    Delta set up
    • Dugeeundefined
      Dugee
      I am converting a mini delta to Duet2 Maestro. I had the printer running well with the original board.
      Would I be better to use my calibration settings from my previous set up at initial set up of the board or should I just start from stock figures and use auto calibration to get it dialled in?
      I'm a little bit out of my comfort zone doing this but looking forward to the challenge!
      • Vetiundefined
        Veti
        yes use your previous setting for the initial set up then use auto calibration.
        use the configurator to help you
        https://configurator.reprapfirmware.org/
          Start with your current settings, but bear in mind that all speeds in RRF are in mm/min whereas Marlin uses a mixture of mm/sec and mm/min.
          Dugeeundefined 1 Reply Last reply Reply Quote 1
          • Dugeeundefined
            Dugee @dc42
            @dc42 Thanks for the reminder. I had seen that in the documentation but I'll make a note when I start the install.
