    AJAX timeout error during a print
    48
    8.6k
    • roboduetundefined
      roboduet
      FF dev console, empty request:
      FF dev console, request index page after previous empty request:
      Wireshark:
      Last successful request tcp stream number = 56
      Empty request tcp stream number = 57
      Index page request tcp stream number = 58
      Also I noticed long pause between 56 and 57 streams (time column).
      57 stream seems like complete (correct) AJAX JSON response.
      After 58 stream (after requesting index page) DWC stops any further requests. DWC doesn't show any errors (i.e AJAX or just "disconnected") in DWC G-Code console tab and still think that it connected to Duet.
      I have saved Wireshark dump in pcapng format, I can upload file if this can help.
      • roboduetundefined
        roboduet
        Sorry, forgot to attach M122 logs after reconnect:
        [[language]]
        M122
        Used output buffers: 2 of 32 (8 max)
        Memory usage:
        Program static ram used: 19284
        Dynamic ram used: 83012
        Recycled dynamic ram: 104
        Current stack ram used: 2768
        Maximum stack ram used: 3868
        Never used ram: 24804
        Last reset 01:58:35 ago, cause: power up
        Error status: 0
        Bed probe heights: 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000
        Free file entries: 10
        SD card longest block write time: 0.0ms
        MCU temperature: min 31.6, current 33.3, max 36.7
        Supply voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0, over voltage events: 0
        Slowest main loop (seconds): 0.004883; fastest: 0.000000
        MaxReps: 0, StepErrors: 0, MaxWait: 0ms, Underruns: 0, 0
        Bed heater = 0, chamber heater = -1
        Heater 1 is on, I-accum = 0.0
        Move available? no
        Stack pointer: 0 of 5
        macro is idle
        http is ready with "M122"
        telnet is idle
        serial is idle
        aux is idle
        file is idle
        === Network ===
        WiFiServer is running
        SPI underruns 0, overruns 0
        === Webserver ===
        HTTP sessions: 1 of 8
        • chrishammundefined
          chrishamm administrators
          Hmm, just as I suspected. It looks like the WiFi module actually sends a non-empty response, but Firefox never receives and processes it. I'll look into the WiFi Server firmware later. Could you send me the Wireshark pcap file though?
          Duet software engineer
          • roboduetundefined
            roboduet
            Yes, as I said before. For some unknown for me reasons Duet sends valid response, but Firefox "receives" empty response. This is freeze/hangup bug. But also sometimes DWC shows me AJAX error and properly shows disconnected state if it receives invalid or empty response. I don't yet know why sometimes DWC is just freezes and why sometimes it shows proper AJAX error.
            I still think about big pause between last valid request and next empty request. Can it be that AJAX request timeout is interpreted as empty response?
            I will ask your email in PM to send logs.
            • roboduetundefined
              roboduet
              Two hours without disconnects or connection freeze using latest 1.16 release firmware with @chrishamm web-server 1.03-ch firmware. Still looking at error logs, but it seems that this release is much stable.
              Firmware Name: RepRapFirmware for Duet WiFi
              Firmware Electronics: Duet WiFi 1.0
              Firmware Version: 1.16 (2016-11-08)
              WiFi Server Version: 1.03 (ch fork)
              Web Interface Version: 1.13
              • roboduetundefined
                roboduet
                Seems like DWC connection freeze issue fixed. Three hours yesterday and one hour today without any connection freezes. Thank you!
                  That's great, thanks for confirming that my latest improvements are working well!
                  • timpactundefined
                    timpact
                    Hi
                    I'm new here and building 3d printer in my free time.
                    I just set up a Duet v0.6 with the latest firmware and Web Control:
                    Firmware Name: RepRapFirmware for Duet-0.6-0.8.5
                    After connecting to the duet via Web Control I'm getting the same error like appjaws after ~55 secconds while doing nothing:
                    Communication Error
                    An AJAX error has been reported, so the current session has been terminated.
                    Please check if your printer is still on and try to connect again.
                    Error reason: timeout
                    I reestablished the connection several times and got the error message every time after 55 secconds.
                    Thanks for every hint and help. Just tell me if you need further information.
                    Edit: I'm using windows 7 pro and the error appears in Firefox and Chrome
                      I recommend you try to reset your TCP/IP stack once and restart your computer, see https://support.microsoft.com/en-us/kb/299357
                      • timpactundefined
                        timpact
                        Well that solved the problem fast and perfect. Thank you!
                        • whosrdaddyundefined
                          whosrdaddy
                          @dc42 : spam?
                            dc42 administrators @whosrdaddy
                            @whosrdaddy said in AJAX timeout error during a print:
                            @dc42 : spam?
                            Yes, account deleted.
