    microSD card for 0.6 Duet board with RRFw v 0.78b
    2.1k
    • DocTruckerundefined
      DocTrucker
      Have a look over:
      https://duet3d.dozuki.com/Wiki/SD_Card
        dc42 administrators @cn
        @cn said in microSD card for 0.6 Duet board with RRFw v 0.78b:
        @doctrucker it seems one cannot invoke bossa[c] without erasing the CPU : ]
        bossac invocation, RepRapPro docs on archive.org
        Having got 1.23 dated 2018-12-24b1 installed (and booting), all I get for the cards I've been trying is: Cannot initialise SD card 0: Card is unusable
        I have tried 128Mb, 1Gb and 32Gb cards
        I expect I should be trying a different capacity/class microSD card.
        Any card up to 32Gb should work, provided it is formatted to FAT16 or FAT32 (which SD cards in that capacity range normally are).
        Can you post a close up photo of the back of the SD card socket? Older Duets sometimes have bad soldered connections there.
        cnundefined 2 Replies Last reply Reply Quote 0
        • cnundefined
          cn @dc42
          @dc42 I rechecked messages I was seeing before the upgrade;
          Can't open 0:/sys/homex.g to read from. Error code: 3
          Macro file homex.g not found.
          Will take a close-up when next in the same room as the board. Full board
          • cnundefined
            cn @dc42
            @dc42 a close up as promised
              That looks OK, but you need to look at it from just above the main processor. Sometimes it's evident that the pins on the right hand (as seen from that angle - it's the left hand end in your photo above) end of the row are just sitting on the PCB pads instead of being soldered to them.
              Is the SD card pushed into the socket far enough so that it clicks, and you have to push it again to release it?
              cnundefined 1 Reply Last reply Reply Quote 0
              • cnundefined
                cn @dc42
                @dc42 like this or this?
                I try to seat the card properly; have used canned air to blow out to no effect.
                Reflowing the soldered joints is next on the list; spare parts are in the post... in case the hot air melts the plastic part 👿
                  I can't be certain because that part of the photo is a little out of focus; but the joints look OK to me. It's usually clear when the joints are bad.
                  If the joints at the back of the SD card are bad, it's easier to mend them using a no-clean flux pen and a fine-tipped soldering iron than with hot air.
                  The other likely possibilities are a bad or damaged contact in the socket, a damaged processor, or a bad soldered joint on one of the processor pins that connects to the SD card. Or just possibly a short (solder bridge) between 2 processor pins, but that's less likely.
                  Where in the UK are you?
                  • cnundefined
                    cn @dc42
                    @dc42 Lincolnshire
                      DocTrucker
                      Have you tried to reading the files on your computer? Have you checked the file system matches what is expected? The duet maybe case sensitive.
                      cnundefined 1 Reply Last reply Reply Quote 1
                        @dc42 Lincolnshire
                        That's a long way from me (Somerset).
                        • cnundefined
                          cn @dc42
                          @dc42 it is 🙂 There’s a town here which shares a name with a village down there…
                          • cnundefined
                            cn @DocTrucker
                            @doctrucker the Duet seems unable to read any microSD cards presently.
                            • cnundefined
                              cn
                              Have replaced the microSD socket; the problem persists. 🤔
                                If the Duet used to be able to read SD cards, then sadly the most likely reason it won't now is that one of the microcontroller interface pins is no longer working. It's possible to replace the microcontroller, but not easy. I wrote off the first two Duets that I tried to replace the microcontroller on, by lifting PCB traces. The 3rd and 4th I did successfully.
                                • cnundefined
                                  cn @dc42
                                  @dc42 I'm not sure it's ever read uSD cards since I've had it
                                  Hopefully this morning's soldering is still viable ![endoscope view of Duet SD socket](Endoscope camera shot of replaced socket)
                                  https://☁.chrs.nl/cloud/index.php/s/9q4X9Nfyh9Y9bro
                                  A new board is outside my current ad hoc budget ...
                                    Was it offered for sale in "known to be fully working" state?
                                    • cnundefined
                                      cn @dc42
                                      @dc42 was part of a printer listing; operative state unspecified 🙃
                                      • cnundefined
                                        cn @dc42
                                        @dc42 if M122 reports that the board has reset itself via software and/or that the MCU temperature is around/above 100°C the Duet is in a bad way?
                                        Phaedruxundefined VoodooBaneundefined 2 Replies Last reply Reply Quote 0
                                          Phaedrux Moderator @cn
                                          You may want to run this procedure to calibrate the CPU temp, since it could be up to 45c off on the older boards. Even so, that would seem high to me.
                                          https://duet3d.dozuki.com/Wiki/Calibrating_the_CPU_temperature
                                            How warm does the MCU feel? It should be no more than slightly warm.
