    BL Touch Flashing
    1.4k
    • WILLYD3113undefined
      WILLYD3113
      How Should I modify the config file, and I tightened and loosened the screw but saw no effect(what am I looking for?)
        WILLYD3113
        The BL doesn't respond M401 or M402 also and the flashing doesn't stop.
        • Vetiundefined
          Veti
          From the linked document you can see the command to use is M280 with the parameters for your connection and the command to execute.
          Also for M557 you need to define the area of your bed where the probing is allowed.
          this depends on the location of your probe etc.
          You could also use the configurator which calculates these things for you.
          configurator.reprapfirmware.org
            WILLYD3113
            The BL touch is now solid red and will test when It turns on but I cannot get it to deploy or retract.
            • Vetiundefined
              Veti
              if you cant get it working by adjusting the grub screw you will have to go in deeper.
              see https://www.youtube.com/watch?v=wq5QmN-MIJA
                WILLYD3113
                New Config:
                ; generated by RepRapFirmware Configuration Tool v2 on Tue Apr 30 2019 09:39:22 GMT-0500 (Central Daylight Time)
                M550 P"PussySlayer" ; Set machine name
                M552 S1 ; Enable network
                M587 S"11818e" P"endless.955.drift" ; Configure access point. You can delete this line once connected
                M586 P0 S1 ; Enable HTTP
                M586 P1 S0 ; Disable FTP
                M586 P2 S0 ; Disable Telnet
                M569 P0 S0 ; Drive 0 goes backwards
                M350 X256 Y256 Z256 E256 I0 ; Configure microstepping without interpolation
                M92 X1280.00 Y1280.00 Z6400.00 E6790.61 ; Set steps per mm
                M566 X900.00 Y900.00 Z12.00 E120.00 ; Set maximum instantaneous speed changes (mm/min)
                M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; Set maximum speeds (mm/min)
                M201 X500.00 Y500.00 Z20.00 E250.00 ; Set accelerations (mm/s^2)
                M906 X1200.00 Y1200.00 Z1200.00 E1600.00 I0 ; Set motor currents (mA) and motor idle factor in per cent
                M84 S30 ; Set idle timeout
                M208 X220 Y220 Z220 S0 ; Set axis maxima
                M574 X1 Y1 Z1 S0 ; Set active low and disabled endstops
                M307 H3 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
                M558 P9 H5 F120 T6000 ; Set Z probe type to bltouch and the dive height + speeds
                G31 P500 X0 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height
                M557 X10:210 Y10:210 S25 ; Define mesh grid
                M307 H0 B0 S1.00 ; Disable bang-bang mode for the bed heater and set PWM limit
                M305 P0 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 0
                M305 P1 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1
                M106 P0 S1 I0 F500 H T10 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
                M106 P1 S0 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
                M563 P0 D0 H1 ; Define tool 0
                ; Custom settings
                M307 H3 A-1 C-1 D-1
                M558 P9 H5 F100 T2000
                G31 X0 Y0 Z0 P25
                M501 ; Load saved parameters from non-volatile memory
                Deploy probe:
                ; deployprobe.g
                ; called to deploy a physical Z probe
                M280 P3 S10
                Retract Probe:
                ; retractprobe.g
                ; called to retract a physical Z probe
                M280 P3 S90
                  WILLYD3113
                  The interface reads 0 and the BL is solid red(turns off when I pull out the probe) and it does a few test clicks when I turn on the printer but any attempt to deploy or retract goes through the console fine but the BL doesn't do anything.
                    @willyd3113 said in BL Touch Flashing:
                    Deploy probe:
                    ; deployprobe.g
                    M280 P3 S10
                    Retract Probe:
                    ; retractprobe.g
                    M280 P3 S90
                    See https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_Software_setup_Duet_2_WiFi_Ethernet. You need to add the i1 parameter to your M280 commands. Then test M401 and M402 again.
                      WILLYD3113
                      All is working! Thanks Guys!
                        WILLYD3113
                        Hey Guys I'm finding a weird issue with the probe. Ive set the probe as my Z Endstop now and I've configured the offset countless times but it doesn't seem to change where the printer thinks zero is. I will set the offset to 0, manually configure where Zero is G92, and run G30 S-1. The printer after restarting then homes when I command it to then goes to z = 5.0 but its really more like 8- 10 and I have no clue why. I've read the BeTrue article and can't figure it out.
                        Here's my Config:
                        ; generated by RepRapFirmware Configuration Tool v2 on Mon May 06 2019 22:38:59 GMT-0500 (Central Daylight Time)
                        M550 P"Mods Suck" ; Set machine name
                        M566 X1800.00 Y1800.00 Z24.00 E240.00 ; Set maximum instantaneous speed changes (mm/min)
                        M203 X12000.00 Y12000.00 Z360.00 E2400.00 ; Set maximum speeds (mm/min)
                        M201 X1000.00 Y1000.00 Z2040.00 E500.00 ; Set accelerations (mm/s^2)
                        M906 X1200.00 Y1200.00 Z1200.00 E1700.00 I0 ; Set motor currents (mA) and motor idle factor in per cent
                        M574 X1 Y1 S0 ; Set active low and disabled endstops
                        M574 Z1 S2 ; Set endstops controlled by probe
                        M558 P9 H10 F120 T6000 ; Set Z probe type to bltouch and the dive height + speeds
                        G31 P25 X15 Y20 Z3.4 ; Set Z probe trigger value, offset and trigger height
                        M557 X10:200 Y10:200 S30 ; Define mesh grid
                        ; Custom settings
                        M307 H3 A-1 C-1 D-1
                        G31 X0 Y0 Z0 P25
                          dc42 administrators @WILLYD3113
                          G30 S-1 measures the trigger height, but doesn't do anything with it apart form report it. See https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Calibrate_the_Z_probe_trigger_height.
                            WILLYD3113
                            After Probing with G30 S-1 I take that height and plug it into the G31 line of config file, forgot to mention.
                            chriskimbrundefined 1 Reply Last reply Reply Quote 0
                            • chriskimbrundefined
                              chriskimbr @WILLYD3113
                              @willyd3113 Ive done this countless times and it doesn't seem to effect where the bed/nozzle is. Mine still prints too far off the bed.
                                WILLYD3113
                                Is it like 4 to 5 mm away from bed even at z=0? @chriskimbr
