    duet2wifi with two 12v power supplies with mosfet for each.
    647
    • chriskimbrundefined
      chriskimbr
      How do i wire the duet2wifi with two power supplies?
      I have 2 mosfets as well.
      My plan is to power the bed with one and the hotend with the other.
      I'm not sure how to wire it and the duet board as well.
      Please assist.
      • Vetiundefined
        Veti
        the hotend does not need its own mosfet. unlike board like the anet a8.
        the hotbed will need its own mosfet if you exceed 15A.
        my suggestion would be to wire one power supply to the duet board which powers everything except the hotbed. and connect the second power supply to the mosfet that powers the hotbed and wire the mosfet controls to the hotbed connector on the duet board.
        the endstops are configured as NO.
        chriskimbrundefined mihaitinteaundefined 2 Replies Last reply Reply Quote 0
          chriskimbr @Veti
          @veti said in duet2wifi with two 12v power supplies with mosfet for each.:
          ..the endstops are configured as NO.
          What do you mean by this?
          • Vetiundefined
            Veti
            NC= normally closed
            NO= normally open
            see
            https://configurator.reprapfirmware.org/Endstops
            Under enstop type
            chriskimbrundefined 1 Reply Last reply Reply Quote 0
              chriskimbr @Veti
              @veti my bed takes forever to heat up and intermittent gets faults. Would it be better to use a 24v power supply? Does that work with standard home plugin
              • Vetiundefined
                Veti
                measure the resistance of your hotbed with the leads disconnected.
                then calculate the power usage using P=V*V/R
                • Dougal1957undefined
                  Dougal1957
                  NC Endstops are the preferred option because they trigger if you get a wire fall off one of them.
                  • mihaitinteaundefined
                    mihaitintea @Veti
                    @veti Hi
                    Please can you tell why did you mention the endstop here. I too have a 2nd PSU and external mostfet, my intention is to do the same (heat the hotbed separately), but seeing that you brought here the endstop into discussion, I want to make sure I do not damage my Duet2 Wifi.
                    Thanks and regards
                    • Vetiundefined
                      Veti
                      sorry the endstops info mentioned was for another thread.
