    microSD card for 0.6 Duet board with RRFw v 0.78b
    2.1k
    • cnundefined
      cn
      Having difficulty creating a card the second–hand, ebay–acquired board will read; is there anywhere I can acquire one guaranteed readable?
        You would be better off installing more recent firmware, which will give you better diagnostics.
        • cnundefined
          cn
          Unfortunately, bossa refuses to connect to the board on 3 separate platforms; Linux, Mac and Windows.
          Arduino IDE on Mac let me run the M115 which told me the firmware version, and that a G28 X0 returned: Can't open 0:/sys/homex.g not found.
          I have been unable to backup current obsolete firware, nevermind install the latest for a Duet 0.6.
          • DocTruckerundefined
            DocTrucker
            What's the full command you are using to get bossa to update it? Terminal or GUI?
            There were some guides kicking about that neglected specifying the com port number.
            Not sure if you need to erase before uploading with bossa?
            cnundefined 1 Reply Last reply Reply Quote 0
            • cnundefined
              cn @DocTrucker
              @doctrucker it seems one cannot invoke bossa[c] without erasing the CPU : ]
              bossac invocation, RepRapPro docs on archive.org
              Having got 1.23 dated 2018-12-24b1 installed (and booting), all I get for the cards I've been trying is: Cannot initialise SD card 0: Card is unusable
              I have tried 128Mb, 1Gb and 32Gb cards
              I expect I should be trying a different capacity/class microSD card.
                DocTrucker
                Have a look over:
                https://duet3d.dozuki.com/Wiki/SD_Card
                  dc42 administrators @cn
                  @cn said in microSD card for 0.6 Duet board with RRFw v 0.78b:
                  Any card up to 32Gb should work, provided it is formatted to FAT16 or FAT32 (which SD cards in that capacity range normally are).
                  Can you post a close up photo of the back of the SD card socket? Older Duets sometimes have bad soldered connections there.
                  cnundefined 2 Replies Last reply Reply Quote 0
                  • cnundefined
                    cn @dc42
                    @dc42 I rechecked messages I was seeing before the upgrade;
                    Can't open 0:/sys/homex.g to read from. Error code: 3
                    Macro file homex.g not found.
                    Will take a close-up when next in the same room as the board. Full board
                    • cnundefined
                      cn @dc42
                      @dc42 a close up as promised
                        That looks OK, but you need to look at it from just above the main processor. Sometimes it's evident that the pins on the right hand (as seen from that angle - it's the left hand end in your photo above) end of the row are just sitting on the PCB pads instead of being soldered to them.
                        Is the SD card pushed into the socket far enough so that it clicks, and you have to push it again to release it?
                        • cnundefined
                          cn @dc42
                          @dc42 like this or this?
                          I try to seat the card properly; have used canned air to blow out to no effect.
                          Reflowing the soldered joints is next on the list; spare parts are in the post... in case the hot air melts the plastic part 👿
                            I can't be certain because that part of the photo is a little out of focus; but the joints look OK to me. It's usually clear when the joints are bad.
                            If the joints at the back of the SD card are bad, it's easier to mend them using a no-clean flux pen and a fine-tipped soldering iron than with hot air.
                            The other likely possibilities are a bad or damaged contact in the socket, a damaged processor, or a bad soldered joint on one of the processor pins that connects to the SD card. Or just possibly a short (solder bridge) between 2 processor pins, but that's less likely.
                            Where in the UK are you?
                            • cnundefined
                              cn @dc42
                              @dc42 Lincolnshire
                                DocTrucker
                                Have you tried to reading the files on your computer? Have you checked the file system matches what is expected? The duet maybe case sensitive.
                                cnundefined 1 Reply Last reply Reply Quote 1
                                  @dc42 Lincolnshire
                                  That's a long way from me (Somerset).
                                  • cnundefined
                                    cn @dc42
                                    @dc42 it is 🙂 There’s a town here which shares a name with a village down there…
                                    • cnundefined
                                      cn @DocTrucker
                                      @doctrucker the Duet seems unable to read any microSD cards presently.
                                      • cnundefined
                                        cn
                                        Have replaced the microSD socket; the problem persists. 🤔
                                          If the Duet used to be able to read SD cards, then sadly the most likely reason it won't now is that one of the microcontroller interface pins is no longer working. It's possible to replace the microcontroller, but not easy. I wrote off the first two Duets that I tried to replace the microcontroller on, by lifting PCB traces. The 3rd and 4th I did successfully.
                                          • cnundefined
                                            cn @dc42
                                            @dc42 I'm not sure it's ever read uSD cards since I've had it
                                            Hopefully this morning's soldering is still viable ![endoscope view of Duet SD socket](Endoscope camera shot of replaced socket)
                                            https://☁.chrs.nl/cloud/index.php/s/9q4X9Nfyh9Y9bro
                                            A new board is outside my current ad hoc budget ...
