    Requested speed is not reached
    6.3k
      Can you post the Gcode file in question so we can see what it's trying to do?
      What print speed have you set in the slicer?
        dc42 administrators @PuddingBaer91
        @puddingbaer91 said in Requested speed is not reached:
        May it have to do with pressure advance enabled?
        When you use pressure advance, the acceleration used for moves with extrusion may be constrained by the extruder jerk setting, because extruder acceleration requires extruder jerk as well. Your extruder jerk setting is 300mm/min which is 5mm/sec. If your pressure advance is set to (for example) 0.2sec then the maximum extruder acceleration allowed is 5/0.2 = 25mm/sec^2.
        • PuddingBaer91undefined
          PuddingBaer91
          my pressure advance value is: M572 D0 S1.624 so my extruder acceleration is about 3mm/sec^2 right? So to speed up the print i have to higher the extruder jerk?
          thank you
          Phaedruxundefined deckingmanundefined 2 Replies Last reply Reply Quote 0
            Phaedrux Moderator @PuddingBaer91
            Try M556 M566 E3000
              PuddingBaer91
              thank you i will try tomorrow
                deckingman @PuddingBaer91
                .........................my pressure advance value is: M572 D0 S1.624 .........................
                S1.624! Seriously?
                PuddingBaer91undefined 1 Reply Last reply Reply Quote 0
                • Vetiundefined
                  Veti
                  @deckingman said in Requested speed is not reached:
                  S1.624! Seriously?
                  for when you have a bowden length of 5km ☺
                  joking aside. what is your bowden length. values that high are actually starting to become counter productive. as you are seeing it slows down your print speed.
                  • Vetiundefined
                    Veti @dc42
                    @dc42 said in Requested speed is not reached:
                    Actually in M205 it's mm/sec for compatibility with Marlin. It's mm/min in M566.
                    my bad. mm/sec for marlin and mm/min for duet is what sticks in my mind.
                    for the duet i always think of M566 for the jerk.
                      dc42 administrators @Phaedrux
                      @phaedrux said in Requested speed is not reached:
                      Try M556 E3000
                      I presume you meant M566 E3000.
                        PuddingBaer91
                        bowden length is about 700mm and i have done the calibration to find the value. With this value i get good results
                        deckingmanundefined dragonnundefined 2 Replies Last reply Reply Quote 1
                          @puddingbaer91 I would suggest that with a pressure advance value of 1.624, the extruder probably spends as much time going backwards as it does going forwards, which s why you'll never be able to print at much more than 30mm/sec.
                          • dragonnundefined
                            dragonn @PuddingBaer91
                            @puddingbaer91 They is something wrong with you machine or calibration procedure. My bowden is too about ~70cm and I only need 0.1 pressure advance.
                              PuddingBaer91 @deckingman
                              S1.624! Seriously?
                              hey deckingman instead of only talking: how could i reduce the value? I have done the calibration posted here in duet forum and ended with this. So please tell me how to reduce 😉
                              • dragonnundefined
                                dragonn
                                You need to post more details of you printer and maybe some photos of it and the calibration process.
                                  PuddingBaer91
                                  okay here we go:
                                  originally it was a TronXY X5S (coreXY) but i converted it to ultimaker machanics (cross slider) only thing that is original are some extrusions. Print area is about 330x330x350mm. The z-axis is driven by one motor coupled with a belt. Extruder is a geared ultimaker clone with double wheels. Also had a bondtech extruder but with this i also need these high values.
                                  config.g: (config.g override contains only PID settings)
                                  ; generated by RepRapFirmware Configuration Tool on Wed Oct 24 2018 17:07:50 GMT+0200 (Mitteleuropäische Sommerzeit)
                                  M667 S0 ; Select Cartesian mode (Select CoreXY mode with S1)
                                  M550 PTronMakerXY ; Set machine name
                                  M552 S1 ; Enable network
                                  M587 S"Fox 7390" P"" I192.168.1.69 J192.168.1.1 K255.255.255.0 ; Configure access point and IP addresses. You can delete this line once connected
                                  M586 P0 S1 ; Enable HTTP
                                  M586 P1 S0 ; Disable FTP
                                  M586 P2 S0 ; Disable Telnet
                                  M569 P0 S0 ; Drive 0 goes backwards DD S1
                                  M569 P1 S1 ; Drive 1 goes backwards DD S1
                                  M569 P3 S1 ; Drive 3 goes backwards
                                  M92 X80.46 Y80.46 Z400 E336 ; Set steps per mm (for pencake motor with bondtech: 830)
                                  M566 X1200 Y1200 Z24 E3000 ; Set maximum instantaneous speed changes (mm/min) M566 X1200 Y1200 Z24 E300 gut: M566 X480 Y480 Z24 E300
                                  M203 X18000 Y18000 Z2400 E2700 ; Set maximum speeds (mm/min)
                                  M201 X3000 Y3000 Z100 E3000 ; Set accelerations (mm/s^2) M201 X3000 Y3000 Z100 E3000 gut: M201 X800 Y800 Z100 E3000
                                  M906 X1200 Y1200 Z1200 E1200 I30 ; Set motor currents (mA) and motor idle factor in per cent
                                  M84 S30 ; Set idle timeout
                                  M208 X330 Y330 Z370 S0 ; Set axis maxima
                                  M574 X1 Y1 S0 ; Set active low endstops
                                  M574 Z1 S2 ; Set endstops controlled by probe
                                  M307 H3 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
                                  M558 P9 H5 F120 T6000 ; Set Z probe type to bltouch and the dive height + speeds
                                  G31 P25 X0 Y-24 Z0.75 ; Set Z probe trigger value, offset and trigger height // Verringern von Z entfernt Bett von der Duese!
                                  M557 X30:315 Y30:310 S59 ; Define mesh grid
                                  M305 P0 T100000 B4138 C0 R4700 X2 ; Set thermistor + ADC parameters for heater 0 and remap it to channel 2
                                  M143 H0 S80 ; Set temperature limit for heater 0 to 80C
                                  M305 P1 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 1
                                  M143 H1 S250 ; Set temperature limit for heater 1 to 250C
                                  M106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                                  M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                                  M106 P2 S1 I0 F500 H1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
                                  M563 P0 D0 H1 S"Extruder" ; Define tool 0
                                  G10 P0 X5 Y0 Z0 ; Set tool 0 axis offsets
                                  ; Automatic power saving
                                  M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
                                  ;M671 X20:295:20:295:170:170 Y10:305:305:10:10:305 P8 ; adjusting screws at rear left (-15,190), front middle (100,-10) and rear right (215,190), thread pitch 8mm
                                  ;M572 D0 S0.268 ; Set pressure control for direct drive with bondtech
                                  M572 D0 S1.624 ; Set pressure control for bowden with sanjiu
                                  ;M307 H1 A459.4 C167.2 D4.1 ; PID for Extruder
                                  ;M307 H0 A101.4 C1123.0 D10.0 B0 ; PID for Bed
                                  ;M592 D0 A0.015 B0.0012 L0.2 ; Nonlinear adjustment
                                  M591 D1 P1 C4 S1 ; Enable E1 Endstop for filament run out detection
                                  M581 E1 S0 T1 ; invoke trigger 1 when a falling edge is detected on the E1 endstop input
                                  ;M929 P"eventlog.txt" S1 ; start logging to file eventlog.txt
                                  ;M200 D1.75 ; set all extruder filament diameters to 1.75mm
                                  ;M207 S1.0 F2400 ; set firmware retraction 1mm with 40mm/s
                                  For calibration i used this: https://forum.duet3d.com/topic/6698/pressure-advance-calibration with these settings:
                                  #!/usr/local/bin/python
                                  extrusion parameters (mm)
                                  extrusion_width = 0.48
                                  layer_height = 0.2
                                  filament_diameter = 1.75
                                  print speeds (mm/s)
                                  travel_speed = 120
                                  first_layer_speed = 20
                                  slow_speed = 5
                                  fast_speed = 60
                                  calibration object dimensions (mm)
                                  layers = 100
                                  object_width = 90
                                  num_patterns = 4
                                  pattern_width = 5
                                  pressure advance gradient (s)
                                  pressure_advance_min = 0.0
                                  pressure_advance_max = 0.4
                                  center of print bed (mm)
                                  offset_x = 165
                                  offset_y = 165
                                  after getting not good results i changed pa value min to 0.4 and pa value max to 0.8 and reprinted the test and so on..
                                  here is a picture with pa value from 0 to 0.4:
                                  https://photos.app.goo.gl/98dehNVkQ2d4naaP9
                                  these test are with values around 1.6:
                                  https://photos.app.goo.gl/h2qjDT6DFwfBaw3y5
                                  the right one is the final where all segments (slow and fast speed) have nearly the same wall thickness
                                  here are some pictures from the printer:
                                  https://photos.app.goo.gl/NM5Zr6jgCv3cpNrV7
                                  thank you very much
                                    S1.624! Seriously?
                                    I don't like the calibration method that is on these forums. This is an old blog post but it details the method I use which works for me https://somei3deas.wordpress.com/2018/01/15/an-attempt-to-investigate-pressure-in-the-extrusion-system-with-a-diamond-hot-end/
                                      PuddingBaer91
                                      slicer settings for PLA:
                                      print temp: 215°C
                                      bed temp: 60°C
                                      nozzle diameter: 0.4
                                      extrusion multiplier: 0.88
                                      retraction distance: 2.5 mm
                                      retraction speed: 30mm/s
                                      Layer heigth: 0.2 mm
                                      start points: fixed position
                                      cooling: 100% starting at second layer
                                      relative extrusion: yes
                                      speed: 60mm/s (outer perimeter and solid infill a bit slower
                                      movement speed: 120mm/s
                                      filament dia: 1.75mm
                                      only retract when crossing open spaces
                                      disabled retraction on layer change
                                        S1.624! Seriously?
                                        thank you but even the autor from this article used a pressure advance value of 0.7 with much shorter bowden tube... Don't know what i could do to reduce it. maybe printing hotter?
                                          @puddingbaer91 I would suggest that if you need that sort of pressure compensation, then there is something seriously wrong that is causing too much pressure inside the hot end. That could be for any number of reasons, for example a partial blockage or too much part cooling air being deflected back off the build plate and dropping the temperature at the nozzle tip. I use a pressure advance value of 0.4 with my Diamond multi filament hot ends and that is considered high by many people. Most (but not all) users with "conventional" hot ends run values in the order of 0.1 to 0.2, even with long Bowden tubes. So there has to be something seriously wrong if you need values in excess of 1.6.
                                            S1.624! Seriously?
                                            I am the author that post - that is my blog I linked too. As I said in my post above, and as described in my blog, those tests were done with a Diamond hot end which uses 3 Bowden tubes and 3 extruders and has a massively large melt chamber. Since changing my extruders from E3D Titans to Bondtech BMGs, I have reduced the PA to 0.4.
