    Maestro motor control problems
    669
    • patrickbundefined
      patrickb
      I have a Maestro card that worked very well but since 1 week is the breakdown and I can not find the solution.
      I attach two video and my files that are on the SD.
      I updated the firmware with version 2.03 RC4.
      Thank you in advance for any help you can give me.
      Fichiers SD
      Video1
      Video2
      Stephen6309undefined 1 Reply Last reply Reply Quote 0
        T3P3Tony administrators
        the video was a bit hard to follow. can you explain what is not working - homeing?
        • patrickbundefined
          patrickb
          When I make a homeall the engines run a few seconds then all is stopped (return to the home screen).
          When I do a homex or homey then it works.
          I tried by uncoupling engines, and it does the same thing, the engines only run a few seconds (2 or 3).
          I tried by disconnecting the engines and after 2 or 3 seconds back to the home screen.
            So homeX works, HomeY works, how about Home Z?
            • patrickbundefined
              patrickb
              Homez works
              • patrickbundefined
                patrickb
                I looked at the config files and everything looks normal.
                I checked the wiring.
                I did research on the internet but I did not find anything.
                Is it a problem on the board ?
                • Stephen6309undefined
                  Stephen6309 @patrickb
                  @patrickb It looks it's reseting itself. Check for shorts when moving.
                    What power supply are you using to power the Duet? It could be that the PSU can handle a single motor but not all of them.
                    If you run M122 from the web interface after trying to home all, you will be able to see:
                    • When the last reset occurred, and why (which will tell you if the hardware reset during the homing attempt);
                    • What the minimum and maximum VIN voltages were since you last powered up (or the board reset) or ran M122.
                    • patrickbundefined
                      patrickb
                      Sorry, I do not speak English well. What does "shorts" mean
                      • patrickbundefined
                        patrickb
                        Even the coupled engines I have the same problem.
                        I'm not at home, I watch as soon as I get home
                        • patrickbundefined
                          patrickb
                          Uncoupled
                            dc42 administrators @patrickb
                            @patrickb said in Maestro motor control problems:
                            Short-circuits.
                            • patrickbundefined
                              patrickb
                              I'm using a 24v 15A power supply.
                              Here are the results of the M122:
                              M122
                              RepRapFirmware for Duet 2 Maestro version 2.02RC5(RTOS) running on Duet Maestro 1.0
                              Board ID: 08D8M-9T8A2-MQNSS-6JKD8-3SD6M-177LY
                              Used output buffers: 3 of 20 (13 max)
                              Static ram: 21236
                              Dynamic ram: 100436 of which 0 recycled
                              Exception stack ram used: 212
                              Never used ram: 9188
                              Tasks: NETWORK(ready,456) HEAT(blocked,1356) MAIN(running,3672) IDLE(ready,200)
                              Owned mutexes:
                              Last reset 00:00:10 ago, cause: watchdog
                              Last software reset at 2019-05-30 02:16, reason: User, spinning module GCodes, available RAM 9100 bytes (slot 0)
                              Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x04418000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
                              Error status: 0
                              Free file entries: 10
                              SD card 0 detected, interface speed: 15.0MBytes/sec
                              MCU temperature: min 42.3, current 42.7, max 42.9
                              Supply voltage: min 24.1, current 24.2, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
                              Driver 0: standstill, read errors 0, write errors 1, ifcount 22, reads 405, timeouts 0
                              Driver 1: standstill, read errors 0, write errors 1, ifcount 22, reads 405, timeouts 0
                              Driver 2: standstill, read errors 0, write errors 1, ifcount 23, reads 405, timeouts 0
                              Driver 3: standstill, read errors 0, write errors 1, ifcount 21, reads 405, timeouts 0
                              Driver 4: standstill, read errors 0, write errors 1, ifcount 21, reads 405, timeouts 0
                              Driver 5: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 411
                              Driver 6: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 411
                              Date/time: 2019-05-30 17:41:40
                              Slowest loop: 1.69ms; fastest: 0.13ms
                              I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0
                              Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 240, MaxWait: 0ms, Underruns: 0, 0
                              Bed compensation in use: none
                              Bed heaters = 0, chamberHeaters = -1 -1
                              Segments left: 0
                              Movement lock held by null
                              http is idle in state(s) 0
                              telnet is idle in state(s) 0
                              file is idle in state(s) 0
                              serial is idle in state(s) 0
                              aux is idle in state(s) 0
                              daemon is idle in state(s) 0
                              queue is idle in state(s) 0
                              lcd is idle in state(s) 0
                              Code queue is empty.
                              === Network ===
                              Slowest loop: 5.64ms; fastest: 0.02ms
                              HTTP sessions: 1 of 8
                              Interface state 5, link 100Mbps full duplex
                                Two things wrong:
                                You are running an unsupported RC version of firmware. Upgrade it to version 2.02 stable.
                                The board is resetting. If it still happens after you have upgraded the firmware to 2.02, post your config.g and homing files here.
                                • patrickbundefined
                                  patrickb
                                  I changed firmware and it works again.
                                  Thanks a lot for your help
