    Extruder Thermistor in Simplify3D
    1.5k
    • Gummixundefined
      Gummix
      0_1553372115966_config (1).g
      https://www.file-upload.net/download-13547328/MagnetAnstandshalterW-Schrank.gcode.html
      I hope they were the right ones, unfortunately I'm not at home anymore to check that out.
        In your config.g it looks like you have no tools defined.
        And in your gcode file, it looks like simplify3d is trying to set the temps for tool5, which explains the invalid tool number.
        G90
        M82
        M106 S0
        M140 S60
        M190 S60
        M104 S198 T5
        M109 S198 T5
        G28 ; home all axes
        G92 E0
        G1 E-2.0000 F2400
        G1 Z0.260 F1002
        ; process Process1
        ; layer 1, Z = 0.260
        T1
        ; tool H0.260 W0.342
        ; skirt
        G1 X87.440 Y84.627 F4800
        G1 E0.0000 F720
        G92 E0
        G1 X89.627 Y82.440 E0.1041 F900
        https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCartesianPrinter#Section_Tool_definition_section
        • Gummixundefined
          Gummix
          And why is that?
          I didn't set anything of a tool 5 in S3D and in Duet I created the tool.
            I'm not sure. I'm not a simplify 3d user. How did you define the tools?
            • Gummixundefined
              Gummix
              Take a look at the pictures, where always "Werkzeug 1" is written you can choose different ones (0-5)
              Which sliver do you use?
                It seems you've added the tools from the DWC then? That could be the issue.
                From the DWC manual https://duet3d.dozuki.com/Wiki/Duet_Web_Control_Manual#Section_Tools
                Tools
                Show the configured tools and allows for tools to be added or removed. Currently these additions and removals don't persist through hardware resets so it is recommended to add tools using the M563 G-Code in config.g file as described in Configuring RepRapFirmware for a Cartesian printer.
                So I would suggest going through that link and adding your tools to config.g so they remain permanently.
                I use Slic3r PE and Cura to slice.
                • Gummixundefined
                  Gummix
                  Thanks i will test it.
                  • Gummixundefined
                    Gummix
                    So i added this in the config.g
                    M563 P0 D0 H1 ; tool 0 uses extruder drive 0 and heater 1
                    G10 P0 S0 R0 X0 Y0 ; set tool 0 temperatures and offsets
                    Shouldn't this now also be displayed under Tools in the dashboard?
                    Cause it doesn't show anything.
                      This is what I have in my tools section and it does show up in the DWC tools tab.
                      M563 P0 S"Titan Aero" D0 H1    ; Define tool 0 (Titan Aero extruder)
                      G10 P0 X0 Y0 Z0   ; Set tool 0 axis offsets
                      T0    ; Select first tool
                      • Gummixundefined
                        Gummix
                        ok, I had to disconnect the whole power supply to the board (also USB). Then it worked. Thank you
