    Initial Homing issues - Sequence of Errors
    2.5k
      Perhaps this guide would help with testing things
      https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+3:+Commissioning/39
      It's written for the Ender 3 but the methods would apply to any printer.
        Your homing files need to be modified slightly to allow it to raise the Z axis before the homing moves.
        For instance, your homez
        G91                ; relative mode
        G1 Z4 F200         ; raise head 4mm to ensure it is above the Z probe trigger height
        G1 Z-210 F200 S1   ; move down to 210mm in the -Z direction, stopping if the homing switch is triggered
        G90
        Would become
        G91                ; relative mode
        G1 Z4 F200 S2        ; raise head 4mm to ensure it is above the Z probe trigger height
        G90
        Notice the S2 on the first Z move to raise it. The S2 allows the axis to move before it is homed. The S1 after that is the move to the endstop.
        The same thing would need to be changed in your other homing files. The first Z move needs the S2 switch.
          It may be worth going through the Reprap configurator on your own and trying to input the values using this config as an example. The configs you got for the Wanhao may be for a much older version of the firmware.
          B0M0A0Kundefined 1 Reply Last reply Reply Quote 0
          • B0M0A0Kundefined
            B0M0A0K @Phaedrux
            @phaedrux said in Initial Homing issues - Sequence of Errors:
            I tend to agree with you on this. There appear to be differences in the configuration that may be based on what version of the i3 you are using.
            Prior to starting this upgrade I installed Repetier-Host and took screenshots of the EEPROM from my Melzi board. I have seen other examples of this that feature some differences in settings. I think this is linked to the version of the i3 and where Wanhao tweaked the config.
            The big issue I have in running through the RepRap configurator from scratch is that I just can't seem to reconcile some of the settings it's asking for with what I have in the screenshots from my printer as it was working with the Melzi board. An example of this would be the "Max. Speed Change" setting. There isn't anything in the EEPROM that seems to match that and I don't know enough about these settings (Yet!) to make an educated guess as to whether it is safe to leave the setting at it's default on the Configurator page.
            The Ender 3 article is a big help in just checking basic functionality and I will run through this again this evening once I am back in front of my printer.
            At the heart of this I think is my misinterpretation of what I was seeing on the Duet Web Control screen. I thought that clicking on the "Home" buttons would perform the action needed and enter that into the config. I did not realize that I needed to have set the Gcode instruction (for whichever axes I was looking at) prior to this.
            As a complete newbie with GCode and the Duet3D WiFi board it's all new to me. I have an inherent dislike of making assumptions so tend to grind to a halt when I don't understand something.
            Again, I am very grateful to all here who are trying to help out. I am making progress and don't think I am too far away from completion of this upgrade.
            0_1559126942952_Printer Information - EEPROM Settings-1.png 0_1559126948362_Printer Information - EEPROM Settings-2.png
            No fate but what we make ....
            Phaedruxundefined dc42undefined 2 Replies Last reply Reply Quote 0
              Phaedrux Moderator @B0M0A0K
              @b0m0a0k said in Initial Homing issues - Sequence of Errors:
              Max. Speed Change
              This refers to jerk.
                dc42 administrators @B0M0A0K
                The configurator will generate the GCode instructions in the homex.g, homey.g, homez.g and homeall.g files for you, but they will obviously only be correct if you enter the correct information in the Endstops page of the configurator. Also you should test that the motors move in the correct directions before you test homing.
                • B0M0A0Kundefined
                  B0M0A0K @dc42
                  @dc42 Thanks again for taking the time to reply. I ran through the commissioning guide you pointed me to and confirmed that just about everything is working with the exception of testing homing. I am focused on getting Home X working first. When I click on Home X the print head moves towards the stopswitch, but stops before it get's there (it moves about 80mm to the left).
                  A Former User? dc42undefined 2 Replies Last reply Reply Quote 0
                  • B0M0A0Kundefined
                    B0M0A0K @Phaedrux
                    @phaedrux Thank you!
                      A Former User @B0M0A0K
                      you need to increase the travel distance in the home file.
                      it probably reads something like G1 X80 S1change the X80 part to match the length of your X axis + a little extra. (Possibly G0 instead of G1, makes no difference)
                        That could be caused by a few different things:
                        1. In the configurator you specified that the size of your printer was much smaller than it actually is. Send M208 from the console and check that the reported min/max axis limits look right.
                        2. You have specified the incorrect steps/mm, so that the motor is not moving as much as it should. Use G91 then G1 S2 moves to check that the motors are moving the right amount. For example, when you send G1 S2 X50 F1000 check that the amount of movement is 50mm.
                        3. You are getting interference on the endstop wires, or you have a bad connection in one of them. This is uncommon, but possible if you have the endstop wires running right next to stepper motor wires over a considerable distance.
                        Please post your config.g, homex.g, homey.g, homex.g and homeall.g files.
                        • B0M0A0Kundefined
                          B0M0A0K @dc42
                          @dc42 I will get back to this tonight and post the requested files. Thanks.
                          • B0M0A0Kundefined
                            B0M0A0K
                            @dc42 As promised, here are my home config files;
                            config.g
                            ; Configuration file for Duet WiFi (firmware version 1.17 to 1.19)
                            ; generated by RepRapFirmware Configuration Tool v2 on Wed May 29 2019 19:19:18 GMT+0100 (British Summer Time)
                            M550 P"Removed" ; Set machine name
                            M551 P"Removed" ; Set password
                            M552 S1 ; Enable network
                            M587 S"Removed" P"Removed" ; Configure access point. You can delete this line once connected
                            M586 P0 S1 ; Enable HTTP
                            M586 P1 S0 ; Disable FTP
                            M586 P2 S0 ; Disable Telnet
                            M569 P0 S1 ; Physical drive 0 (X) goes forwards
                            M569 P1 S0 ; Physical drive 1 (Y) goes forwards
                            M569 P2 S1 ; Physical drive 2 (Z) goes backwards
                            M569 P3 S0 ; Physical drive 3 (E) goes forwards
                            M350 X128 Y128 Z128 E16 I0 ; Configure microstepping without interpolation
                            M92 X80.00 Y80.00 Z400.00 E100.00 ; Set steps per mm
                            M566 X900.00 Y900.00 Z12.00 E120.00 ; Set maximum instantaneous speed changes (mm/min)
                            M203 X6000.00 Y6000.00 Z600.00 E600.00 ; Set maximum speeds (mm/min)
                            M201 X1000.00 Y1000.00 Z100.00 E5000.00 ; Set accelerations (mm/s^2)
                            M906 X855.00 Y855.00 Z855.00 E855.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
                            M84 S30 ; Set idle timeout
                            M208 X200 Y200 Z180 S0 ; Set axis maxima
                            M574 X1 Y1 Z1 S0 ; Set active low and disabled endstops
                            M558 P0 H5 F120 T6000 ; Disable Z probe but set dive height, probe speed and travel speed
                            M557 X25:175 Y25:175 S20 ; Define mesh grid
                            M305 P0 T100000 B3988 R4700 ; Set thermistor + ADC parameters for heater 0
                            M143 H0 S60 ; Set temperature limit for heater 0 to 60C
                            M305 P1 T100000 B3988 R4700 ; Set thermistor + ADC parameters for heater 1
                            M143 H1 S210 ; Set temperature limit for heater 1 to 210C
                            M106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                            M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                            M106 P2 S1 I0 F500 H1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
                            M563 P0 D0 H1 ; Define tool 0
                            T0 ; Select first tool
                            homez.g
                            ; homez.g
                            ; called to home the Z axis
                            G91 ; relative positioning
                            G1 S1 Z-185 F1800 ; move Z down until the endstop is triggered
                            G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
                            ;G91 ; relative positioning
                            ;G1 S2 Z5 F100 ; lift Z relative to current position
                            ;G90 ; absolute positioning
                            homey.g
                            ; homey.g
                            ; called to home the Y axis
                            G1 S1 Y-205 F1800 ; move quickly to Y axis endstop and stop there (first pass)
                            G1 Y5 F6000 ; go back a few mm
                            G1 S1 Y-205 F360 ; move slowly to Y axis endstop once more (second pass)
                            G1 Z-5 F6000 S2 ; lower Z again
                            homex.g
                            ; homex.g
                            ; called to home the X axis
                            G1 S1 X-205 F1800 ; move quickly to X axis endstop and stop there (first pass)
                            G1 X5 F6000 ; go back a few mm
                            G1 S1 X-205 F360 ; move slowly to X axis endstop once more (second pass)
                            homeall.g
                            ; homeall.g
                            ; called to home all axes
                            G1 S1 X-205 Y-205 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
                            G1 S1 X-205 Y-205 F360 ; move slowly to X and Y axis endstops once more (second pass)
                            G1 S1 Z-185 F1800 ; move Z down stopping at the endstop
                            G92 Z0 ; set Z to axis minimum (you may want to adjust this)
                            G1 S1 Z5 F100 ; lift Z relative to current position
                              A Former User
                              Your M208 and G1 commands say it should be allowed to move more than 80mm. Are you certain the steps/mm is correct?
                                Delete that line now that you've connected to the wifi router.
                                It's a good idea to stick to x16 microstepping with interpolation to x256 and calculate your steps per mm based on x16 at least until everything is working properly, then if necessary you can experiment with other microstepping values, but generally, x16 interpolated will give the best results.
                                100mm/s might be a little slow for travel moves.
                                @bearer said in Initial Homing issues - Sequence of Errors:
                                I think your microstepping being set to x128 is making your steps per mm value of 80 incorrect. 80 may be correct for x16 though. This would explain why the axis isn't moving as much as you are requesting.
                                • B0M0A0Kundefined
                                  B0M0A0K
                                  OK, so thanks to the combined suggestions of @bearer and @Phaedrux we have progress. I changed the line;
                                  to
                                  M350 X16 Y16 Z16 E16 I0 ; Configure microstepping without interpolation
                                  as per your suggestions. The I re-ran all the home commands one axis at a time. Movement was much similar to what it had been with the old Melzi board setup. All axes homed to the stop switches, backed off a little and then slowly recontacted with the stop switches. They all stopped their movement with the stop switch activated (all red stop switches on the board active).
                                  I'm not sure if this is a new feature that I need to get used to (and I can see it in the config files for each axis), but before starting the Home process on X & Y they all raise Z before proceeding.
                                  The one that worries me here is the Z axis. When it triggers the stop switch it is pressed hard against the bed, so I need to back that off a little. I have tried lowering the bed as much as it will go and its still pressed hard.
                                    you'll get the same movement but smoother motion if you change the I0 to I1 to enable interpolation.
                                    • B0M0A0Kundefined
                                      B0M0A0K @A Former User
                                      Thanks, am giving that a try now.
                                      • B0M0A0Kundefined
                                        B0M0A0K
                                        I am wondering if the issue with the Z axis hitting the bed is because I am using a glass plate as the bed surface. The end stop switch was adjusted to allow for this, but I am wondering if there is a need to allow for that in the homez.g file?
                                        ; homez.g
                                        G1 S1 Z-400 F1800 ; move Z down until the endstop is triggered
                                          A Former User
                                          Not quite sure how this is built, but sounds like you need to move your z-switch. but strange if it worked before you replaced the board.
                                          • B0M0A0Kundefined
                                            .. but strange if it worked before you replaced the board.
                                            Yes, that's what bothers me as well.
