    Hot end / thermistor problem
    1.2k
    • Vetiundefined
      Veti
      can you measure the resistance of the thermistor with a voltmeter?
      my guess is you somehow shorted the thermistor cables and the resistance is very low.
      • Vetiundefined
        Veti @BearcatTD
        @bearcattd said in Hot end / thermistor problem:
        These are what I bought:
        the problem with that is that they dont tell you what the thermistor actually is.
        without a supplied resistance table the temperature can easily be off by 40 degrees at 200 degrees.
        BearcatTDundefined 1 Reply Last reply Reply Quote 0
        • BearcatTDundefined
          BearcatTD
          101.2 on the voltmeter
          Professor of Theatre, Lighting and Scenic Designer, Northwest Missouri State University
          Hardware: Ender 3 with a Duet 2 wifi, CR-10 V2 with a Duet3
          • Vetiundefined
            Veti
            thats broken. it should read around 100k at room temperature.
              BearcatTD @Veti
              @veti Could I find a resistance table for 100k ohm thermistors and use that? Would it look like this:
              http://www.bapihvac.com/wp-content/uploads/2010/11/Thermistor_100K.pdf
                BearcatTD @Veti
                @veti FYI I had the voltmeter selector at 200K on the resistance side.
                • Vetiundefined
                  Veti
                  so it was 100k.
                  can you swap the hotend and bed heaters around and report the temperatures?
                  • nhofundefined
                    nhof
                    If it indicates 9000 degrees then it's probably a short rather than thermistor values being off. NTC means resistance goes down as temps go up. A short is essentially 0 resistance so it will read an unnaturally high value. Check the leads coming out of the thermistor as those are the usual suspects.
                    You can generate your own beta values using a table and a calculator like so: https://www.ametherm.com/thermistor/ntc-thermistor-beta
                    • Vetiundefined
                      Veti @BearcatTD
                      @bearcattd
                      if thats the table for your thermistor then yes. if its a random one you found, prob not.
                        dc42 administrators @BearcatTD
                        I actually just took the thermistor out of the heater block and it immediately went down to "Normal" range...24ishC. When I put it back into the block and started to tighten the retaining screw, it shot back up to 9000c . Methinks there might be a short.
                        I agree, there is a short. Is it a cartridge thermistor or a bead thermistor?
                          BearcatTD @dc42
                          It is a bead therm. I replaced the one that was bad and wired in the second one. the weird thing is, is that if I tighten down the retaining screw the temp goes crazy. so right now i have it loosely tightened (if that makes any sense) and things are working great!!
                          • Vetiundefined
                            Veti
                            put some nylon spacer in between.
                              dc42 administrators @Veti
                              @veti said in Hot end / thermistor problem:
                              I doubt that Nylon will withstand the temperature of the heater block. I suggest some new glass fibre sleeving. Or change the heater block for one that accepts a cartridge thermistor.
