    Duet wifi stepper noise in signal
    38
    3.1k
    • Retundefined
      Ret
      So, in other-words, yours looks similar to that and its normal?
      • zaptaundefined
        zapta @Veti
        @veti said in Duet wifi stepper noise in signal:
        https://www.trinamic.com/fileadmin/assets/Support/Appnotes/AN001-spreadCycle.pdf
        "Hissing or chirping chopper noise can be annoying. Especially in motor standstill, many applications
        are required to be silent. While the latest TRINAMIC drivers support stealthChop for absolutely silent ..."
        I can't wait to give it a try. It's noticeable when steppers are stationary.
        • Danalundefined
          Danal
          Is your old Duet for sale?
          • Vetiundefined
            Veti @zapta
            @zapta said in Duet wifi stepper noise in signal:
            on the duet maestro where stealthchop2 is supported at low speeds you dont even hear the movement.
            on my delta the fan makes the most noise.
            • Vetiundefined
              Veti
              @Ret Can you post a picture of the bad prints the duet is producing?
                config file too?
                  And maybe a sample of sliced gcode? Which slicer? Is it set to reprap gcode flavour?
                  • Retundefined
                    Ret
                    Here is my config. Just to let you all know, I manage a print farm with custom and commercial desktop FDM printers, so I’m not anywhere near new to printing. I have them all tuned and printing very well, but they’re running marlin, repetier, and smoothie.
                    The big issues I’m still having is rough movement from the printer and a poor rough top layer where the extruder fills a 2-7mm section. Both of these issues (from experience) are normally related to jerk and acceleration, yet I have tried nearly every single possible combination with results not getting much better from the last test ran. I've tried tuning pressure advance and it helps, but needs a value of about 0.75 to smooth out that top layer, but trashes the rest of the print. I also get uneven extrusions, and different print results from running the same gcode right after the first. To throw in, I’ve tried S3D, Cura, slic3r, idea maker, and Pathio, all horrible results. I’ve still not gotten an answer to this post regarding the very strange jittery and noisy stepper signal. Yes, the drivers manipulate the signal, but does mine look at all similar to any of yours? To be clear, I’m not talking about audible noise, I’m referring to noise in the signal. Seems like a couple of you may have drifted from that.
                    About a year ago I started THIS thread. My config file has been changed since then, but results haven’t gotten much better, a year ago.
                    OEM setttings for marlin:
                    #define DEFAULT_MAX_ACCELERATION {900,1000,30,2000}
                    #define DEFAULT_MAX_FEEDRATE {200, 200, 25, 25}
                    #define DEFAULT_XYJERK 4.0
                    #define DEFAULT_ZJERK 0.4
                    #define DEFAULT_EJERK 1.0
                    These images reflect the gcode.
                    1_1556294322049_simple_boat5.gcode 0_1556294322048_config.g
                    Retundefined DocTruckerundefined 2 Replies Last reply Reply Quote 0
                    • Retundefined
                      Ret @Ret
                      Here are the images:
                      • Vetiundefined
                        Veti
                        @ret said in Duet wifi stepper noise in signal:
                        Makergear M2
                        where did you get the values for the M305 from?
                        From what i can see in their firmware both hed and thermistor are the same.
                        yet your config has different values.
                        also those values do not correspond to the marlin thermistor 1 values.
                        • Retundefined
                          Ret
                          The bed and hotend thermistor are in fact the same model. I did try with the equivalent thermistor settings from marlin, but went further on tuning them.
                            I don't know about the motor signal noise. @dc42 would have to weigh in there.
                            From your config.g though your jerk values seem very low.
                            M566 X240 Y240 Z30 E120
                            Remember those values are mm/min not mm/s for reprap. Though it looks like you're just using the values from marlin. However, the way jerk works between the two isn't necessarily the same if I recall. Certainly not the same when it comes to the extruder and how jerk interacts with pressure advance. Not to mention how Z jerk can interact with mesh grid compensation.
                            Try M566 X900 Y900 Z120 E6000
                            I know that for me, with X and Y jerk values that low the quick back and forth zig zag moves slow down way too much and ends up oozing a lot leading to the rough surface like in your picture.
                              The only good way to tell if the stepper driver is supplying the correct waveform to the stepper motors is to use a current probe in series with one of the windings. Modern stepper drivers use various techniques to reduce EMI and, achieve accurate low current microstepping, and to implement advanced features such as stealthchop.
                              • Retundefined
                                Ret
                                @Phaedrux I'm aware of the units. I initially copied over the exact (converted) units from marlins FW, with no success. I've tried more duet printer standard accel and jerk like yours and it doesn't improve anything. I printed the little boat again with your exact jerk settings and it turned out worse than with the low jerk and accel. The makergear is a very solid printer, but its not designed for very high speeds, accel, and jerk. Any other suggestions?
                                • botundefined
                                  bot
                                  Can you show us a comparison of two photos of prints, one showing the effects you're trying to correct and another that doesn't show these effects, ideally printed on the same printer?
                                  The prints you have shown don't look amazing, but they don't look bad. I would hesitate to implicate anything other than different settings exciting mechanical errors in different ways.
                                  *not actually a robot
                                  • Retundefined
                                    Ret
                                    @bot I ran out of white, but this is the same sliced settings, printed on my rambo, just modified the jerk and acceleration gcode commands and format. You can clearly see the difference between the two, and that's not even using my normal RAMBO slicing settings, that's using the settings that work the best on the duet, but are still not good.
                                    • botundefined
                                      bot @Ret
                                      @ret
                                      That was printed on the exact same printer? I do see a difference, and it seems related to the extruder axis IMO. Would you agree?
                                      Can you post the accel, jerk, and speed settings you are using in marlin, and then post what settings you used on the duet? Please include the values for the extruder axis.
                                        How confident are you in the accuracy of your thermistor values?
                                        M305 P1 T100000 B4138 C0 R4700
                                        The white one does look kind of over extruded, but that could also be from printing too hot?
                                        • Retundefined
                                          Ret
                                          @bot yes, same printer. I copied the exact same values used in the gcode I posed, just converted them from reprap firmware to marlin, and converted the units where needed. At this point im not quite sure what to think. If i was trying to debug someone else having this issues, id probably agree with you about extruder, but from my perspective, it doesn't make sense at all. Reducing flow on the duet only minimizes the problem proportionally and ruins the rest of the part, so it seems its not flow.
                                          @Phaedrux ---I'm pretty confident in the accuracy since its what I used in marlin as well for a little bit. To be honest, I made the changes long ago and reverted them back to defaults and see no difference in quality at all. PLA has such a wide range of printing temperatures that it must have just been okay.
                                          • botundefined
                                            bot @Ret
                                            [...] I copied the exact same values used in the gcode I posed, just converted them from reprap firmware to marlin, and converted the units where needed. [...]
                                            Jerk does not work the same way as in marlin, afaik. IIRC, you essentially have to use half the jerk value in RRF than you do in marlin. This is because, and my memory might be failing me here, marlin uses half the jerk value as the start/stop speed, and the jerk value itself is used for cornering speeds or something.
                                            Anyway, it's obvious that copying and pasting the settings isn't working, so you should start trying different values to see what changes things.
