    Recommended extruded motor
    10
    1.0k
    • Jareryundefined
      Jarery
      I have a delta printer, based off of DC42’s large Kossel build.
      Duet Wi-Fi , smart effector, E3D volcano with .8mm nozzle.
      I have been using a nimble extruded but am tired of endless calibration and never ending blobs and ripples. I have a titan extruded sitting in a box so I’m looking at going back to that and a Bowden tube.
      With the nimble it was recommended to use a 1.8 degree motor due to the gearing. What is recommended for a titan and a volcano setting ? 1.8 or 0.9 ? My power supply is 24v if that matters in the decision.
      • Vetiundefined
        Veti
        you want to be around 300-400 steps/mm. so a 1.8 degree motor is fine for a titan.
        • frank26080115undefined
          frank26080115
          @jarery said in Recommended extruded motor:
          Hey I have been using a flex shaft system like the Nimble for years. Whenever I see ripples, I replace the shaft, and the problem goes away for a few months. The problem being when the shaft gets softer, it becomes springy, and doesn't transfer torque instantly anymore, it builds up tension before releasing tension, causing ripples and blobs.
          You must really watch what the bend radius of the flex shaft is, or else it wears down really fast. If you have a kink in the protective tube, it will also wear down the shaft faster. Perhaps re-evaluate the placement and orientation of your motor.
          I also switched to a 3/16" diameter flex shaft (uncommon but stronger) instead of 1/8" diameter (more common). To do this mod, you need to stick a solid shaft down the nylon worm you got first, and then us a shaft coupling between the flex shaft and the solid shaft.
          Also I never really calibrated my E-steps. My first system was a Flex3Drive and they simply told me what number to put into Marlin and it's been dead on. My second system is my own design but with known gear size so I just calculated it and it was dead on too. Never had to really calibrate either printer's e-steps.
          VoodooBaneundefined Mad3DHatterundefined 2 Replies Last reply Reply Quote 0
            You can use either 1.8deg or 0.9deg with a 3:1 geared extruder such as the Titan. I use 1.8deg motors in all my extruders, but as you are using 24V power, if you need to buy a new motor then in your position I would probably choose 0.9deg just in case it makes a difference to print quality.
            • VoodooBaneundefined
              VoodooBane @frank26080115
              @frank26080115 you could always use a 1/4 inch ball bearing. with a "metal spring" flex coupler shaft. I just saw a video on this idk if it works well but it makes sense to me.
              • Mad3DHatterundefined
                Mad3DHatter @frank26080115
                @frank26080115
                HI frank, My name is Justin. I am curious about your flexible system an d what type of flexible shafts you are using .
                frank26080115undefined 1 Reply Last reply Reply Quote 0
                  I'd use the 1.8 with the volcano if you're going to be pushing a lot of high flow filament.
                  But it may be worth noting that E3D themselves recommend a slim (not pancake) 0.9 stepper for the Titan.
                  https://e3d-online.com/motors-slimline-motor
                    frank26080115 @Mad3DHatter
                    @mad3dhatter said in Recommended extruded motor:
                    @frank26080115
                    The first printer is a Ultimaker 2 upgraded with Flex3Drive https://flex3drive.com/flex3drive/f3d-um2/
                    The second printer is a custom built printer using some gears from eBay and the flex shaft from McMaster-Carr https://www.mcmaster.com/5910K92
                    The Flex3Drive I also hacked up to use the same shaft from McMaster-Carr, the old shaft was removed, replaced with a short piece of solid shaft so that it protrudes out the top, and then the new shaft attached to the solid shaft. The new shaft is thicker so it lasts longer.
                    • Jareryundefined
                      Jarery
                      As an update, I went with a Moons 1.8 stepper, 0.46 Nm.
                      Works well so far with very smooth looking surfaces so far.
                      @frank26080115 Very interesting re the changing of the shaft and having the ripples disappear. I really like the flexible shaft direct drive on a delta printer as it removes the Bowden and doesn't add the motor weight. Next time I get motivated to try it again i'll try your suggestion.
                      zaptaundefined 1 Reply Last reply Reply Quote 0
                      • zaptaundefined
                        zapta @Jarery
                        You could also use the nimble in a direct drive mode with a very light motor due to the high gearing. e.g. Moon's 40g MS08HY1R4050.
