    CoreXY - X-Axis Vibration Issues
    49
    7.1k
    • Vetiundefined
      Veti @zapta
      @zapta said in CoreXY - X-Axis Vibration Issues:
      That's a great pointer. Thanks. Found it on Thingiverse.
      also on this forum. https://forum.duet3d.com/topic/8874/blv-mgn-cube-3d-printer-project
      • zaptaundefined
        zapta @Veti
        @veti said in CoreXY - X-Axis Vibration Issues:
        i think this is why BLV uses 16 tooth pulleys and 0.9 Steppers on his cube.
        I just install same 0.9 stepper as the (x-y) motor of my printer and the vibrations of the (x-y) diagonal movements test are gone! I have another one on order for the (x+y) motor. It seems that 0.9deg steppers do make a difference.
        https://www.amazon.com/gp/product/B00W9A2L3S
        fcwiltundefined Vetiundefined 2 Replies Last reply Reply Quote 0
        • fcwiltundefined
          fcwilt @zapta
          Was your printer already setup with a 24 volt power supply?
          • zaptaundefined
            zapta @fcwilt
            Yes, all parts are on 24V, including heaters and fans, no buck converters and such. The only add-on is this SSR to reduce heat on the Duet https://www.auberins.com/index.php?main_page=product_info&products_id=288
            • fcwiltundefined
              fcwilt @zapta
              And I just finished tidying up the wiring on my 12 volt setup making the conversion a bit more work. Sigh...
              So, let's see, I need new heaters, new fans, new steppers and a new bulb for my illuminated emergency stop button...
              Thanks for the info.
              • Vetiundefined
                Veti @zapta
                Same for me. But can anyone give an explanation as to why this solves the problem?
                My current theory is that the microstepping can not hold the inbetween steps in all cases.
                i.e at some steps closer to the full step the holding force is not great enough which causes the driver to move/remain at the full step resolution. causing more filament to be extruded at the full step position.
                edit: found this https://www.machinedesign.com/archive/microstepping-myths
                zaptaundefined 1 Reply Last reply Reply Quote 1
                • zaptaundefined
                  zapta @fcwilt
                  @fcwilt said in CoreXY - X-Axis Vibration Issues:
                  And I just tied up my wiring, which resulted in the SSR giving up smoke and dying. Apparently I connected the control input in reverse polarity. 😉
                  This was an opportunity to look inside the SSR. It's built like a tank and the power Mosfet has a large chunk of silicon in it.
                  Connected the 12A/24V bed to the Duet directly and everything works like champ. Not sure if I want to install a new SSR. I like the current simplicity.
                  dc42undefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                  • zaptaundefined
                    zapta @Veti
                    I think that my experiment of having vibration in a single stepper diagonal move (I as actually holding the other belt with my finger to make sure that there are no vibrations from the stationary motor) supports that this is not necessarily a result of an interaction between the two motors.
                    Your explanation sounds reasonable to me. Microstepping and Interpolation have their limits, especially that it is a modulation of the underlying PWM and not direct linear current source.
                    Another potential factor is that the 0.9 steppers are also larger (for same torque) and thus have higher mass and smoother rotation (?)
                    • Vetiundefined
                      Veti
                      i found this very good analysis of microstepping https://hackaday.com/2016/08/29/how-accurate-is-microstepping-really/
                        dc42 administrators @zapta
                        12A is well within the rating of the Duet. I recommend that at regular intervals you check that the screws in the VIN and bed heater terminal blocks of the Duet are still tight, until you are sure that they are staying tight. This is because high currents can cause creep in wires. Crimping the correct ferrules on to the wire ends reduces this risk.
                        • fcwiltundefined
                          fcwilt @zapta
                          My heaters are all line voltage heaters (110 VAC) and thus an SSR is needed.
                          • zaptaundefined
                            zapta @dc42
                            @dc42 said in CoreXY - X-Axis Vibration Issues:
                            Yes, it seems to handle it very well and the mosfet is cool even at 100% PWM (looked at it with an IR camera).
                            I did crimp cheap Chinese ferrules, hope they are right, they seem to be made of aluminum(?). Not sure how it will behave when oxidized. I know very little about it
                              The rated bed heater current of the Duet isn't set by the MOSFET, it's determined by heating of the PCB traces. Even when using 2oz copper instead of the usual 1oz, and duplicating traces on both sides of the PCB, it's hard to carry 20A on a PCB.
                              • zaptaundefined
                                zapta
                                @dc42, I presume you are aware of this technique but just in case
                                http://www.eevblog.com/forum/blog/eevblog-317-pcb-tinning-myth-busting/
                                • Vetiundefined
                                  Veti
                                  we have a name. VFA (Vertical Fine Artifacts)
                                  https://shop.prusa3d.com/forum/user-mods-octoprint-enclosures-nozzles--f65/stepper-motor-upgrades-to-eliminate-vfa-s-vertical-t28098.html
                                  it seems if you make your printer more precise these artefacts start to show.
                                  after getting an ender 3 to play with i found these artefacts as well on the ender 3.
                                  funny thing is the user started seeing the problem around the same time.
                                    Yes, but it's not very effective, especially if you are already using 2oz copper.
                                    • zaptaundefined
                                      zapta @dc42
                                      @dc42, yes, this is a good point. Doubling the copper thickness doesn't double the solder.
