BL Touch Problem Duet wifi 2
@phaedrux
Hi, It is Firmware version: 2.02(RTOS) (2018-12-24b1) and 1.04b revision.
I'm now Just trying to find this V3 thread!
With regards to a static G30 test, I haven't no, i haven't seen this recommended anywhere? -
@Phaedrux
I've just tried to do a G30 static test, but i get the error or needing the Z to be homed first. I cant home it without the sensor working? -
How did you do the test?
https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
Here's the V3 thread. https://forum.duet3d.com/topic/10023/bltouch-v3-0-information-setup-and-o-scope-pictures
@phaedrux
I cant seem to do any test on it bar the fact it deploys and retracts. I can't home the z axis to preform a G30 test because the z axis proceeds to just go down past the sensor until i emergency stop then manually lift the z axis. -
@jackismad, to perform a plain G30 test (with no XYZP parameters), you don't need to home Z first, just X and Y.
@jackismad said in BL Touch Problem Duet wifi 2:
You can use G92 Z0 to set the z axis as homed, then you can jog it around.
@phaedrux said in BL Touch Problem Duet wifi 2:
BLTouch V3
Is there a V3 ?
According to Antclabs website the latest iteration is classified as V2.2
@calvinx Yes, it's quite new though. They've only just posted the manual.
https://www.antclabs.com/manual -
Thanks for the reponce.
I looked at the problem with fresh eyes this morning. I Found in my Homeall.g file it was calling the wrong file on this line.
M98 deployprobe.g ; deploy mechanical Z probe
and
M98 retractprobe.g ; retract mechanical Z probe
They were both like the old style Pdeployprobe.g/Pretractprobe.g. So i changed this, set the offsets then did a static test where it worked. I then proceeded to do a test, i homed all, it deployed and lowered correctly, when it hit the bed it rose 5. I must have changed a setting somewhere to make it do that.The next issue i now face, is after it rises i get a warning where robe.g couldn't be found. I am assuming i am doing something incorrectly and its not searching for the full deployprobe.g or retractprobe.g
I moved on with doing a static test recommended by @Phaedrux.
The result was with the probe deployed using the M401, When triggered the pin rises, goes red then the pin drops again with Z-probe reading 0 both times.The G30 Test, it does what it is suppose to do, it lowers then when it triggers it rises 5 again. (Need to find that in the config to stop it from doing that)
I did start the dynamic test to find the trigger height. Which i worked it out to be -0.148 lower then when it triggers. i was going to amend this when i know it is accurate with the static test working first...
Thanks again
Thanks for the info.
Can you post your homing files and config.g?
You don't need to use M98 Pdeployprobe.g or M401 to control the pin. When using probe type P9 for the BLTouch the Duet will control the pin as needed when you call G30, G29, etc.
You still need to have deployprobe.g and retractprobe.g macros in the sys folder with the servo commands in them.
@phaedrux Yeah sure, here they are, I
Config.g
; generated by RepRapFirmware Configuration Tool v2 on Sat Apr 13 2019 16:24:07 GMT+0100 (British Summer Time); General preferences
M83 ; ...but relative extruder moves; Network
M550 P"Jack" ; Set machine name
M552 S1 ; Enable network
;*** Access point is configured manually via M587
M586 P0 S1 ; Enable HTTP
M586 P1 S1 ; Enable FTP
M569 P0 S0 ; Drive 0 goes forwards
M569 P1 S0 ; Drive 1 goes forwards
M569 P2 S1 ; Drive 2 goes backwards
M92 X160.00 Y160.00 Z8000.00 E100.00 ; Set steps per mm
M566 X600.00 Y600.00 Z18.00 E300.00 ; Set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 E6000.00 ; Set maximum speeds (mm/min)
M201 X1500.00 Y1500.00 Z100.00 E10000.00 ; Set accelerations (mm/s^2)
M906 X500.00 Y500.00 Z500.00 E800.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
M208 X-50 Y-10 Z0 S1 ; Set axis minima
M208 X220 Y220 Z200 S0 ; Set axis maxima; Endstops
M574 X1 Y1 S0 ; Set active low and disabled endstops; Z-Probe
M574 Z1 S2 ; Set endstops controlled by probe
M307 H3 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
M558 P9 H5 F120 T1500 ; Set Z probe type to bltouch and the dive height + speeds
G31 P1 X-50 Y0 Z0 ; Set Z probe trigger value, offset and trigger height
M557 X20:200 Y20:200 S40 ; Define mesh grid; Heaters
M307 H0 B0 S1.00 ; Disable bang-bang mode for the bed heater and set PWM limit
M305 P0 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 0
M143 H0 S130 ; Set temperature limit for heater 0 to 130C
M305 P1 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
M143 H1 S275 ; Set temperature limit for heater 1 to 275C; Fans
M106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
M563 P0 D0 H1 ; Define tool 0
G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C; Automatic power saving
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss; Custom settings are not configured
M501 ; Load saved parameters from non-volatile memory
T0 ; Select first toolhomeall.g
; homeall.g
; called to home all axes
; generated by RepRapFirmware Configuration Tool v2 on Sat Apr 13 2019 16:24:08 GMT+0100 (British Summer Time)
G91 ; relative positioning
G1 Z0.5 F1500 S2 ; lift Z relative to current position
G1 S1 X-258 Y-235 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
G1 X5 Y5 F1500 ; go back a few mm
G1 S1 X-258 Y-235 F360 ; move slowly to X and Y axis endstops once more (second pass)
G90 ; absolute positioning
G1 X20 Y20 F1500 ; go to first bed probe point and home Z
G30 ; home Z by probing the bed; Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G1 S2 Z5 F25 ; lift Z relative to current position
;G90 ; absolute positioningM98 retractprobe.g ; retract mechanical Z probe
homex.g
; homex.g
; called to home the X axis
G1 Z5 F1500 S2 ; lift Z relative to current position
G1 S1 X-258 F1800 ; move quickly to X axis endstop and stop there (first pass)
G1 X5 F1500 ; go back a few mm
G1 S1 X-258 F360 ; move slowly to X axis endstop once more (second pass)
G1 Z-5 F1500 S2 ; lower Z again
G90 ; absolute positioninghomey.g
; homey.g
; called to home the Y axis
G1 S1 Y-235 F1800 ; move quickly to Y axis endstop and stop there (first pass)
G1 Y5 F1500 ; go back a few mm
G1 S1 Y-235 F360 ; move slowly to Y axis endstop once more (second pass)
G90 ; absolute positioninghomez.g
; homez.g
; called to home the Z axis
G1 Z0 F1500 S2 ; lift Z relative to current position
G1 X20 Y20 F1500 ; go to first probe point
;G90 ; absolute positioning -
M98 retractprobe.g ; retract mechanical Z probeYou can remove those from homeall.g
M558 H5 sets the dive height of the probe, so that explains it lifting.
In your homeall you have
which only lifts it 0.5mm, if you change that to 5mm things will be a bit smoother. I also like to return the nozzle to 5mm above the bed after the probe is finished just to keep the pin sufficiently above the bed.If you make those changes I think things will work a bit more smoothly.
I think your probe is working as long as it's stopping the movement of the bed when you trigger the pin by hand during a G30 probe.
https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe to find your trigger height.
@phaedrux Fantasic, thank you very much, just going to go through the test page now! I have just relised aswell my Z axis steps per mm is screwed up as 5mm seems more like 50mm!! Ill get this sorted then sort out the trigger height!
Thanks again for your help!
