    Strange Printing Defect! Please Help,
    23
    1.7k
    • clearlynotstefundefined
      clearlynotstef
      I returned my nimble for the same situation. This printer printed perfectly before the nimble and perfectly afterwards, and it was calibrated according to their instructions. There was nothing wrong except that nimble. I will say they were helpful and good to work with, but I will also say this post above shifting blame to the users other components does rub me the wrong way.
        Phaedrux Moderator @Syko_Symatic
        @syko_symatic said in Strange Printing Defect! Please Help,:
        M566 X400 Y400 Z20 E30 ; Set maximum instantaneous speed changes (mm/min)
        ; Pressure Advance
        ;M572 D0 S0.7
        Very low extruder jerk and very high pressure advance can lead to some odd side effects. I'm not super familiar with the nimble, but I realize they recommend low jerk due to the worm gear drive?
        If you're running firmware 2.03 You could try enabling the new jerk policy setting with M566 P1 and see if it makes a difference. It's a long shot, but worth a try.
        Looking at the pictures though it definitely seems like some sort of extruder eccentricity.
        Syko_Symaticundefined Alexander Mundyundefined 2 Replies Last reply Reply Quote 0
        • Syko_Symaticundefined
          Syko_Symatic @Phaedrux
          @phaedrux extruder eccentricity? Never heard that term before? Could you give me a quick run down on it?
            @syko_symatic A gear or something in the path that transfers the rotation of the motor to the gear that pushes the filament is out of true. So instead of consistent motion there is pulsing, or vibration, or extra drag/friction. Some mechanical action causing the pattern you see.
            Have you tried printing larger objects yet? Circles? Diagonals?
            Syko_Symaticundefined 1 Reply Last reply Reply Quote 0
              @phaedrux diagonals, yes, circles no.
              With the nimble what could actually cause that eccentricity?
                I imagine that would be the tolerance stacking they mentioned in that copy and paste above.
                • Alexander Mundyundefined
                  Alexander Mundy
                  Doesn't look like an eccentric gear or loose bearings/case/hob shaft due to the tight spacing. I had an undersized hobb shaft and the effect was more spread out. Looks more to me like cable/stepper side problem. What is your minimum cable radius? Can you detect any slapping of the cable against the sheath? Re lube, I use 20K diff lube and it works fine. Others I have heard using 10K to 100K.
                    Alexander Mundy
                    Oh, another thing to check is that the end of the cable is all the way down inside the worm gear.
                      Alexander Mundy @Phaedrux
                      @phaedrux said in Strange Printing Defect! Please Help,:
                      Honestly the low jerk / acceleration was the biggest hurdle for me. I almost gave up but I hunted for low inertia / fast steppers. I found that 3.6 degree parallel disc magnet steppers from Portescap (P430 258 005 01 with the coils wired parallel) allow for some serious extruder acceleration and jerk. As a test I have tried up to 100mm/s retraction without any problem even with the 30 to 1 gearing. Be sitting down if you look that stepper up though. Fortunately I got them used for less than 10% new price.
                        Syko_Symatic
                        Spoke quickly to Brian from Zesty Tech over email. He suggested a few things which have improved the quality but still not quite there 100%. May be having a call with him tomorrow.
                        One thing I have mentioned to him though, the worm gear seems much looser in the bearing on one end, I am not sure if this is intentional but may be an issue?
                        If anyone can suggest anything to improve this result further I am all ears....
                        Improved
                        Alexander Mundyundefined 1 Reply Last reply Reply Quote 0
                        • DamianMundefined
                          DamianM
                          This post is deleted!
                            Syko_Symatic @DamianM
                            @damianm reducing the extruder acceleration to 1000 did wonders to be honest. I will have to check a few other slicer settings and esteps to see if I can improve on the finish I am currently getting.
                            It's good but now as good as I got from it on my previous printer.
                              Alexander Mundy @Syko_Symatic
                              @syko_symatic That looks like it might be related to the loose fit at one end of the worm to me. It is similar to what I got when a bearing was getting worn out.
                                Syko_Symatic
                                Jammed some paper in between the looser end on the worm gear and the bearing and it seems to have helped. I have ordered a new nimble (as they have a slightly improved version now) so maybe I need to get a replacement worm gear? I will have to measure it first and see if it was manufactured incorrectly.
                                Little bit better
                                • DamianMundefined
                                  DamianM
                                  @Syko_Symatic Thank You!
