    Duet Web Control 2.0.0-RC6
    Duet Web Control
    35
    64
    11.2k
      Phaedrux Moderator @Vlad
      @vlad Did you even try what I suggested?
      Vladundefined 1 Reply Last reply Reply Quote 0
      • thweundefined
        thwe @Vlad
        @vlad said in Duet Web Control 2.0.0-RC6:
        … Looks like duet can't see that now index is in "public" subfolder ...
        … I can open the public.html file ...
        1. there is no "public" folder
        2. there is no "public.html"
        This is how the structure looks on the (my) sd card:
        … and the subfolder "www"
        After what I've read from you everything, I can imagine where the problem sits: it sits in front of your screen. So first restore the original structure and test it again
        ... Why couldn't this be taken care of by DUET team instead of me now having to do their job again ... Why everything has to always be so half-assed…
        I think you do not only need help with dealing with the duet, also in the topic of courtesy and politeness there is pent-up demand
        Thomas
        • Vladundefined
          Vlad @Phaedrux
          @phaedrux of course I did. Why would I say that it didn't work?
          • Vladundefined
            Vlad @thwe
            @thwe yeah, this is how my V1.12 looked like, before I loaded that file. Zip file has public folder etc. Again duet3D leave us to wonder what to do. Zero clear manuals for years...
            • frank26080115undefined
              frank26080115
              99% sure Vlad uploaded the source code zip file instead of the release zip file
              whosrdaddyundefined 1 Reply Last reply Reply Quote 1
                For anyone else new to DWC2 who is having issues with it, here is some guidance.
                1. DWC2 and DWC1 can coexist on the same SD card, because they use different files. The main page for DWC1 is reprap.htm. For DWC2 it is index.html. When you enter the Duet's IP address in the brower, firmware 2.02 and later will return index.html if it is present, otherwise reprap.html. So you can force DWC1 to load by appending /reprap.htm to the IP address in your browser tab, or by deleting or renaming index.html so that it is not found.
                2. DWC2 puts more stress on the network system when loading than DWC1 did, and this exposed a bug in DuetWiFiServer 1.21. So if using a Duet WiFi, you should upgrade DuetWiFiServer to version 1.23.
                • whosrdaddyundefined
                  whosrdaddy @frank26080115
                  @frank26080115 : yep he did, and being a halfass towards others isn't going to help him...
                  • robmundefined
                    robm
                    Sorry I am a bit late to the party but here are some comments/issues:
                    • The active temperature drop-down menu was truncating the values until I did a 'command -' to zoom out one step. This is fine but there was still lots of space around the elements, and more if I dragged the window wider.
                    • I don't have an ATX power supply configured, can I make that control go away?
                    This is on a 2012 MacBook Pro retina, running Firefox.
                    Otherwise looks very nice. I thought the ability to edit the drop-down list of g-codes on the top bar had gone away, but I worked it out and prefer this newer implementation.
                    Very happy to see the continued development.
                    Rob.
                    • wilrikerundefined
                      wilriker
                      @chrishamm I found another issue. I have a macro that works a bit like G32 with no probe, i.e. it goes to several points and then presents the jog dials for Z.
                      In previous versions it was only possible to press reach jog button once but that has been fixed.
                      Now I have a new issue where the dialog is only shown at the first point. If I click on OK there the head moves to the next point but no dialog is shown. Switching to DWC1 immediately presents the dialog and all following. I did not try to reload DWC2 to see what happens, though.
                      Manuel
                      My Tool Collection
                      • chrishammundefined
                        chrishamm administrators @wilriker
                        @wilriker said in Duet Web Control 2.0.0-RC6:
                        That bug was related to the message boxes in general and it has been fixed in RC7.
                        Duet software engineer
                        Catalin_ROundefined 1 Reply Last reply Reply Quote 1
                        • Catalin_ROundefined
                          Catalin_RO @chrishamm
                          @chrishamm When will there be a RC7 package available for download? So far I can only find up to RC6 ZIP files.
                            A Former User
                            @chrishamm
                            looks good as far as I can tell! (took me a while to copy it to the sd-card - 🙂 )
                            1 feature-request for people with moving-plate instead of moving-head, to make the symbol of the baby steps "ambidextrous" for both parties: dc42 already included it in the latest build for the panel due (https://forum.duet3d.com/topic/10061/paneldue-firmware-1-23-now-available/8) - it are two arrows either opposing each other for closer together - or two arrows pointing away from each other for spreading apart...
                            All the best! Nice work!
                            -> THANKS FOR THE TIMESTAMPS on the diagramm(s)
                            • hestiahuangundefined
                              hestiahuang @chrishamm
                              @chrishamm said in Duet Web Control 2.0.0-RC6:
                              So hopefully this one is really the last RC before the actual release. You can get it here: https://github.com/chrishamm/DuetWebControl/releases/tag/2.0.0-RC6
                              Here once again the changelog:
                              Updated NodeJs components (also fixes a bug that caused all inputs to stop working once the heightmap was activated)
                              Changed click behaviour of file list items to be activated on a single click again
                              Added touch events to event+file lists to show the context menu on devices that do not support the native JS contextmenu event
                              Print information is no longer cleared when a print finishes
                              Simplified file list reset when the connection is interrupted
                              Print+Simulate options are hidden when a job file is being processed
                              Escape closes the text editor again
                              Height map is automatically reloaded once 'heightmap.csv' shows up in a G-code response
                              Minor other changes
                              Bug fix: Notification when editing a large file was not displayed during download
                              Bug fix: Macro list did not return to the root directory when the connection was interrupted
                              Bug fix: Warm-up time was not displayed
                              Bug fix: Selected tool was no longer highlighted when the light theme was selected
                              Bug fix: Drag&Drop was completely broken in Chrome and the drag animation stopped working anywhere
                              Let me know if any other issues come up.
                              I want to report an issue, after I uploaded the config files. It doesn't prompt up and ask for the restart the firmware. However it can on version 1.x...
                              • jv43undefined
                                jv43 @chrishamm
                                @chrishamm
                                Just another little bug report:
                                1. the visibility of text when using dark mode is really poor, maybe its just cause im partly colorblind, but another shade of blue would be greatly appreciated
                                  text visibility
                                2. I love being able to select which fans are shown but after selecting my LED (configured as Fan 2, Fan0 can be selected an deselected and it works fine)
                                  fan slider
                                3. any reason there is no option in DWC2 to show the heightmap? found it quite usefull to get my bed as flat as possible
                                Edit regarding 3.: nvm i found the heightmap tab, really like that implementation!
                                • totalosundefined
                                  totalos
                                  Hello.
                                  I think that on Dashboard/Extrusion Control
                                  "Feed amount in mm" and "Feedrate in mm/s: " default data will be 5 and 5.
                                  Now is 100 and 60 - in my opinion it is not safe and not good.
                                  Can I save other default value in RC6?
                                  jv43undefined 1 Reply Last reply Reply Quote 1
                                  • jv43undefined
                                    jv43 @totalos
                                    @totalos
                                    I second that! It really should be 5 and 5 at default, better to extrude too little and too slow than too much and too fast.
