    BLTouch breakout PCB for Duet2 Wifi
    • zapta
      zapta last edited by
      In case anybody is interested, here is a simple breakout board for connecting BLTouch servo connector to Duet2 Wifi.
      The schematic, kicad, and gerber files are here https://github.com/zapta/misc/tree/master/evo/bltouch/bltouch_breakout
      I used these connectors though equivalent are available from other sources
      • Digikey S9201-ND https://www.digikey.com/short/ppjmm7
      • https://www.aliexpress.com/item/KF2510-Kits-50-sets-Kit-in-box-2p-3p-4-pin-2-54mm-Pitch-Terminal-Housing/32815992024.html (Molex KK equivalent)
      You can order the board from any PCB vendor (try pcbshopper.com). If you are not familiar with PCB orders, oshpark.com is probably the easiest.
      I have 4 spares bare PCBs that I can mail for free within the US.
      • timcurtis67
        timcurtis67 last edited by
        Got any photos of it? Will it work if you have a duex5 attached?
        dc42 zapta 2 Replies Last reply Reply Quote 0
          dc42 administrators @timcurtis67 last edited by
          @timcurtis67 said in BLTouch breakout PCB for Duet2 Wifi:
          If you have a DueX attached, you can use one of the servo connectors on the DueX.
          timcurtis67 1 Reply Last reply Reply Quote 0
          • zapta
            zapta @timcurtis67 last edited by
            @timcurtis67, my post included a picture. If you can't see it, it's also available here https://i.imgur.com/7nytfW3.jpg
            As for the DueX, as @dc42 said, you don't need this breakout board and I believe this will also be the case with Duet3 (?).
            Another option I considered is to rework the DWF2 with a mod wire to have that wire routed to the probe connector. Maybe one day.
              dc42 administrators @zapta last edited by
              @zapta said in BLTouch breakout PCB for Duet2 Wifi:
              Correct. Duet 3 has 5-pin connectors for endstops and Z probes.
              • timcurtis67
                timcurtis67 @dc42 last edited by
                @dc42 said in BLTouch breakout PCB for Duet2 Wifi:
                Thanks for the info, good to know. I already have a BL Touch on my small corXY but I'm thinking about adding one to my large IDEX printer with the DueX5.
                The firewall at work is blocking the picture. I'll check it out tonight.
