Duet firmware 2.03beta3 available
@dragonn said in Duet firmware 2.03beta3 available:
Strange, I read that:
"If you used M141 to define a chamber heater using a heater number other than 0 or 1, the firmware crashed"
And I used heater chamber on heater 6 and it worked fine on 2.03beta2.
Will try beta3 in a few days.Maybe it's OK if you use heater 6. Someone else used heater 5 and it always crashed on boot up.
In earlier 2.03beta versions, if you auto-calibrated a delta printer then the motor positions were slightly wrong afterwards until you homed the printer
That's probably why I have been having weird height map when no hardware on the printer has been changed.
Typo in release notes:
Known issues:
- Custom endstop input numbers in the M575 command (probe tool) don't work
Probe tool is M585. Also I am particularly interested in getting this fixed. Is that planned to be done before 2.03 final?
@wilriker said in Duet firmware 2.03beta3 available:
Known issues:
Yes it will be fixed, probably in the next beta.
@dc42 Thanks!
M291 doesnt pause a tool change if the message is blocking ie M291 S2, the message now appears at the correct time but the tool change carrys on anyway until completed.
@gavatron3000 said in Duet firmware 2.03beta3 available:
On my list to investigate.
thank you
Updated to the 2.03beta3 then when uploading the last DuetWiFiServer.bin I get SKIPPED as response from DWC, why ?
thx -
@paboman said in Duet firmware 2.03beta3 available:
thxThat happens if you upload DuetWiFiServer.bin to a board other than a Duet WiFi. What board do you have, and what does Duet Web Control think it is?
@dc42 its an ethernet version, do I need that file ?
@paboman No, this file is only for the Wifi version.
I Just installed beta3 and it's running well on my cartesian but I'm having an issue on the delta with smart effector. I decided to make a nozzle change that required me to reset the trigger height in the G31 and things have gone downhill from there.
I am running through the steps of jogging Z until I get my paper trapped then...
Do G92 Z0
Do G1 Z25
Do G30 S-1
Get value from M114 and enter it into my G31 entry in config.g. So my config is now:
M208 S1 Z-2.0
M558 P8 R0.5 H12 F1000 T8000
G31 X0 Y0 Z-0.32 P100
Reboot...
G28
G1 Z0 <<- slight hit on bed. Absolutely no clearance. Need to jog Z up by .35 to get clearanceI've run this a bunch of times with no luck and I'm starting to think that the Z value in the G31 is being ignored. I have looked and there is no other G31 anywhere.
Did the procedure change or is my process wrong?
@davea said in Duet firmware 2.03beta3 available:
Don't do that. Use the value that the firmware reports after the G31 S-1 command instead.
Just ran the sequence again and used the value displayed in the results box (Stopped at height -0.319) . Updated G31 with no change in outcome - still slight hit on the bed. Need to jog Z up by .30ish to get clearance back.
Also tried the same sequence on the cartesian and it appears to work as expected.
On a delta, if you change the Z probe trigger height then you will also need to correct the homed height (M665 H parameter). The easiest way to do this is to run auto calibration, then save the new H value. Or you could just reduce the M665 H parameter by 0.3 in config.g or config-override.g as appropriate.
Apart from the m291 issue I raised above. CoreXZ running normally. Just completed a 4 hour print
Thanks for the feedback!
Ran a 2 hour print on my CoreXY yesterday, no problems to report
Ran a 3 hour print on my Delta yesterday, no problems to report
