    Duet firmware 2.03beta3 available
    Firmware installation
    18
    56
    6.0k
      I've just released this at https://github.com/dc42/RepRapFirmware/releases/tag/2.03beta3. See the upgrade notes at https://github.com/dc42/RepRapFirmware/blob/dev/WHATS_NEW.md for important change information.
        Just completed a 4 hour print, DuetWifi 1.02, CoreXY, no issues noted.
        • c310undefined
          c310
          i noticed 6 axis printer support. can you recommend 6-axis design mechanics ?
          or it is intended for future development ??
            deckingman @c310
            @c310 I've already got a 7 axis machine running on Duet. Although it's only 7axes when homing. For printing it reverts to being a 3 axis machine. It's CoreXYUV with a separate load balancing/force cancelling gantry. So effectively XYU and V get course homed together, then fine homed individually. XY carries the 5colour hot end, UV carries the 5 extruders. The third XY gantry gets homed independently. After homing, the 6 Motors get re-assigned to a single XY gantry but the motor direction of the upper gantry is reversed so it does the opposite of the lower two gantries.
            • Martin1454undefined
              Martin1454
              • If you try to use a G- or M-code that the firmware doesn't recognise, it will try to run a macro file of that name. For example, command M650 tries to run /sys/M650.g.
              Nice! - This will be useful for custom scripts!
              • dragonnundefined
                dragonn
                Strange, I read that:
                "If you used M141 to define a chamber heater using a heater number other than 0 or 1, the firmware crashed"
                And I used heater chamber on heater 6 and it worked fine on 2.03beta2.
                Will try beta3 in a few days.
                  dc42 administrators @dragonn
                  @dragonn said in Duet firmware 2.03beta3 available:
                  Maybe it's OK if you use heater 6. Someone else used heater 5 and it always crashed on boot up.
                  • Jackalundefined
                    Jackal
                    In earlier 2.03beta versions, if you auto-calibrated a delta printer then the motor positions were slightly wrong afterwards until you homed the printer
                    That's probably why I have been having weird height map when no hardware on the printer has been changed.
                    • wilrikerundefined
                      wilriker
                      Typo in release notes:
                      Known issues:
                      • Custom endstop input numbers in the M575 command (probe tool) don't work
                      Probe tool is M585. Also I am particularly interested in getting this fixed. Is that planned to be done before 2.03 final?
                      Manuel
                      My Tool Collection
                        dc42 administrators @wilriker
                        @wilriker said in Duet firmware 2.03beta3 available:
                        Known issues:
                        Yes it will be fixed, probably in the next beta.
                        • wilrikerundefined
                          wilriker @dc42
                          @dc42 Thanks!
                          Manuel
                          My Tool Collection
                          • gavatron3000undefined
                            gavatron3000
                            M291 doesnt pause a tool change if the message is blocking ie M291 S2, the message now appears at the correct time but the tool change carrys on anyway until completed.
                              dc42 administrators @gavatron3000
                              @gavatron3000 said in Duet firmware 2.03beta3 available:
                              On my list to investigate.
                                gavatron3000
                                thank you
                                • pabomanundefined
                                  paboman
                                  Updated to the 2.03beta3 then when uploading the last DuetWiFiServer.bin I get SKIPPED as response from DWC, why ?
                                  thx
                                    dc42 administrators @paboman
                                    @paboman said in Duet firmware 2.03beta3 available:
                                    thx
                                    That happens if you upload DuetWiFiServer.bin to a board other than a Duet WiFi. What board do you have, and what does Duet Web Control think it is?
                                    pabomanundefined 1 Reply Last reply Reply Quote 0
                                    • pabomanundefined
                                      paboman @dc42
                                      @dc42 its an ethernet version, do I need that file ?
                                      • wilrikerundefined
                                        wilriker @paboman
                                        @paboman No, this file is only for the Wifi version.
                                        Manuel
                                        My Tool Collection
                                        • DaveAundefined
                                          DaveA
                                          I Just installed beta3 and it's running well on my cartesian but I'm having an issue on the delta with smart effector. I decided to make a nozzle change that required me to reset the trigger height in the G31 and things have gone downhill from there.
                                          I am running through the steps of jogging Z until I get my paper trapped then...
                                          Do G92 Z0
                                          Do G1 Z25
                                          Do G30 S-1
                                          Get value from M114 and enter it into my G31 entry in config.g. So my config is now:
                                          M208 S1 Z-2.0
                                          M558 P8 R0.5 H12 F1000 T8000
                                          G31 X0 Y0 Z-0.32 P100
                                          Reboot...
                                          G28
                                          G1 Z0 <<- slight hit on bed. Absolutely no clearance. Need to jog Z up by .35 to get clearance
                                          I've run this a bunch of times with no luck and I'm starting to think that the Z value in the G31 is being ignored. I have looked and there is no other G31 anywhere.
                                          Did the procedure change or is my process wrong?
                                            @davea said in Duet firmware 2.03beta3 available:
                                            Don't do that. Use the value that the firmware reports after the G31 S-1 command instead.
