    Z-probe triggers way above table during HOME ALL
    2.2k
    • Billsrfundefined
      Billsrf
      If I am not using a bed compensation. Why would that be making my trigger so high off my build surface? It moves down about 20 mm then triggers during home.all. But, if i do a home.z afterwards it moves to the correct trigger height and it is ready to go
      www.dpp3d.com , pellet fed large format 3d printers
        Have you gone through these steps?
        https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
        Billsrfundefined 1 Reply Last reply Reply Quote 0
        • Billsrfundefined
          Billsrf
          yes 9 times. I will change the offsets and then go through the probe set up again
          • Billsrfundefined
            Billsrf
            @dc42 went through the same set up process as described in test and calibrate Z probe, same results as before, it moves down 10 mm then triggers then stops. I did nottice, as it is moving towards the X-Y home position, the IR sensor flashes 3 times like it is just initialized. Never done that before either.
            • Billsrfundefined
              Billsrf @Phaedrux
              @phaedrux went through the same set up process as described in test and calibrate Z probe, same results as before, it moves down 10 mm then triggers then stops. I did nottice, as it is moving towards the X-Y home position, the IR sensor flashes 3 times like it is just initialized. Never done that before either.
              • Billsrfundefined
                Billsrf
                Tried running a G29 and this is what I am getting back now. I have never had this kind of issue with my duet3d before. its triggering during moves.0_1555968974806_G29 Probing.JPG
                  Is the sensor on the IR probe dirty or damaged at all?
                  Billsrfundefined 2 Replies Last reply Reply Quote 0
                  • Billsrfundefined
                    Billsrf @Phaedrux
                    @phaedrux No, i have even swapped it out with a new probe and it does the same thing!! I am baffled!!! to say the least. As you can see it won't run a G29 anymore either
                    • Billsrfundefined
                      Billsrf @Phaedrux
                      @phaedrux I have another Duet3d wifi board, I am going to swap it out in the morning and reload my firmware and see if that does it
                        Can you post your config.g as it is now?
                        • Billsrfundefined
                          Billsrf @Phaedrux
                          @phaedrux 0_1555973203011_config.g
                          • Billsrfundefined
                            Billsrf @Phaedrux
                            @phaedrux 1_1555973271826_homez.g 0_1555973271825_homeall.g
                              That all looks right to me.
                              Do you have anything weird in config-overide.g?
                              • Billsrfundefined
                                Billsrf @Phaedrux
                                @phaedrux 0_1555973721313_config-override.g 0_1555973742894_bed.g
                                  That all looks fine as well.
                                    Firmware version?
                                    Double check wiring? Bad crimp? Clean the sensor with some isopropyl?
                                    • Billsrfundefined
                                      Billsrf @Phaedrux
                                      • Billsrfundefined
                                        Billsrf @Phaedrux
                                        @phaedrux do you have a link to the latest update?
                                          https://github.com/dc42/RepRapFirmware/releases/tag/2.02
                                          • Billsrfundefined
                                            Billsrf @Phaedrux
                                            @phaedrux thank you, I will update today and check for hardware issues
