New firmware 2.03RC1 available
Prints can now be baby stepped, paused and cancelled while they are waiting for temperatures to be reached
Nice, was going to make a suggestion on the baby stepping - nothing better than getting beaten to it in this case:)
No phase disconect reports on Duet Maestro. Thanks
I've updated a couple of the 12864 menu files to cope with the changes in 2.03RC1
As usual they are in https://github.com/mudcruzr/Duet-Maestro-12864-Menu-Files
2 Files required updates to cope with the changes in 2.03RC1
The new files are main_for_203RC1 and heat_for_203RC1
Upload the 2 new files, rename the existing heat and main to something like heat_backup and main_backup then rename the 2 new files to heat and main respectively.
Note these files are ONLY for using with 2.03RC1
@stephen6309 said in New firmware 2.03RC1 available:
@dc42 Nope, it's not fixed. Fixed (hopefully - not tested!) issue with Fan 1 on Duet085 in 2.03 beta releases
I've just updated the RepRapFirmware.bin file in this release to version 1.24RC1+1 which fixes that problem.
@dc42 It's fixed.
unfortunately theres no change in the behaviour of M291 during a tool change, the message comes up at the instance the m291 is called but the tool change will continue until its finished
deleting comment -- I was using the wrong RRFLibraries, compiles fine now -- will try it later to see if i2c is improved
I've just released 2.03RC2 at https://github.com/dc42/RepRapFirmware/releases/tag/2.03RC2 so I will lock this thread.
