    Core-XY based on Rat Rig V-Core and Duet 2 Ethernet
    My Duet controlled machine
    15
    176
    27.0k
    • snoozerundefined
      snoozer @Phaedrux
      @phaedrux oh that sounds interesting now, you mean I could use a different M574 in a macro then the M574 I have used in config.g ? If that's possible I just need to put the z 0 and z max end stops in series and can make use of them on both ends or even try stall detection in my macro that brings the bed to z max. I must read the link regarding "Bed levelling using multiple independent Z motors". To late now for that, bed time.
      Thanks for the valuable input !!!
      Jan
      Regards Jan
      My Printers:
      #1 Prusa i3 MK3 kit all stock (Retired)
      #2 Rat Rig V-Core Core-XY (Almost finished but fully usable)
      My Experiments:
      https://www.thingiverse.com/snoozer17/designs
        Yes that's right. You can treat the config.g as the default settings that are applied at startup. Pretty much every command can be issued at any time to change a setting. So in your macro files for various things like homing, etc, you can reconfigure things right when you need it.
        So in your homing macro you could have the Z probe configured (M558, G31, and G30 to probe) and use it to find Z0, then you could use M574 to define a Zmax endstop and use G1 S3 Z400 (Note teh S3) to seek the Zmax endstop and when it triggers, set the Z axis maxima (M208) to be equal to the current Z height (which you know, because you established Z0 first). And then save it to config-override.g with M500 P31. You've now automatically established the length of your Z axis.
        In that example, if you weren't using a Z probe yet, you could substitute the probe commands for the M574 Zmin commands and home to Zmin using the endstop first.
        Note that this method won't help after a power loss. In that case, you'd need to use the method I described earlier where you set the Z axis length precisely ahead of time, so that homing to zmax will give you a predefined known value.
        Here are some example macros that may help explain the concept.
        2_1557290592240_PrimeNozzle.g
        1_1557290592239_start.g
        0_1557290592239_homeall.g
        0_1557290612902_2_HomeZMax.g
        0_1557290636906_0_Measure Zmax trigger.g
        Just examples of what's possible. Things can be as simple and basic, or as specific and involved as you like.
        snoozerundefined 2 Replies Last reply Reply Quote 0
        • snoozerundefined
          snoozer @Phaedrux
          @phaedrux That's great to know how I could make it work. I am not worried to have z max that precise since I can now have both z max and z 0 end stop or the combination of z probe and z max end stop. Since I do know the physical dimensions when at z max I can fast move close to z 0, say 10mm off and probe at slower speed from there.
          Thanks very much
          Jan
          Regards Jan
          My Printers:
          My Experiments:
          • snoozerundefined
            snoozer @Phaedrux
            @phaedrux I was just looking through the g-code you linked. I do get the idea, I see how you use M574 in the homezmax.g. Till you mentioned it I did not realise this can be done outside the config.g and change "on the fly". I also see you used M291 a bit. I assume that works in DWC as well as on the PanelDue ?
            Jan
            Regards Jan
            My Printers:
            My Experiments:
              Phaedrux Moderator @snoozer
              @snoozer said in Core-XY based on Rat Rig V-Core and Duet 2 Ethernet:
              That's right. A popup window will come up in the DWC.
              • snoozerundefined
                snoozer
                I got a bunch more done now. I have moved the z end stop to the z max end and installed an inductive probe for now till I have a piezo probe to go. Had to modify my bed mount as well, I was to worried about losing height on the extruder and it was higher than the bed can reach without losing a few turns on the lead screws. Had to raise the springs a little. The bed for now is the original that came with the printer. Its OK actually. The heater is a adhesive silicone mat with a pretty good wiring harness in a thick silicone tubing. I have made some strain relieve to prevent pulling on the heater when the bed moves. Its a 24V supposedly 300W but in reality more 280 looking at the current it draws. I was surprised how long it take to heat up. I guess I am spoiled with the Prusa. I had it going for a couple hours at 60 degree to start and went to 120 in the end which took for ever. That's all acceptable for the moment but definitely not a solution in the long run. I was super disappointed with the spring steel sheet that I got from Amazon I think it was. Once I had applied the PEI sticker it would no longer lay flat. I guess I should have pre bend it slightly cause it looks as if the PEI is pulling the edges up. Its also very thin, not anything like the Prusa one. Its basically unusable. The last observation I made was the difference is probing distance for my inductive probe between the aluminium, bed and spring steel. Without the steel and only aluminium the probe barely triggers before digging the nozzle in. The probe is then so low that I worry about proximity to a print. With the spring steel that approx 1.5mm better. That surprised me a little, did not expect just big difference.
                I had no go on macros yet or making use of the z max switch, that's on the agenda for next week. Also trying to find better spring steel with PEI and a piezo probe cause I want to be able to print on glass as well.
                Here a few pics of today.
                Regards Jan
                My Printers:
                My Experiments:
                • snoozerundefined
                  snoozer
                  Just a quick add on, an impression of the fast non print move speeds I get so far.
                  https://youtu.be/PBN2l-wafVY
                  Regards Jan
                  My Printers:
                  My Experiments:
                    dc42 administrators @snoozer
                    That's noisier than I expect from a Duet. What stepper motors are you using, and at what current and microstep setting (M906 and M350 commands in config.g) ?
                    snoozerundefined 1 Reply Last reply Reply Quote 0
                    • snoozerundefined
                      snoozer @dc42
                      @dc42 Hi,
                      My settings are here:
                      M350 X16 Y16 Z16 E16 I1
                      M906 X900.00 Y900.00 Z1500.00 E800.00 I1
                      I have not yet done anything with the extruder cause I don't yet have a good bed solution. The motors I have on X,Y and Z are 0.9 degree rated at 1.7A.
                      0_1557734771912_MT-1704HSM168A-RevA-100cm-wires.pdf
                      Regards
                      Jan
                      PS: The noise in the Z axis is MUCH more intense in the video than in reality, I believe I had the bed resonating with the bolts holding it as well.
                      Regards Jan
                      My Printers:
                      My Experiments:
                      • Vetiundefined
                        Veti
                        why are you running X and Y at 900mA if the steppers are 1.7A?
                        also you are moving your Z axis at a very high speed. what is the sound at a more reasonable speed of 6-10mm/sec?
                        • snoozerundefined
                          snoozer
                          I have not fully fine tuned the stepper settings yet cause I am not yet at a stage where I actually print. Getting to grips with mechanical issues and macros, end stops, probes etc...... From what I have read and what makes logical sense to me is that there is no need to drive the steppers with the highest rated current but rather find a sweet spot between desired torque and needed current, I could probably reduce that even further but I just did not yet get around giving it a good test. If I move everything at slow speeds like the Prusa does by default I hardly hear anything little background wine. The Prusa would be louder. One of my main concerns was the time it takes to move Z from 0 to max. On this particular build because its not as freely accessible like most Cartesian printers I like to have the bed move quick to Z max for ease of access. That's also the reason for playing around with z probe for z 0 and end stop for z max so I can do quick moves but yet have the ability to home to 0 for the last 5mm at slow speed since I know the dimensions. In general I think its my mindset to move all axis as fast as possible without losing steps or causing mechanical damage on non print moves. Power consumption and noise are not really issues for me. Having that said, I obviously don't have the experience yet to know what is the limit 😉 but I am not losing steps with my set up as it is for now and I have no rubber dust from the belts.
                          Thanks
                          Jan
                          Regards Jan
                          My Printers:
                          My Experiments:
                          • snoozerundefined
                            snoozer
                            I have ran the bed leveling a few times now to see where I am re bed adjustments. Its the 1st time that I did that now after having the Z probe working. Once its done the probing I get the overemphasized graphical representation of the bed. The bed and the probed view are on a different plain level. The probed bed is approx 5mm below the ideal bed. Is that an issue with some offset that I have not taken care of or is that the difference due to position from homing to z0 and then probing at a much slower speed.
                            Thanks
                            Jan
                            Regards Jan
                            My Printers:
                            My Experiments:
                            • Vetiundefined
                              Veti
                              thats the difference between your height and your actual height as measured by your z probe.
                              if you have a fixed probe having a z max endstop does not make much sense in my opinion.
                              • snoozerundefined
                                snoozer @Veti
                                @veti The end goal is to be able to turn on the printer, move quick to Z max without the need to home to z 0 because I may still have a print on the bed or what ever. This way I can have a macro to move fast to z max, do what ever is needed and then move to z 0 +5mm and go slow from there to probe for z 0. That's the idea behind it but as I said, I am still in the process of learning and finding good ways to mount end stops, probes etc..... Piezo probe on the top of my list now..... redesign extruder mount etc..... plenty of playing around to do 😉 I don't even know if I leave it at micro switches or rather change to optical or other ways for homing. The smaller and lighter the better, contactless probably ideal.
                                Jan
                                PS: I have just read this and flew over the write up:
                                https://forum.duet3d.com/topic/7948/external-triggers
                                I love the idea of actual buttons. That would be even better if I get that to work without the need of interacting on DWC for certain things such as "Go to Z max fast" or load and unload filament.
                                Regards Jan
                                My Printers:
                                My Experiments:
                                • snoozerundefined
                                  snoozer
                                  While I was playing around this WE I figured out that my cable management leaves a lot to desire. The Duet mount IS temporary, that will go on a metal sheet which will also be the rear wall of my printer in the final set-up. My worry is the harness from the frame to the head. I was hoping the PTFE tube for the filament guide would provide enough strength to support the harness in a nice arch from frame to head but it does not. I dislike cable chains when used hinge side up, it is not meant to be used that way in my opinion. So I am thinking of sliding contacts or a compressions coil spring long enough to form an arch from the frame to the head to use in the same way people use the normal plastic wire wrap stuff. I am ofc not finding such a spring. Has anybody solved this issue somehow nice and neat without support from the top (hanger for harness) ? Any other good solutions that people use ? Just trying to gather ideas that people have for this issue.
                                  Jan
                                  Regards Jan
                                  My Printers:
                                  My Experiments:
                                    deckingman @snoozer
                                    @snooze Flexible conduit might be what you need - like the picture in this link https://www.toolstation.com/conduit-ducting/p92502?store=JC&utm_source=googleshopping&utm_medium=feed&utm_campaign=googleshoppingfeed&mkwid=sgsL3oOy9_dc&pcrid=142003768299&pkw=&pmt=&product=92502&gclid=CjwKCAjwq-TmBRBdEiwAaO1en8lu35EdHtSVejabt_2pdkSxZ_-XAWPJxwIb8iPoU_FfJddLwLAyjRoCwSEQAvD_BwE
                                    Fix the ends securely to the frame and print carriage.
                                    • snoozerundefined
                                      snoozer @deckingman
                                      @deckingman I was looking at conduit like that. I am not confident it will stay up and its a lot of drama to add wires etc. after initial installation. I have seen these kind of kitchen water taps with the coil to hold them.
                                      https://www.google.ie/search?q=küchenarmatur+spiralfeder&source=lnms&tbm=isch&sa=X&ved=0ahUKEwj6_NWWyJjiAhU7TxUIHcjSCcIQ_AUIDigB&biw=1379&bih=804
                                      I have to check what length they are and inside diameter. Weight might be an issue here. I am probably thinking way to fancy..... maybe a simple spring steel rod bundled together with the plastic wrap or inside a PTFE tube and wrapped in with that would be simpler and just as effective.
                                      Regards Jan
                                      My Printers:
                                      My Experiments:
                                        deckingman @snoozer
                                        @snoozer Something like that might work too. I use cable chain on it's side which isn't ideal but it's OK. The type I use can be opened up which makes it easier to add another conductor should that be necessary (I have about 40 conductors going to my carriages from the frame because I have 5 extruders that move, plus heaters, lights, end stops, a probe, fans etc.
                                        You can buy split flexible conduit too, that can be opened up.
                                        If I used conduit or a spring such as you describe, I'd find some way to support the end some distance above the centre of the bed, rather than a loop from the frame. So the carriage just has to "drag" the end around but it doesn't have to take the weight.
                                        Just a tip if you do go that route with conduit or a spring type thing (spiwrap might work too but it's a bit stiff), work out how many conductors you need including heaters, fans, lights, ends stop switches and anything else you can think of, then add a couple more "just in case". It's a lot easier to feed them all in as a bundle taped together here and there, than it is to add another conductor at a later date.
                                        • snoozerundefined
                                          snoozer @deckingman
                                          @deckingman I try to avoid the need of support from above if I can. The idea is that I can have a full acrylic made hood on top without any further obstructions to keep the heat in but easy access if needed. Sure If I find no other way I can also make a support frame on top. Re wiring, I am nowhere near to a final setup yet but I have added a spare 4 core cable with Dupont connectors just in case, so I don't have to rip it apart for everything I like to test.
                                          Are you actually using shielded cable on your machine ? Just wondering if you had issues with noise from the stepper motors and probes etc ? The cables that came with the motors are non shielded which I actually don't like so much.
                                          Jan
                                          Regards Jan
                                          My Printers:
                                          My Experiments:
                                            deckingman @snoozer
                                            No and No - (with a couple of caveats). I twist the motor wires but they are unshielded. I'm not sure of the source but I used to get a noisy signal when I used a PT100 on my bed. Not much but enough that the temperature reading had about +_ 0.5 degree "oscillation" in the signal. However, this happened regardless of whether the motors were moving or not so I doubt that the motors were the cause. Changing the PT100 to a simple thermistor fixed the problem.
