    bl touch not working
    2.0k
      dc42 administrators @Phaedrux
      @phaedrux said in bl touch not working:
      You also have M574 Z0 which would mean no endstop at all.
      That's correct if the BLTouch is being used to home Z.
        dc42 administrators @Sir printsalot
        @sir-printsalot said in bl touch not working:
        override.g is clean nothing interupting bl touch related command.
        The particular issue to watch for is config-override.g containing a M307 H7 line that re-enables it as a heater, which will prevent the M280 commands using it.
        • Sir printsalotundefined
          Sir printsalot
          I removed config override and commented out m501 in config g for testing. no difference. and its an Ethernet with static ip and cat 6e tested with through put 897 mbps using Ethernet tester. Board wont connect any way I try. It's not a network issue, seeing as I upgraded firmware than close dwc it refused to connect again. I imported the combined firmware 2.02a plus the ip4e file listed and the dwc was instructed as combined. I received status update showing the firmware was correctly installed. However the dwc version did not reflect a change. I did hit the applied setting tab anyway. no luck. I'm stuck.
            I think your DWC files may be out of date and will need to be manually updated.
            Download this file https://github.com/dc42/RepRapFirmware/releases/download/2.02/DuetWebControl-1.22.6.zip
            And unzip the contents into the /www folder on the SD card so that the contents of /www look like this:
              Sir printsalot
              This is what I got 0_1559300949515_config.g 0_1559300965861_deployprobe.g 0_1559300977009_retractact probe.txt
              Ok so sd card copy of dwc worked to reconnect. Thanks much for that help! Now back to the probe issue. As a precaution I ordered a brand new bl touch v3.01 for the manufactures site. It's installed with factory wire and connectors pre made. With the files listed here it does not deploy,retract,reset,or self test. It does deploy and retract 2 cycles rapidly when board pwrs on. however through gcode nothing. m401 m280 p7 s10,90,120,160 i1 codes show up green fielded in gcode console lines but are unresponsive. And again it works with the older firmware and config.g. however longer prints fail because of so bug unknown to me. So my question is, have I made the correct alterations to these files? and if so why do these probes not work with this firmware version. again duet Ethernet, both bl touch v2.0 and v3.01 tested. and is the 2.02a combined firmware the correct version for second gen Ethernet board?
                Looking at your config.g file, I think you have a DueX5 connected, so I presume you have connected the BLTouch to the PWM_5 connector on the DueX5. Is that correct? If so, you need to remove the i1 parameter from the M280 commands (in deployprobe.g, retractprobe.g and anywhere else that you use M280 to command the BLTouch).
                  Sir printsalot
                  ok what was the i1 command? single inversion I guess? How does that relate to the expansion header?
                    Sir printsalot
                    ok that cleared it up. I still can't explain how it worked that way under older firmware? I'd like to say who care it works now, but finding a more true understanding is the only recipe for success with this stuff anymore. Thanks Phaedrux and dc42 for you efforts, they paid off. If you ever need any uccnc or deskproto cam knowledge I'm your guy! I'm a mechanism at my local power plant, but code understanding is still not my strong suit. Thanks!
                      The heater signals on the expansion header are active low - the reason is that the MCU enables pullup resistors on all its outputs at power up, and we didn't want that to turn the heaters on. So if you connect bltouch to the expansion header, you need i1. The DueX has a gate and buffer that inverts the signal to provide an active high signal to drive the heater mosfet and increase it to 5V, and that is the same signal provided on the PWM headers. So when connecting a bltouch to one of those PWM headers, you don't need i1. See https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe?revisionid=HEAD#Section_Software_setup_Duet_2_WiFi_Ethernet.
                        Sir printsalot
                        Hello again, Ok I got the bl touch working by removing the I1 from m280. However homing machine probe deploys turns blue like it show but dont stop when triggered. the probe pin draws up on contact, but firmware isn't stopping movement. machine properties indicates z not stopped before homing, and after probe contact end stop hit. its just not stoping and setting zero0_1559522906537_homeall.txt 0_1559522913353_config.g new.txt
                          M401
                          G30                         ;lower probe set height
                          M402
                          Remove the M401 and M402. The G30 will take care of deploying and retracting the pin as needed.
                          Have you gone through this process of testing the probe?
                          https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
                          Can you supply a photo of how the probe is wired? We need to verify which pins you are using and that everything is connected as expected. If the probe isn't stopping movement it might indicate the signal wire isn't actually connected due to a bad crimp or broken wire.
                            Sir printsalot
                            I removed the m401 and 402 from homeall.g and homez. I used the factor 1 meter cable that comes with the new v3.0 bl touch. It's a 2 pin yeelow orange and black mounted at the heater 7 connector on my duex 5 expansion board. Then the 2 pin white and black sensor connectotr is mounted to the duet ethernet board probe in connector. looking at the board the top 2 of the 4 probe pins with ground being the top most pin. I have had the bl touch v2.0 for a year, but bought the newset version to rule out a bad probe. I used the supplied cables. I also ran them and all end stop cable in copper shielded cable covers with kapton sleeve . emi shielding. extremely low noise over senor wiring. And in machine properties I see z endstop state change when I touch probe pin during sensor testing. It's just not stopping or reflecting the position change. I had this happen a years ago with 2.00 rcos but forget what the fix was in config.
                              Sir printsalot
                              should there be a m564 s1 command line in homing files involving probe during intended triggering of probe or does the g30 and g31 cover the stop at switch event part?
                                Sir printsalot
                                New test results0_1559564317970_bl touch test for forum.txt
                                  From your config.g:
                                  G31 X0 Y12 Z2.01; PROBE OFFSET
                                  The P parameter is missing. I think the default should be OK, but try adding P100 to that command just in case.
                                    Sir printsalot
                                    thankyou!
