    Spike in temperature of hotend PT100 when extruder stepper runs
    1.8k
    • gzcwnkundefined
      gzcwnk
      I am just setting up a Duetwifi to run a Wanhao D6 after the D6s motherboard died.
      So hot end gets up to temperature fine, it controls OK at 180C.
      I just tried to retract the filament and the hotend temp went off the scale and the Duetwifi switched to safe. I seem to have been lucky nothing blew, except I cant find a fault so far. I was very careful when assembling the wiring…....
      Now I am stumped. I just went through all the wiring again and I can detect no short between the extruder's 4 wires and the pt100s 2 wires nor also to ground. I have tested end to end of the wanhao's ribbon cable, no joy so far.
      So I am stumped.....like huh? any ideas please?
        Two possibilities I can think of:
        1. Short between one of the PT100 wires and something else. But you have checked for that already.
        2. If the wiring is such that the extruder wires can induce a voltage in the PT100 wires, that could interfere with the reading. Can you post a photo of the wiring?
        • gzcwnkundefined
          gzcwnk
          Ive like done so many checks I cant see it being a short. So near yet so far….bugger. 😞
          After the trip out the temperature graph became a little noisy just from the hold current? of the extruder's stepper? so I suspect 2 myself.
          The E0 will not run if the temp is too low (high?). is there a way to bypass that safety for testing? that way I can put a voltmeter on the pt100's leads and try and investigate a bit more.
          Off to work in a moment. I thought tonight I'd run a brand new pair for the PT100 end to end physically clear of the extruder's cabling as a test. Might be best if I go buy 2metres of shielded twisted pair for the PT100 and maybe the same in 2 pair for the extruder?
          The Wanhao uses a 16way ribbon cable, I bought a female socket and hooked into that. Sorry no idea how to upload a pic cant seem to make that work here.
          um, try this,
          http://imgur.com/a/Mi0zz
          or maybe this,
          https://postimg.org/image/b8kz9xckd/cd72cdfe/
          and,
          http://imgur.com/a/SbVOi
            I have the extruder and the PT100 cables following the same route for about 200mm, however they are not in a ribbon cable. I can see how running them all in a ribbon cable might increase the mutual inductance between them. So running the PT100 leads in a twisted pair may well help.
            • gzcwnkundefined
              gzcwnk
              The ribbon cable alone is 1.5M so in fact with my wiring close to 2M. I will buy some high grade audio heavy shielded for both. I assume can just drain them to the -ve from the power supply unit on the duetwifi?
              Is there a way to bypass the limit/safety so I can leave the stepper motor to the extruder running? That way I might be able to trace what is going on if this all fails.
                It's nice to see someone using those extra outputs we added!
                  T3P3Tony administrators
                  @gzcwnk:
                  M302 P1 will allow for code extrude so you can run the stepper motor while finding the PT100 issue.
                  Also if you have the one to hand you can put a PT100 or similar resistor (say 180R) into the PT100 board then that will confirm that the issue is with the wiring.
                  • gzcwnkundefined
                    gzcwnk
                    I installed highly flexible, shielded audio cable with a drain at one end that seems to have fixed it
                    • gzcwnkundefined
                      gzcwnk
                      i read you can stack 2 modules, so 4 pt100s, need that to drive E3d's kraken? pretty serious stuff. I want to probably do a dual I think so this was one of the selling points of the duetwifi.
                        Yes you can stack them in a pair on the DuetWifi for 2 PT100s or 2 PT100s and 2 thermocouples. Also another 4 channels on the Expansion board so 8 PT100s/Thermocouples in total
