    DUET thinks print is finished but is actually stalled...
    • msjfbundefined
      msjfb
      Object was 8mm high, but printing stopped at 3.01mm... And all heaters were left on!
      Nozzle was sitting in a middle of the print.
      I am enclosing a Zipped file of the Gcode (had to rename it because of the size...)
      I am at a loss as to why this happened. Maybe someone can spot something in the GCODE ?
      I ran it fine through a Gcode simulator...
      I have nothing connected to the DUET, i.e. running it exclusively through the web interface.
      Thanks,
      François
      0_1561687982695_Garden_Stake_Tripod_Clip__Connector_-_Arm_A_v1.0 v2 (repaired) x2.zip.gcode
        We're you able to capture an M122 after it stopped before rebooting the board?
        • msjfbundefined
          msjfb
          Unfortunately, no. I used the 'emergency stop' as soon as I came back to the printer after a few minutes.
          I have been trying to run a WYZE V2 camera (with DAFANG hack) in DUET: not much success, was having trouble keeping a connection. I am wondering if this could be related (ressources ?.
          I have removed the link from DUET and am now using a separate browser page to monitor the DAFANG stream.
          • zaptaundefined
            zapta @msjfb
            @msjfb said in DUET thinks print is finished but is actually stalled...:
            I am using the WYZE camera independently of the duet, using it's mobile app and it works great. I can view the printing from outside of home network and can go back to interesting events in the recorded timeline (requires a SD card). You may want to give it a try.
            • msjfbundefined
              msjfb
              Thanks @zapta , in fact I have 2 other Wyze cameras running at home. I may put the original firmware back into this one and use it as a 'Wyze' cam for the printer, but I try to limit the number of web connected devices in my home...
