    Duet firmware 2.03beta3 available
    Firmware installation
    18
    56
    6.0k
    • Martin1454undefined
      Martin1454
      • If you try to use a G- or M-code that the firmware doesn't recognise, it will try to run a macro file of that name. For example, command M650 tries to run /sys/M650.g.
      Nice! - This will be useful for custom scripts!
      • dragonnundefined
        dragonn
        Strange, I read that:
        "If you used M141 to define a chamber heater using a heater number other than 0 or 1, the firmware crashed"
        And I used heater chamber on heater 6 and it worked fine on 2.03beta2.
        Will try beta3 in a few days.
          dc42 administrators @dragonn
          @dragonn said in Duet firmware 2.03beta3 available:
          Maybe it's OK if you use heater 6. Someone else used heater 5 and it always crashed on boot up.
          • Jackalundefined
            Jackal
            In earlier 2.03beta versions, if you auto-calibrated a delta printer then the motor positions were slightly wrong afterwards until you homed the printer
            That's probably why I have been having weird height map when no hardware on the printer has been changed.
            • wilrikerundefined
              wilriker
              Typo in release notes:
              Known issues:
              • Custom endstop input numbers in the M575 command (probe tool) don't work
              Probe tool is M585. Also I am particularly interested in getting this fixed. Is that planned to be done before 2.03 final?
              Manuel
              My Tool Collection
                dc42 administrators @wilriker
                @wilriker said in Duet firmware 2.03beta3 available:
                Known issues:
                Yes it will be fixed, probably in the next beta.
                • wilrikerundefined
                  wilriker @dc42
                  @dc42 Thanks!
                  Manuel
                  My Tool Collection
                  • gavatron3000undefined
                    gavatron3000
                    M291 doesnt pause a tool change if the message is blocking ie M291 S2, the message now appears at the correct time but the tool change carrys on anyway until completed.
                      dc42 administrators @gavatron3000
                      @gavatron3000 said in Duet firmware 2.03beta3 available:
                      On my list to investigate.
                        gavatron3000
                        thank you
                        • pabomanundefined
                          paboman
                          Updated to the 2.03beta3 then when uploading the last DuetWiFiServer.bin I get SKIPPED as response from DWC, why ?
                          thx
                            dc42 administrators @paboman
                            @paboman said in Duet firmware 2.03beta3 available:
                            thx
                            That happens if you upload DuetWiFiServer.bin to a board other than a Duet WiFi. What board do you have, and what does Duet Web Control think it is?
                            pabomanundefined 1 Reply Last reply Reply Quote 0
                            • pabomanundefined
                              paboman @dc42
                              @dc42 its an ethernet version, do I need that file ?
                              • wilrikerundefined
                                wilriker @paboman
                                @paboman No, this file is only for the Wifi version.
                                Manuel
                                My Tool Collection
                                • DaveAundefined
                                  DaveA
                                  I Just installed beta3 and it's running well on my cartesian but I'm having an issue on the delta with smart effector. I decided to make a nozzle change that required me to reset the trigger height in the G31 and things have gone downhill from there.
                                  I am running through the steps of jogging Z until I get my paper trapped then...
                                  Do G92 Z0
                                  Do G1 Z25
                                  Do G30 S-1
                                  Get value from M114 and enter it into my G31 entry in config.g. So my config is now:
                                  M208 S1 Z-2.0
                                  M558 P8 R0.5 H12 F1000 T8000
                                  G31 X0 Y0 Z-0.32 P100
                                  Reboot...
                                  G28
                                  G1 Z0 <<- slight hit on bed. Absolutely no clearance. Need to jog Z up by .35 to get clearance
                                  I've run this a bunch of times with no luck and I'm starting to think that the Z value in the G31 is being ignored. I have looked and there is no other G31 anywhere.
                                  Did the procedure change or is my process wrong?
                                    @davea said in Duet firmware 2.03beta3 available:
                                    Don't do that. Use the value that the firmware reports after the G31 S-1 command instead.
                                    • DaveAundefined
                                      DaveA
                                      Just ran the sequence again and used the value displayed in the results box (Stopped at height -0.319) . Updated G31 with no change in outcome - still slight hit on the bed. Need to jog Z up by .30ish to get clearance back.
                                      Also tried the same sequence on the cartesian and it appears to work as expected.
                                        On a delta, if you change the Z probe trigger height then you will also need to correct the homed height (M665 H parameter). The easiest way to do this is to run auto calibration, then save the new H value. Or you could just reduce the M665 H parameter by 0.3 in config.g or config-override.g as appropriate.
                                        DaveAundefined 1 Reply Last reply Reply Quote 0
                                          gavatron3000
                                          Apart from the m291 issue I raised above. CoreXZ running normally. Just completed a 4 hour print
                                            Thanks for the feedback!
