
                                    adri84dj @dc42
                                    It is already tested and in beta 3 it works correctly again.
                                    • brunofportoundefined
                                      brunofporto
                                      When running G29 now the printer is using the nozzle reference and my z probe is out of the bed area. But when showing the map it thinks it was the probe at the nozzle position.
                                        dc42 administrators @brunofporto
                                        @brunofporto said in Firmware 2.03beta2 available:
                                        The only change should be that if you run G29 within a system macro file (for example, bed.g) then tool offsets will be applied., whereas in firmware 2.02 they are not. But Z probe offsets are always applied by G29. Are you using tool offsets?
                                        brunofportoundefined 2 Replies Last reply Reply Quote 0
                                          brunofporto @dc42
                                          @dc42 Not using any tool offsets. The only offset is the z-probe defined at the z-probe configuration line.
                                          Pretty sure it is putting the nozzle exactly where it should be the probe when I send a G29 - needed to change some parameters to make sure the probe is over the bed but the height map shows as the nozzle position is where the probe took the measurement.
                                            brunofporto @dc42
                                            @dc42 ps.: just realized that I post at the wrong thread! I am using the beta3! 😄
