    Printing % on PanelDue
    PanelDue
    • PaulHewundefined
      PaulHew
      Is it possible for the PanelDue to display the completion % instead of just 'Printing' in the top right hand corner?
      I.E. Printing - 16.6%
      Or would that cause too much traffic over the serial connection.
      Thanks
      RailCore II - Duet Mini + 1LC, Voron V0.1 - Duet Mini
      Voron 2.4 disassembled..... Waiting for the RailCore Mini....
      • PaulHewundefined
        PaulHew
        ANd while I remember, the PanelDue is showing Fan 0%, even though all of my fans are on, including the case fan for the Maestro.
        Have I messed up somewhere?
        Thanks.
          Which versions of RepRapFirmware and PanelDueFirmware are you running? I think there was a bug fix in this area sometime last year.
          • PaulHewundefined
            PaulHew
            @dc42 I am running the following
            PanelDue 1.22.1(28B1)
            Maestro Firmware Version: 2.02RC3(RTOS) (2018-10-17b2)
            Web Interface Version: 1.22.6
            Regards.
              I think you should update your PanelDue and main firmware versions.
              1.23 for paneldue just came out, and 2.02 final has been released for quite some time. That may take care of your fan %.
              • PaulHewundefined
                PaulHew
                Thank you @dc42 and @Phaedrux
                I will read up on how to do the updates.
                Regards, Paul.
