    Bltouch Error: Z probe was not triggered during probing move
    • doerofthings
      doerofthings last edited by
      i'm trying to get my duet 2 WiFi working on my tevo tornado, and am running into issues with the BLTouch
      everything seems to be working, but when I have it probe the bed I get
      "G28
      Error: Z probe was not triggered during probing move"
      but it sure looks to me like it was.
      it sure looks like it detects the bed, it hops back up, probes the bed again and the printer reports that it is homed.
      it's really confusing.
      any suggestions where to look / what to change?
      here's my wall-o-configs
      Firmware Version: 2.03beta3 (2019-03-25b6)
      WiFi Server Version: 1.22
      Web Interface Version: 1.22.6
      config-override.g
      empty
      Config.g
      ; generated by RepRapFirmware Configuration Tool v2 on Wed Apr 03 2019 15:50:04 GMT-0500 (Central Daylight Time)
      M550 P"PrinterOfThings" ; Set machine name
      M552 S1 ; Enable network
      M586 P0 S1 ; Enable HTTP
      ;M586 P1 S1 ; Enable FTP
      ;M586 P2 S1 ; Enable Telnet
      M569 P0 S0 ; Drive 0 goes Backwards
      M569 P1 S0 ; Drive 1 goes Backwards
      M569 P2 S0 ; Drive 2 goes Backwards
      M569 P3 S0 ; Drive 3 goes Backwards
      M92 X80.00 Y80.00 Z400.00 E615.4 ; Set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120.00 ; Set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z6000.00 E1200.00 ; Set maximum speeds (mm/min)
      M201 X200.00 Y200.00 Z100.00 E250.00 ; Set accelerations (mm/s^2)
      M906 X800.00 Y800.00 Z800.00 E800.00 I10 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X0 Y0 Z-20 S1 ; Set axis minima
      M208 X300 Y300 Z400 S0 ; Set axis maxima
      M574 X1 Y1 S0 ; Set active low and disabled endstops
      M574 Z1 S2 ; Define Z to use Probe. Home to Min
      ; BLTouch - Heaters
      M307 H7 A-1 C-1 D-1 ; Disable the 7th Heater to free up PWM channel 5 on the Duex board.
      M557 X15:285 Y15:285 S50 ; Define mesh grid
      M558 P9 H5 F100 T6000 A5 R0.2 ; P9 for BLTouch, dive height 5mm, probe at 100mm/min, travel 6000mm/min, up to 5 probes, pause 0.1s
      G31 X-45 Y-5 Z-5.25 P25 ; probe XY offset and Z trigger height and trigger value
      M557 X5:205 Y5:165 S20 ; Define mesh grid
      M305 P1 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1
      M143 H1 S265 ; Set temperature limit for heater 1 to 265C
      M106 P1 S0 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P2 S0 I0 F500 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M563 P0 D0 H1 ; Define tool 0
      ; Automatic power saving
      M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
      Deployprobe.g
      M280 P7 S10 I1
      Retractprobe.g
      M280 P7 S90 I1
      homez.g
      ; homez.g
      ; called to home the Z axis
      ; generated by RepRapFirmware Configuration Tool v2 on Wed Apr 03 2019 15:50:05 GMT-0500 (Central Daylight Time)
      G91 ; relative positioning
      G1 X190 Y150 F4000 ; Move probe to middle of bed
      G30
      G92 Z13 ; set Z to axis minimum (you may want to adjust this)
      ;G91 ; relative positioning
      ;G1 S2 Z5 F100 ; lift Z relative to current position
      ;G90 ; absolute positioning
      homeall.g
      ; homeall.g
      ; called to home all axes
      G1 S1 X-305 Y-305 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
      G1 X5 Y5 F6000 ; go back a few mm
      G1 S1 X-305 Y-305 F360 ; move slowly to X and Y axis endstops once more (second pass)
      G90
      G30
      G92 Z11 ; set Z to axis minimum (you may want to adjust this)
      ;G90 ; ; absolute positioning
      Allergen notice: This message was processed in a facility that also processes data.
      • Veti
        Veti last edited by
        does the self test work?
        M280 P7 S120 I1
        • doerofthings
          @veti said in Bltouch Error: Z probe was not triggered during probing move:
          M280 P7 S120 I1
          yes it does
          <click, click, click.....>
            @doerofthings said in Bltouch Error: Z probe was not triggered during probing move:
            G31 X-45 Y-5 Z-5.25
            How did you get a trigger height of -5.25?
            doerofthings 1 Reply Last reply Reply Quote 0
            • doerofthings
              doerofthings @Phaedrux last edited by
              @phaedrux
              honestly, i'm not sure how i arrived at that.
              i think i was trying to set the Z offset, but yeah, it doesn't make sense.
              so i went back and set it based on the procedure here http://www.sublimelayers.com/2017/05/fdffsd.html
              and arrived at G31 X-45 Y-5 Z3.7 P25
              it seems to like that, but it thinks zero is 2.2mm above the bed. how do i fix that? i tried setting the G31 Z to 1.5 and also 5.9 (assuming i didnt know how it was counting...) but it made no change.
              how do i set the z offset on this?
                Remove this from your homeall.g and homez.g. You definitely don't want to force the z height after you've used the probe to find the real height with G30. This explains why changing the offset had no effect, because you are overriding it.
                I have a feeling that your bltouch may be mounted a bit too high as well. It should be mounted so that the base of the probe body is 8mm above the nozzle tip. When installed correctly, the trigger height will be around 2mm.
                Once you've done that, recheck your trigger height with this procedure: https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Calibrate_the_Z_probe_trigger_height
                Then you can rerun your G29 if you want to use it.
