    BL Touch Problem Duet wifi 2
    1.6k
    • jackismadundefined
      jackismad @jackismad
      @Phaedrux
      I've just tried to do a G30 static test, but i get the error or needing the Z to be homed first. I cant home it without the sensor working?
        How did you do the test?
        https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
        Here's the V3 thread. https://forum.duet3d.com/topic/10023/bltouch-v3-0-information-setup-and-o-scope-pictures
        jackismadundefined 1 Reply Last reply Reply Quote 0
          jackismad @Phaedrux
          @phaedrux
          I cant seem to do any test on it bar the fact it deploys and retracts. I can't home the z axis to preform a G30 test because the z axis proceeds to just go down past the sensor until i emergency stop then manually lift the z axis.
          dc42undefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
            dc42 administrators @jackismad
            @jackismad, to perform a plain G30 test (with no XYZP parameters), you don't need to home Z first, just X and Y.
              Phaedrux Moderator @jackismad
              @jackismad said in BL Touch Problem Duet wifi 2:
              You can use G92 Z0 to set the z axis as homed, then you can jog it around.
                A Former User @Phaedrux
                @phaedrux said in BL Touch Problem Duet wifi 2:
                BLTouch V3
                Is there a V3 ?
                According to Antclabs website the latest iteration is classified as V2.2
                Versions
                  Phaedrux Moderator @A Former User
                  @calvinx Yes, it's quite new though. They've only just posted the manual.
                  https://www.antclabs.com/manual
                    jackismad @dc42
                    Thanks for the reponce.
                    I looked at the problem with fresh eyes this morning. I Found in my Homeall.g file it was calling the wrong file on this line.
                    M98 deployprobe.g ; deploy mechanical Z probe
                    and
                    M98 retractprobe.g ; retract mechanical Z probe
                    They were both like the old style Pdeployprobe.g/Pretractprobe.g. So i changed this, set the offsets then did a static test where it worked. I then proceeded to do a test, i homed all, it deployed and lowered correctly, when it hit the bed it rose 5. I must have changed a setting somewhere to make it do that.
                    The next issue i now face, is after it rises i get a warning where robe.g couldn't be found. I am assuming i am doing something incorrectly and its not searching for the full deployprobe.g or retractprobe.g
                    I moved on with doing a static test recommended by @Phaedrux.
                    The result was with the probe deployed using the M401, When triggered the pin rises, goes red then the pin drops again with Z-probe reading 0 both times.
                    The G30 Test, it does what it is suppose to do, it lowers then when it triggers it rises 5 again. (Need to find that in the config to stop it from doing that)
                    I did start the dynamic test to find the trigger height. Which i worked it out to be -0.148 lower then when it triggers. i was going to amend this when i know it is accurate with the static test working first...
                    Thanks again
                      @phaedrux
                      Thanks for the info.
                        Can you post your homing files and config.g?
                        You don't need to use M98 Pdeployprobe.g or M401 to control the pin. When using probe type P9 for the BLTouch the Duet will control the pin as needed when you call G30, G29, etc.
                        You still need to have deployprobe.g and retractprobe.g macros in the sys folder with the servo commands in them.
                          jackismad @Phaedrux
                          @phaedrux Yeah sure, here they are, I
                          Config.g
                          ; generated by RepRapFirmware Configuration Tool v2 on Sat Apr 13 2019 16:24:07 GMT+0100 (British Summer Time)
                          M550 P"Jack" ; Set machine name
                          M552 S1 ; Enable network
                          ;*** Access point is configured manually via M587
                          M586 P0 S1 ; Enable HTTP
                          M586 P1 S1 ; Enable FTP
                          M586 P2 S0 ; Disable Telnet
                          M569 P0 S0 ; Drive 0 goes forwards
                          M569 P1 S0 ; Drive 1 goes forwards
                          M569 P2 S1 ; Drive 2 goes backwards
                          M92 X160.00 Y160.00 Z8000.00 E100.00 ; Set steps per mm
                          M566 X600.00 Y600.00 Z18.00 E300.00 ; Set maximum instantaneous speed changes (mm/min)
                          M203 X6000.00 Y6000.00 Z180.00 E6000.00 ; Set maximum speeds (mm/min)
                          M201 X1500.00 Y1500.00 Z100.00 E10000.00 ; Set accelerations (mm/s^2)
                          M906 X500.00 Y500.00 Z500.00 E800.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
                          M84 S30 ; Set idle timeout
                          M208 X-50 Y-10 Z0 S1 ; Set axis minima
                          M208 X220 Y220 Z200 S0 ; Set axis maxima
                          M574 X1 Y1 S0 ; Set active low and disabled endstops
                          M574 Z1 S2 ; Set endstops controlled by probe
                          M307 H3 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
                          M558 P9 H5 F120 T1500 ; Set Z probe type to bltouch and the dive height + speeds
                          G31 P1 X-50 Y0 Z0 ; Set Z probe trigger value, offset and trigger height
                          M557 X20:200 Y20:200 S40 ; Define mesh grid
                          M307 H0 B0 S1.00 ; Disable bang-bang mode for the bed heater and set PWM limit
                          M305 P0 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 0
                          M143 H0 S130 ; Set temperature limit for heater 0 to 130C
                          M305 P1 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
                          M143 H1 S275 ; Set temperature limit for heater 1 to 275C
                          M106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                          M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                          M563 P0 D0 H1 ; Define tool 0
                          ; Automatic power saving
                          M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
                          M501 ; Load saved parameters from non-volatile memory
                          T0 ; Select first tool
                          homeall.g
                          ; homeall.g
                          ; called to home all axes
                          ; generated by RepRapFirmware Configuration Tool v2 on Sat Apr 13 2019 16:24:08 GMT+0100 (British Summer Time)
                          G91 ; relative positioning
                          G1 Z0.5 F1500 S2 ; lift Z relative to current position
                          G1 S1 X-258 Y-235 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
                          G1 X5 Y5 F1500 ; go back a few mm
                          G1 S1 X-258 Y-235 F360 ; move slowly to X and Y axis endstops once more (second pass)
                          G90 ; absolute positioning
                          G1 X20 Y20 F1500 ; go to first bed probe point and home Z
                          ;G91 ; relative positioning
                          ;G1 S2 Z5 F25 ; lift Z relative to current position
                          ;G90 ; absolute positioning
                          homex.g
                          ; homex.g
                          ; called to home the X axis
                          G1 Z5 F1500 S2 ; lift Z relative to current position
                          G1 S1 X-258 F1800 ; move quickly to X axis endstop and stop there (first pass)
                          G1 X5 F1500 ; go back a few mm
                          G1 S1 X-258 F360 ; move slowly to X axis endstop once more (second pass)
                          G1 Z-5 F1500 S2 ; lower Z again
                          homey.g
                          ; homey.g
                          ; called to home the Y axis
                          G1 S1 Y-235 F1800 ; move quickly to Y axis endstop and stop there (first pass)
                          G1 Y5 F1500 ; go back a few mm
                          G1 S1 Y-235 F360 ; move slowly to Y axis endstop once more (second pass)
                          homez.g
                          ; homez.g
                          ; called to home the Z axis
                          G1 Z0 F1500 S2 ; lift Z relative to current position
                          G1 X20 Y20 F1500 ; go to first probe point
                            You can remove those from homeall.g
                            M558 H5 sets the dive height of the probe, so that explains it lifting.
                            In your homeall you have G1 Z0.5 F1500 S2 ; lift Z relative to current position which only lifts it 0.5mm, if you change that to 5mm things will be a bit smoother. I also like to return the nozzle to 5mm above the bed after the probe is finished just to keep the pin sufficiently above the bed.
                            If you make those changes I think things will work a bit more smoothly.
                            I think your probe is working as long as it's stopping the movement of the bed when you trigger the pin by hand during a G30 probe.
                            https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe to find your trigger height.
                              jackismad @Phaedrux
                              @phaedrux Fantasic, thank you very much, just going to go through the test page now! I have just relised aswell my Z axis steps per mm is screwed up as 5mm seems more like 50mm!! Ill get this sorted then sort out the trigger height!
                              Thanks again for your help!
