    Z-probe triggers way above table during HOME ALL
    2.2k
    • Billsrfundefined
      Billsrf
      after home.all, I can push HOME.Z and it moves to the bed and sets the correct nozzle height
      www.dpp3d.com , pellet fed large format 3d printers
      • Billsrfundefined
        Billsrf @Phaedrux
        @phaedrux i have the offset Z trigger height set to zero for testing. What should the X-Y settings be for the G31? isnt it center of my build plate?
          Phaedrux Moderator @Billsrf
          @billsrf The X and Y values for G31 should be the distance of the probe from the nozzle. Just as the Z value is the distance from the probe to the nozzle tip in Z.
          If the probe is to the left, the value will be -x.
          If the probe is to the right, the value will be +x.
          If the probe is to the front, the value will be -y.
          If the probe is to the back, the value will be +y.
          Billsrfundefined 1 Reply Last reply Reply Quote 0
          • Billsrfundefined
            Billsrf
            my BED.G looks like it is missing a lot of information now for some reason. 0_1555961191732_bed.g
              It looks like your bed.g is currently setup to just do a mesh grid compensation run.
              • Billsrfundefined
                Billsrf @Phaedrux
                @phaedrux ok, i will measure the offset and change that in the G31 in config.g
                • Billsrfundefined
                  Billsrf
                  If I am not using a bed compensation. Why would that be making my trigger so high off my build surface? It moves down about 20 mm then triggers during home.all. But, if i do a home.z afterwards it moves to the correct trigger height and it is ready to go
                    Have you gone through these steps?
                    https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
                    • Billsrfundefined
                      Billsrf
                      yes 9 times. I will change the offsets and then go through the probe set up again
                      • Billsrfundefined
                        Billsrf
                        @dc42 went through the same set up process as described in test and calibrate Z probe, same results as before, it moves down 10 mm then triggers then stops. I did nottice, as it is moving towards the X-Y home position, the IR sensor flashes 3 times like it is just initialized. Never done that before either.
                        • Billsrfundefined
                          Billsrf @Phaedrux
                          @phaedrux went through the same set up process as described in test and calibrate Z probe, same results as before, it moves down 10 mm then triggers then stops. I did nottice, as it is moving towards the X-Y home position, the IR sensor flashes 3 times like it is just initialized. Never done that before either.
                          • Billsrfundefined
                            Billsrf
                            Tried running a G29 and this is what I am getting back now. I have never had this kind of issue with my duet3d before. its triggering during moves.0_1555968974806_G29 Probing.JPG
                              Is the sensor on the IR probe dirty or damaged at all?
                              Billsrfundefined 2 Replies Last reply Reply Quote 0
                              • Billsrfundefined
                                Billsrf @Phaedrux
                                @phaedrux No, i have even swapped it out with a new probe and it does the same thing!! I am baffled!!! to say the least. As you can see it won't run a G29 anymore either
                                • Billsrfundefined
                                  Billsrf @Phaedrux
                                  @phaedrux I have another Duet3d wifi board, I am going to swap it out in the morning and reload my firmware and see if that does it
                                    Can you post your config.g as it is now?
                                    • Billsrfundefined
                                      Billsrf @Phaedrux
                                      @phaedrux 0_1555973203011_config.g
                                      • Billsrfundefined
                                        Billsrf @Phaedrux
                                        @phaedrux 1_1555973271826_homez.g 0_1555973271825_homeall.g
                                          That all looks right to me.
                                          Do you have anything weird in config-overide.g?
                                          • Billsrfundefined
                                            Billsrf @Phaedrux
                                            @phaedrux 0_1555973721313_config-override.g 0_1555973742894_bed.g
