    Duet2 WiFi : No WiFi without SD Card
    3.3k
    • elmoretundefined
      elmoret @DennisHall
      @dennishall said in Duet2 WiFi : No WiFi without SD Card:
      @elmoret
      I only even got a replacement because I was told previously in this thread, the LCD may be defective.
      If you review this thread you will see for yourself.
      People only arrived at that conclusion because you repeatedly stated that you had a PanelDue 7i.
      As for how they came out of the box, sounds like someone in the supply chain (perhaps Spool3D) is flashing incorrect firmware. But that's fixable without replacement hardware, of course.
      Why do you suspect the Duet 2 Wifi is defective?
      DennisHallundefined 1 Reply Last reply Reply Quote 0
        My guess is that the PanelDue controller board has the 5" firmware on it, which is how they are programmed during manufacture. Running 5" firmware on a 7" panel gives incorrect colours.
        • DennisHallundefined
          DennisHall @elmoret
          @elmoret Thanks fo rthe model type clarification.
          All good now. That no-logo bin file took care of it.
          I only suspected the Duet2 WiFi starting today when the replacement LCD had the same result out-of-box.
          I just got off the phone with Darek at Spool3D. They don't flash the hardware, seems Duet shipped with V1.21.1. Darek also says they have 5 more 7 inch LCD's still in stock and will update their site stock.
          Anyhow, all good now.
          Sorry if I got testy with anyone, that's me getting a bit stressed. Terminologies are not always consistent between Chineze clones and "real" hardware 😉
          I love the Dark 2 colors scheme on the LCD with the 1.22.1 firmware build.
            DennisHall @dc42
            @dc42 Sorry if my photos in this thread did not show the controller board separate from the LCD.
            The issue was my lack of knowledge of the model type between my 7 and a 7i.
            The no-logo bin file took care of business and Spool3D also now knows they are receiving their PanelDue models with the 1.21.1 firmware.
              DennisHall @Phaedrux
              @phaedrux Thanks man! That was the right bin file for (what I now know is a PanelDue 7)
              Your summary made it obvious.
              Really appreciated.
